Cold-boot KWin journal and NVIDIA kernel log snippets
Jul 02 22:02:05 fedora systemd[9993]: Starting plasma-kwin_x11.service - KDE Window Manager...
Jul 02 22:02:05 fedora systemd[9993]: Started plasma-kwin_x11.service - KDE Window Manager.
Jul 02 22:02:12 fedora kwin_x11[10391]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.kwin'")
Jul 02 22:02:18 fedora kwin_x11[10391]: QDBusConnection: couldn't handle call to Teardown, no slot matched
Jul 02 22:02:18 fedora kwin_x11[10391]: Could not find slot Krunner1Adaptor::Teardown
Jul 02 22:02:27 fedora systemd[9993]: Stopping plasma-kwin_x11.service - KDE Window Manager...
Jul 02 22:02:27 fedora kwin_x11[10391]: Could not delete render time query because no context is current
Jul 02 22:02:27 fedora kwin_x11[10391]: Could not delete framebuffer because no context is current
Jul 02 22:02:27 fedora systemd[9993]: plasma-kwin_x11.service: Main process exited, code=exited, status=15/n/a
Jul 02 22:02:27 fedora systemd[9993]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Jul 02 22:02:27 fedora systemd[9993]: Stopped plasma-kwin_x11.service - KDE Window Manager.
Jul 02 22:02:27 fedora systemd[9993]: plasma-kwin_x11.service: Consumed 1.730s CPU time over 22.473s wall clock time, 66.8M memory peak.
Jul 02 22:02:42 fedora systemd[9993]: Starting plasma-kwin_x11.service - KDE Window Manager...
Jul 02 22:02:42 fedora systemd[9993]: Started plasma-kwin_x11.service - KDE Window Manager.
Jul 02 22:02:47 fedora kwin_x11[13698]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.kwin'")
Jul 02 22:03:34 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 30055, resource id: 20972988, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:03:34 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 30056, resource id: 48234525, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:05:11 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 45715, resource id: 20974359, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:05:11 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 45716, resource id: 48234527, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:05:54 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 55017, resource id: 20975228, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:05:54 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 55018, resource id: 48234530, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:06:48 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 62305, resource id: 20975909, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:06:48 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 62306, resource id: 48234532, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:07:47 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 5740, resource id: 20976742, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:07:47 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 5741, resource id: 48234534, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:10:54 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 12973, resource id: 20982186, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:10:54 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 12974, resource id: 92274710, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:14:36 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 6413, resource id: 20987041, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:14:36 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 6414, resource id: 48234540, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:14:42 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 7294, resource id: 20987080, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:14:42 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 7295, resource id: 48234543, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 02 22:34:06 fedora kwin_x11[13698]: XCB error: 152 (BadDamage), sequence: 12652, resource id: 21024732, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 02 22:34:06 fedora kwin_x11[13698]: XCB error: 3 (BadWindow), sequence: 12653, resource id: 48234577, major code: 129 (SHAPE), minor code: 6 (Input)
=== KERNEL LOGS ===
[ 1.084147] ACPI: bus type drm_connector registered
[ 1.230304] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 1.230319] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 1.232806] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 6.380726] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[ 7.071510] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 595.80 Release Build (dvs-builder@U22-I3-AF05-29-2) Thu May 21 19:21:58 UTC 2026
[ 7.129559] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 8.919264] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[ 9.062606] fbcon: nvidia-drmdrmfb (fb0) is primary device
[ 9.062612] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
