Hi, I am very new to cuda, I have installed a clean install of ubuntu 14.04.1 64bit and and GT 730 GPU
Wed Mar 9 17:46:08 2016
| NVIDIA-SMI 352.63 Driver Version: 352.63 |
| 0 GeForce GT 730 Off | 0000:01:00.0 N/A | N/A |
| 40% 36C P8 N/A / N/A | 193MiB / 1023MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
mark@mark-K30AD-M31AD-M51AD:~/Downloads$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GK208 [GeForce GT 730] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1
I have installed the CUDA Toolkit 7.5 and used the default settings for the samples, all installed with no error’s.
The problems I have is when i try to compile the samples:
Example…
mark@mark-K30AD-M31AD-M51AD:~/NVIDIA_CUDA-7.5_Samples/0_Simple/clock$ nvcc clock.cu
clock.cu:28:30: fatal error: helper_functions.h: No such file or directory
#include <helper_functions.h>
so i checked the location of the includes in the make file:
INCLUDES := -I../../common/inc
so i had a look to make sure the path was correct:
mark@mark-K30AD-M31AD-M51AD:~/NVIDIA_CUDA-7.5_Samples/0_Simple/clock$ cd …/…/common/inc
mark@mark-K30AD-M31AD-M51AD:~/NVIDIA_CUDA-7.5_Samples/common/inc$ ls -l
total 432
-rw-r–r-- 1 paddy paddy 20993 Mar 9 17:41 cuda_drvapi_dynlink.c
-rw-r–r-- 1 paddy paddy 11015 Mar 9 17:41 drvapi_error_string.h
drwxr-xr-x 2 paddy paddy 4096 Mar 9 17:41 dynlink
-rw-r–r-- 1 paddy paddy 14883 Mar 9 17:41 dynlink_d3d10.h
-rw-r–r-- 1 paddy paddy 6299 Mar 9 17:41 dynlink_d3d11.h
-rw-r–r-- 1 paddy paddy 5106 Mar 9 17:41 exception.h
drwxr-xr-x 2 paddy paddy 4096 Mar 9 17:41 GL
-rw-r–r-- 1 paddy paddy 15894 Mar 9 17:41 helper_cuda_drvapi.h
-rw-r–r-- 1 paddy paddy 4675 Mar 9 17:41 helper_cuda_gl.h
-rw-r–r-- 1 paddy paddy 36774 Mar 9 17:41 helper_cuda.h
-rw-r–r-- 1 paddy paddy 4159 Mar 9 17:41 helper_cusolver.h
-rw-r–r-- 1 paddy paddy 1168 Mar 9 17:41 helper_functions.h
The list goes on… but sure enough my ‘helper_functions.h’ is where I believe it should be, I am missing something but I have looked high and low on forums and the only info i find is to check that the includes files are in the right location.
any help is really appreciated.
mark
