ComfyUI Performance Problem related to power usage
I’ve been having an issue with ComfyUI running about 30% of its usual speed and it seems to be related to power usage. Normally, for this particular Qwen 2512 workflow, it would generate at 4 seconds per iteration and the GPU temperature would peak at around 80C. Now, it is running at 10.25s per iteration and the GPU temperature is at 44C. GPU power from nvidia-smi is 11W. Any ideas on what might be throttling the GPU like this?
Unplug the power brick from the wall and the Spark for a minute and reconnect and see if it improves. Something is really messed up with PD, even on latest firmware.
Woot! That did the trick. Back to normal.
Hopefully NVIDIA figure this out soon. It’s a serious problem.
