**• Hardware Platform (Jetson / GPU)**dGPU
• DeepStream Version 5.1
• TensorRT Version The latest version that came with Deepstream 5.1
• NVIDIA GPU Driver Version (valid for GPU only) 460.39
• Issue Type( questions, new requirements, bugs) Question
Hello, My use case is to perform auto color correction through a custom element(the function SimplestCB performs this), colorbalance in an image using c++ and opencv - Stack Overflow.
Looking at Not able to draw line on incoming frame, *dsexample->cvmat, is the cv::Mat object of the frame, which I would need to modify.
I call the SimplestCB function, right after the transcoding of RGBA to BGR conversion takes place inside, get_converted_mat
#if (CV_MAJOR_VERSION >= 4)
cv::cvtColor(in_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
#else
cv::cvtColor(in_mat, *dsexample->cvmat, CV_RGBA2BGR);
SimplestCB(*dsexample->cvmat, tmp, 1);
NvBufSurfaceSyncForDevice(dsexample->inter_buf, 0, 0);
cv::cvtColor(*dsexample->cvmat, in_mat, cv::COLOR_BGR2RGBA);
NvBufSurfaceMap(dsexample->inter_buf, 0, 0, NVBUF_MAP_READ_WRITE);
*dsexample->cvmat = tmp.clone();
Here’s the gst-launch command.
gst-launch-1.0 uridecodebin uri='file:///opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_1080p_h264.mp4' ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream-python-pipeline-structuring/dstest_imagedata_config.ini ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! dsexample full-frame=1 ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=I420" ! nvv4l2h264enc bitrate=2000000 ! h264parse ! flvmux latency=200 ! rtmpsink location='rtmp://13.xxx.xxx.xx/streamkey'
The issue is that I’m not able to get the color-corrected frame.
Here, is the normal image before color correction named(Normal-image.png)
Here’s the color-corrected image, i.e what the frame should look like if processed correctly.
I have tried adding NvBuf map and unmap, but that gave internal data stream errors, hence I decided to exclude it from the code I’ve posted here.
Thank you in advance!
