Combining distributions using rep.distribution.choice
Hi there,
I’m trying to combine multiple distributions using rep.distribution.choice as is described in the documentation here. Unfortunately, running the example code from the documentation results in an error.
Sample code:
# Add Default Light
distance_light = rep.create.light(rotation=(315,0,0), intensity=3000, light_type="distant")
with rep.trigger.on_frame():
    with rep.create.cube():
        rep.modify.pose(
            position=rep.distribution.choice([
                rep.distribution.uniform((0., 0., 0.), (10., 10., 10.)),
                rep.distribution.normal((100., 100., 100.), (50., 50., 50.))
Error message:
2024-04-15 13:24:51 [25,474ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-10' coro=<Extension.run_script_async() done, defined at /home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/extension.py:173> exception=ValueError("Base type <class 'omni.replicator.core.scripts.utils.utils.ReplicatorItem'> is not supported. Only elements of type str, bool, int and float are supported.")>
  File "/home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/extension.py", line 194, in run_script_async
    spec.loader.exec_module(module)
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/home/nikita/illuminex/temp_test_stack_distributions.py", line 9, in <module>
  File "/home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/utils/utils.py", line 606, in __call__
    return ReplicatorItem(self.__fn, *args, **kwargs)
  File "/home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/utils/utils.py", line 635, in __init__
    self.node = self.__fn(*args, **kwargs)
  File "/home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/distribution.py", line 253, in choice
    data_type = _get_data_type(choices)
  File "/home/nikita/.local/share/ov/pkg/deps/8021e278fce7781f5bb307a5b4b24ed4/extscache/omni.replicator.core-1.9.8+105.0.lx64.r.cp310/omni/replicator/core/scripts/distribution.py", line 53, in _get_data_type
    raise ValueError(
ValueError: Base type <class 'omni.replicator.core.scripts.utils.utils.ReplicatorItem'> is not supported. Only elements of type str, bool, int and float are supported.
I noticed in this forum post it was stated that randomizing distributions is not supported. I assumed that this post must be stale as the documentation states that this feature is supported.
Is it possible to use Omniverse Replicator to combine multiple distributions? If so, how can I do this? If not, when can I expect this feature to be added?
Thanks for the help!
Hi, did you succeed in solving this problem? I would like to do the same but I am having some issues. Thanks
