I built OpenCV 4.5.4 on my Jetson AGX Orin using Mdegans nano_build_opencv script.  WITH_CUDA=ON and OPENCV_GENERATE_PKGCONFIG=ON. JTOP info reports OpenCV: 4.5.4 with CUDA: YES.  The prefix in the build script is /usr/local and pkg-config returns this path. So far so good.
After the build script completes, I can go into build_opencv/opencv/samples/cpp/example_cmake and use cmake and make to successfully build executables that use GpuMat data types with OpenCV functions, but I cannot launch custom kernels this way because the build process is not calling nvcc.
When I try to use nvcc with GpuMats the build complains that OpenCV was not built with CUDA support.
So I made two identical files, differing only in extension, gbi.cu and gbi.cpp.  They both call the opencv utility getBuildInformation(). The two source files are compiled using nvcc and g++ respectively:
nvcc gbi.cu -o gbi_cu
pkg-config --cflags --libs opencv4
g++ gbi.cpp -o gbi_cpppkg-config --cflags --libs opencv4
Each returns identical output notably devoid of any CUDA related content. When I build the same gbi.cpp source file using the example_cmake provided by Opencv, I get a different result. This cmake workflow now includes the lines:
NVIDIA CUDA: YES (ver 11.4, CUFFT CUBLAS FAST_MATH)
NVIDIA GPU arch: 87
NVIDIA PTX archs:
The final line from the cmake-based output is:
  Install to:                    /usr/local
whereas the nvcc pkg-config flow results in:
  Install to:                    /usr
gbi.cu and gbi.cpp contents:
#include "opencv2/core/utility.hpp"
#include "opencv2/core/cuda.hpp"
#include "opencv2/core.hpp"
#include "opencv2/imgproc.hpp"
#include "opencv2/highgui.hpp"
#include "opencv2/videoio.hpp"
#include <iostream>
// CUDA structures and methods
#include <opencv2/cudaarithm.hpp>
#include <opencv2/cudafilters.hpp>
using namespace cv;
using namespace std;
int main()
    cout << "This is built with OpenCV " << CV_VERSION << endl;
    cout << getBuildInformation() << endl;
    return 0;
pkg-config output:
$ echo `pkg-config --cflags --libs opencv4`
-I/usr/local/include/opencv4 -L/usr/local/lib -lopencv_gapi -lopencv_stitching -lopencv_alphamat -lopencv_aruco -lopencv_barcode -lopencv_bgsegm -lopencv_bioinspired -lopencv_ccalib -lopencv_cudabgsegm -lopencv_cudafeatures2d -lopencv_cudaobjdetect -lopencv_cudastereo -lopencv_dnn_objdetect -lopencv_dnn_superres -lopencv_dpm -lopencv_face -lopencv_freetype -lopencv_fuzzy -lopencv_hfs -lopencv_img_hash -lopencv_intensity_transform -lopencv_line_descriptor -lopencv_mcc -lopencv_quality -lopencv_rapid -lopencv_reg -lopencv_rgbd -lopencv_saliency -lopencv_stereo -lopencv_structured_light -lopencv_phase_unwrapping -lopencv_superres -lopencv_cudacodec -lopencv_surface_matching -lopencv_tracking -lopencv_highgui -lopencv_datasets -lopencv_text -lopencv_plot -lopencv_videostab -lopencv_cudaoptflow -lopencv_optflow -lopencv_cudalegacy -lopencv_videoio -lopencv_cudawarping -lopencv_wechat_qrcode -lopencv_xfeatures2d -lopencv_shape -lopencv_ml -lopencv_ximgproc -lopencv_video -lopencv_xobjdetect -lopencv_objdetect -lopencv_calib3d -lopencv_imgcodecs -lopencv_features2d -lopencv_dnn -lopencv_flann -lopencv_xphoto -lopencv_photo -lopencv_cudaimgproc -lopencv_cudafilters -lopencv_imgproc -lopencv_cudaarithm -lopencv_core -lopencv_cudev
getBuildInformation() returned using pkg-config:
This is built with OpenCV 4.5.4
General configuration for OpenCV 4.5.4 =====================================
  Version control:               4.5.4-8-g3e4c170df4
  Platform:
    Timestamp:                   2022-01-18T10:01:01Z
    Host:                        Linux 5.10.65-tegra aarch64
    CMake:                       3.16.3
    CMake generator:             Unix Makefiles
    CMake build tool:            /usr/bin/make
    Configuration:               Release
  CPU/HW features:
    Baseline:                    NEON FP16
  C/C++:
    Built as dynamic libs?:      YES
    C++ standard:                11
    C++ Compiler:                /usr/bin/c++  (ver 9.3.0)
    C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
    C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
    C Compiler:                  /usr/bin/cc
    C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
    C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
    Linker flags (Release):      -Wl,--gc-sections -Wl,--as-needed
    Linker flags (Debug):        -Wl,--gc-sections -Wl,--as-needed
    ccache:                      NO
    Precompiled headers:         NO
    Extra dependencies:          dl m pthread rt
    3rdparty dependencies:
  OpenCV modules:
    To be built:                 calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python2 python3 stitching ts video videoio
    Disabled:                    world
    Disabled by dependency:      -
    Unavailable:                 java
    Applications:                tests perf_tests examples apps
    Documentation:               NO
    Non-free algorithms:         NO
  GUI:                           GTK2
    GTK+:                        YES (ver 2.24.32)
      GThread :                  YES (ver 2.64.6)
      GtkGlExt:                  NO
  Media I/O:
    ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
    JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
    WEBP:                        build (ver encoder: 0x020f)
    PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.37)
    TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.1.0)
    JPEG 2000:                   build (ver 2.4.0)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    FFMPEG:                      YES
      avcodec:                   YES (58.54.100)
      avformat:                  YES (58.29.100)
      avutil:                    YES (56.31.100)
      swscale:                   YES (5.5.100)
      avresample:                YES (4.0.0)
    GStreamer:                   YES (1.16.2)
    v4l/v4l2:                    YES (linux/videodev2.h)
  Parallel framework:            TBB (ver 2020.1 interface 11101)
  Trace:                         YES (with Intel ITT)
  Other third-party libraries:
    Lapack:                      NO
    Eigen:                       YES (ver 3.3.7)
    Custom HAL:                  YES (carotene (ver 0.0.1))
    Protobuf:                    build (3.5.1)
  Python 2:
    Interpreter:                 /usr/bin/python2.7 (ver 2.7.18)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.18)
    numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.16.5)
    install path:                lib/python2.7/dist-packages/cv2/python-2.7
  Python 3:
    Interpreter:                 /usr/bin/python3 (ver 3.8.10)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.8.so (ver 3.8.10)
    numpy:                       /usr/lib/python3/dist-packages/numpy/core/include (ver 1.17.4)
    install path:                lib/python3.8/dist-packages/cv2/python-3.8
  Python (for build):            /usr/bin/python2.7
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
  Install to:                    /usr
getBuildInformation() returned using opencv sample cmake:
  Extra modules:
    Location (extra):            /tmp/build_opencv/opencv_contrib/modules
    Version control (extra):     4.5.4
  Platform:
    Timestamp:                   2023-12-08T20:52:28Z
    Host:                        Linux 5.10.104-tegra aarch64
    CMake:                       3.16.3
    Configuration:               RELEASE
  CPU/HW features:
    Baseline:                    NEON FP16
      required:                  NEON
  C/C++:
    C++ standard:                11
    C++ Compiler:                /usr/bin/c++  (ver 9.4.0)
    ccache:                      NO
    Extra dependencies:          m pthread cudart_static dl rt nppc nppial nppicc nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cudnn cufft -L/usr/local/cuda/lib64 -L/usr/lib/aarch64-linux-gnu
  OpenCV modules:
    To be built:                 alphamat aruco barcode bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dnn_superres dpm face features2d flann freetype fuzzy gapi hfs highgui img_hash imgcodecs imgproc intensity_transform line_descriptor mcc ml objdetect optflow phase_unwrapping photo plot python2 python3 quality rapid reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking video videoio videostab wechat_qrcode xfeatures2d ximgproc xobjdetect xphoto
    Disabled:                    world
    Unavailable:                 cvv hdf java julia matlab ovis sfm ts viz
    Applications:                apps
    Documentation:               NO
    Non-free algorithms:         YES
  GUI:                           GTK3
    GTK+:                        YES (ver 3.24.20)
      GtkGlExt:                  NO
    OpenGL support:              NO
    VTK support:                 NO
  Media I/O:
    OpenEXR:                     build (ver 2.3.0)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    DC1394:                      YES (2.2.5)
    FFMPEG:                      YES
    GStreamer:                   YES (1.16.3)
  Parallel framework:            pthreads
    Lapack:                      YES (/usr/lib/aarch64-linux-gnu/liblapack.so /usr/lib/aarch64-linux-gnu/libcblas.so /usr/lib/aarch64-linux-gnu/libatlas.so)
    NVIDIA GPU arch:             87
    NVIDIA PTX archs:
  cuDNN:                         YES (ver 8.6)
  OpenCL:                        YES (no extra features)
    Include path:                /tmp/build_opencv/opencv/3rdparty/include/opencl/1.2
    Link libraries:              Dynamic load
  Python 2:
  Python 3:
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
What am I missing?  How do I set the flags for nvcc to get the opencv in /usr/local instead of /usr?  As far as I can tell pkg-config is already pointing to the correct directory.
