Com.nvidia.cuda.version: 9.0 in Modulus24.12 container
I got “com.nvidia.cuda.version: 9.0” when I ran the command “singularity inspect Modulus.sif” to inspect the image I got from “singularity build Modulus.sif docker://nvcr.io/nvidia/modulus/modulus:24.12”. Is “9.0” a typo in the meta data or Modulus24.12 container is built using cuda version 9.0? The full output from “singularity inspect Modulus.sif” is as following :
com.nvidia.build.id: 114410972
com.nvidia.build.ref: 3e3c067dd015e6d16d2cf59ac18e9f2e2466b68a
com.nvidia.cublas.version: 12.6.3.3
com.nvidia.cudnn.version: 9.5.0.50
com.nvidia.cufft.version: 11.3.0.4
com.nvidia.curand.version: 10.3.7.77
com.nvidia.cusolver.version: 11.7.1.2
com.nvidia.cusparse.version: 12.5.4.2
com.nvidia.cusparselt.version: 0.6.2.3
com.nvidia.cutensor.version: 2.0.2.5
com.nvidia.nccl.version: 2.22.3
com.nvidia.npp.version: 12.3.1.54
com.nvidia.nsightcompute.version: 2024.3.2.3
com.nvidia.nsightsystems.version: 2024.6.1.90
com.nvidia.nvjpeg.version: 12.3.3.54
com.nvidia.pytorch.version: 2.5.0a0+e000cf0
com.nvidia.tensorrt.version: 10.5.0.18
com.nvidia.tensorrtoss.version:
com.nvidia.volumes.needed: nvidia_driver
org.label-schema.build-arch: amd64
org.label-schema.build-date: Saturday_7_December_2024_12:24:47_UTC
org.label-schema.schema-version: 1.0
org.label-schema.usage.singularity.deffile.bootstrap: docker
org.label-schema.usage.singularity.deffile.from: nvcr.io/nvidia/modulus/modulus:24.12
org.label-schema.usage.singularity.version: 4.1.5-1.el8
org.opencontainers.image.ref.name: ubuntu
org.opencontainers.image.version: 22.04
I ran “singularity exec Modulus.sif python3 -c “import torch; print(torch.version.cuda)”” and got 12.6. I guess 9.0 might be a typo.
