Hi, I am new to using learning transfer tools, I have a problem installing TRT-OSS / Jetson / README.md during command execution
/usr/ local/bin/cmake … -DGPU_ARCHS = “53 62 72” -DTRT_LIB_DIR = /usr/lib/aarch64-linux-gnu/ -DCMAKE_C_COMPILER = /usr/bin/gcc -DTRT_BIN_DIR = pwd /out
it throws me the following error:
- Parsers Used: caffe; uff; onnx
- InferPlugin Used: OFF
- Licensing: opensource
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUBLASLT_LIB
linked by target “nvinfer_plugin” in directory /home/dlinano/TensorRT/plugin
TENSORRT_LIBRARY_MYELIN
linked by target “nvonnxparser_static” in directory /home/dlinano/TensorRT/parsers/onnx
linked by target “nvonnxparser” in directory /home/dlinano/TensorRT/parsers/onnx
- Configuring incomplete, errors occurred!
See also “/home/dlinano/TensorRT/build/CMakeFiles/CMakeOutput.log”.
See also “/home/dlinano/TensorRT/build/CMakeFiles/CMakeError.log”.Picture output
