For some reason I’m seeing that my LOW-pass WanVideo Sampler is affinitizing to the CPU and not the GPU; making for longer than necessary create times. Everything else is fine.
Any one else having this issue; what did you do to resolve?
Can you share more context? such as is your library GPU aware? or if you are using a docker container, is it enable to passthru the GPU? Sometimes even if the library is GPU aware, you may need the latest version to take advantage of the SM* version for Blackwell.
Sure - since this is an application environment; e.g. comfyui, I’m questioning (those with experience testing ComfyUI-on-Spark) whether they’ve tested enough to see this problem or if this is more of an interaction between ComfyUI and the default Spark environment. For example, this may be a caching issue where ComfyUI is holding on to a previous state that it doesn’t recover from when restarting. The only caches I’m finding are python related but maybe there’s a Spark state that gets messed up?
This feels like state problem. Long stretches of it working off GPU then it seems to get stuck in CPU mode and doesn’t go back to GPU.
However, this also may be a problem with Spark drivers or hardware that causes GPU resources not to be available so the application falls back to CPU. There appears to be some performance bugs with Spark that I’ve been reading about and fixes not yet released.
This is running ComfyUI from the console within an ssh session on bare metal - no docker, vms, etc… venv for python but that’s it. Everything is updated to its latest - I’ll provide some inventory lists. Doesn’t look like I can attach files so including inline -
COMMAND: nvidia-smi
Sun Jan 18 03:03:12 2026
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 Off | N/A |
| N/A 54C P0 14W / N/A | Not Supported | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3526 G /usr/lib/xorg/Xorg 18MiB |
| 0 N/A N/A 3555 G /usr/bin/gnome-shell 6MiB |
| 0 N/A N/A 4099 C …spark01/comfy-env/bin/python3 21607MiB |
COMMAND: /home/spark01/comfy-env/bin/python /home/spark01/ComfyUI/_support_output_20260118_030309/pip_spotlight.py
“spotlight_versions”: {
“accelerate”: “1.12.0”,
“diffusers”: “0.36.0”,
“numpy”: “2.2.6”,
“opencv-python”: “4.12.0.88”,
“pillow”: “12.0.0”,
“safetensors”: “0.7.0”,
“torch”: “2.9.1+cu130”,
“torchaudio”: “2.9.1”,
“torchvision”: “0.24.1”,
“transformers”: “4.57.3”,
“triton”: “3.5.1”,
“xformers”: null
COMMAND: /home/spark01/comfy-env/bin/python /home/spark01/ComfyUI/_support_output_20260118_030309/key_libs_and_cuda_via_torch.py
/home/spark01/comfy-env/lib/python3.12/site-packages/torch/cuda/init.py:283: UserWarning:
Found GPU0 NVIDIA GB10 which is of cuda capability 12.1.
Minimum and Maximum cuda capability supported by this version of PyTorch is
(8.0) - (12.0)
warnings.warn(
“modules”: {
“PIL”: {
“imported”: true,
“version”: “12.0.0”
“accelerate”: {
“imported”: true,
“version”: “1.12.0”
“cv2”: {
“imported”: true,
“version”: “4.12.0”
“diffusers”: {
“imported”: true,
“version”: “0.36.0”
“einops”: {
“imported”: true,
“version”: “0.8.1”
“numpy”: {
“imported”: true,
“version”: “2.2.6”
“safetensors”: {
“imported”: true,
“version”: “0.7.0”
“torch”: {
“imported”: true,
“version”: “2.9.1+cu130”
“torchaudio”: {
“imported”: true,
“version”: “2.9.1”
“torchvision”: {
“imported”: true,
“version”: “0.24.1”
“tqdm”: {
“imported”: true,
“version”: “4.67.1”
“transformers”: {
“imported”: true,
“version”: “4.57.3”
“triton”: {
“imported”: true,
“version”: “3.5.1”
“xformers”: {
“error”: “No module named ‘xformers’”,
“imported”: false
“torch”: {
“build_config_lines”: [
“PyTorch built with:”,
" - GCC 13.3",
" - C++ Version: 201703",
" - Intel(R) MKL-DNN v3.7.1 (Git Hash 8d263e693366ef8db40acc569cc7d8edf644556d)“,
" - OpenMP 201511 (a.k.a. OpenMP 4.5)”,
" - LAPACK is enabled (usually provided by MKL)“,
" - NNPACK is enabled”,
" - CPU capability usage: DEFAULT",
" - CUDA Runtime 13.0",
" - NVCC architecture flags: -gencode;arch=compute_80,code=sm_80;-gencode;arch=compute_90,code=sm_90;-gencode;arch=compute_100,code=sm_100;-gencode;arch=compute_110,code=sm_110;-gencode;arch=compute_120,code=sm_120;-gencode;arch=compute_120,code=compute_120",
" - CuDNN 91.3",
" - Build settings: BLAS_INFO=nvpl, BUILD_TYPE=Release, COMMIT_SHA=5811a8d7da873dd699ff6687092c225caffcf1bb, CUDA_VERSION=13.0, CUDNN_VERSION=9.13.0, CXX_COMPILER=/opt/rh/gcc-toolset-13/root/usr/bin/c++, CXX_FLAGS=-ffunction-sections -fdata-sections -fvisibility-inlines-hidden -DUSE_PTHREADPOOL -DNDEBUG -DUSE_KINETO -DLIBKINETO_NOROCTRACER -DLIBKINETO_NOXPUPTI=ON -DUSE_PYTORCH_QNNPACK -DAT_BUILD_ARM_VEC256_WITH_SLEEF -DUSE_XNNPACK -DSYMBOLICATE_MOBILE_DEBUG_HANDLE -O2 -fPIC -DC10_NODEPRECATED -Wall -Wextra -Werror=return-type -Werror=non-virtual-dtor -Werror=range-loop-construct -Werror=bool-operation -Wnarrowing -Wno-missing-field-initializers -Wno-unknown-pragmas -Wno-unused-parameter -Wno-strict-overflow -Wno-strict-aliasing -Wno-stringop-overflow -Wsuggest-override -Wno-psabi -Wno-error=old-style-cast -faligned-new -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Werror=format -Wno-dangling-reference -Wno-error=dangling-reference -Wno-stringop-overflow, LAPACK_INFO=nvpl, TORCH_VERSION=2.9.1, USE_CUDA=ON, USE_CUDNN=ON, USE_CUSPARSELT=ON, USE_GFLAGS=OFF, USE_GLOG=OFF, USE_GLOO=ON, USE_MKLDNN=ON, USE_MPI=OFF, USE_NCCL=ON, USE_NNPACK=ON, USE_OPENMP=ON, USE_ROCM=OFF, USE_ROCM_KERNEL_ASSERT=OFF, USE_XCCL=OFF, USE_XPU=OFF, "
“cuda”: {
“allow_tf32_matmul”: false,
“cudnn_enabled”: true,
“cudnn_version”: 91300,
“device_count”: 1,
“is_available”: true,
“torch_cuda_version”: “13.0”
“devices”: [
“index”: 0,
“major”: 12,
“minor”: 1,
“multi_processor_count”: 48,
“name”: “NVIDIA GB10”,
“total_memory_bytes”: 128499458048
“torch_git_version”: “5811a8d7da873dd699ff6687092c225caffcf1bb”,
“torch_version”: “2.9.1+cu130”
COMMAND: /home/spark01/comfy-env/bin/python /home/spark01/ComfyUI/_support_output_20260118_030309/python_runtime_inventory.py
“env”: {
“PATH”: “/home/spark01/comfy-env/bin:/home/spark01/comfy-env/bin:/usr/local/cuda/bin:/opt/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin”,
“VIRTUAL_ENV”: “/home/spark01/comfy-env”
“python”: {
“base_prefix”: “/usr”,
“executable”: “/home/spark01/comfy-env/bin/python”,
“implementation”: “CPython”,
“platform”: “Linux-6.14.0-1015-nvidia-aarch64-with-glibc2.39”,
“prefix”: “/home/spark01/comfy-env”,
“version”: “3.12.3 (main, Jan 8 2026, 11:30:50) [GCC 13.3.0]”
“site”: {
“getsitepackages”: [
“/home/spark01/comfy-env/lib/python3.12/site-packages”,
“/home/spark01/comfy-env/local/lib/python3.12/dist-packages”,
“/home/spark01/comfy-env/lib/python3/dist-packages”,
“/home/spark01/comfy-env/lib/python3.12/dist-packages”
“getusersitepackages”: “/home/spark01/.local/lib/python3.12/site-packages”
“sys_path”: [
“/home/spark01/ComfyUI/_support_output_20260118_030309”,
“/usr/lib/python312.zip”,
“/usr/lib/python3.12”,
“/usr/lib/python3.12/lib-dynload”,
“sysconfig”: {
“paths”: {
“data”: “/home/spark01/comfy-env”,
“include”: “/usr/include/python3.12”,
“platinclude”: “/usr/include/python3.12”,
“platlib”: “/home/spark01/comfy-env/lib/python3.12/site-packages”,
“platstdlib”: “/home/spark01/comfy-env/lib/python3.12”,
“purelib”: “/home/spark01/comfy-env/lib/python3.12/site-packages”,
“scripts”: “/home/spark01/comfy-env/bin”,
“stdlib”: “/usr/lib/python3.12”
“platform”: “linux-aarch64”
Import sanity checks using venv python:
python: Python 3.12.3
Test: import torch / print key attributes
torch: 2.9.1+cu130
cuda available: True
torch.version.cuda: 13.0
COMMAND: /home/spark01/comfy-env/bin/pip freeze --all
absl-py==2.3.1
accelerate==1.12.0
aiofiles==24.1.0
aiohappyeyeballs==2.6.1
aiohttp==3.13.3
aiohttp_socks==0.11.0
aioice==0.10.2
aiortc==1.14.0
aiosignal==1.4.0
alembic==1.18.0
aliyun-python-sdk-core==2.16.0
aliyun-python-sdk-kms==2.16.5
annotated-doc==0.0.4
annotated-types==0.7.0
antlr4-python3-runtime==4.9.3
anyascii==0.3.3
anyio==4.12.1
argbind==0.3.9
arrow==1.4.0
asgiref==3.11.0
asttokens==3.0.1
attrs==25.4.0
audio-separator==0.41.0
audioread==3.1.0
av==16.1.0
babel==2.17.0
beartype==0.18.5
binaryornot==0.4.4
bitsandbytes==0.49.1
boto3==1.34.86
botocore==1.34.162
brotli==1.2.0
cached_path==1.8.1
certifi==2026.1.4
cffi==2.0.0
cfgv==3.5.0
chardet==5.2.0
charset-normalizer==3.4.4
click==8.1.8
cn2an==0.5.23
color-matcher==0.6.0
coloredlogs==15.0.1
comfy-cli==1.5.4
comfy-kitchen==0.2.6
comfyui-embedded-docs==0.4.0
comfyui-workflow-templates-core==0.3.88
comfyui-workflow-templates-media-api==0.3.39
comfyui-workflow-templates-media-image==0.3.55
comfyui-workflow-templates-media-other==0.3.80
comfyui-workflow-templates-media-video==0.3.38
comfyui_frontend_package==1.36.14
comfyui_workflow_templates==0.8.4
conformer==0.3.2
contourpy==1.3.3
contractions==0.1.73
cookiecutter==2.6.0
crcmod==1.7
cryptography==46.0.3
csvw==3.7.0
cycler==0.12.1
Cython==3.2.4
dacite==1.9.2
datasets==4.5.0
ddt==1.7.2
decorator==5.2.1
descript-audio-codec==1.0.0
descript-audiotools==0.7.2
diffq==0.2.4
diffusers==0.36.0
dill==0.4.0
Distance==0.1.3
distlib==0.4.0
dlinfo==2.0.0
dnspython==2.8.0
docstring_parser==0.17.0
docutils==0.22.4
editdistance==0.8.1
einops==0.8.1
einx==0.3.0
ema-pytorch==0.7.9
encodec==0.1.1
executing==2.2.1
faiss-cpu==1.13.2
fal_client==0.11.0
fastapi==0.128.0
ffmpy==1.0.0
filelock==3.20.3
fire==0.7.1
flatbuffers==25.12.19
flatten-dict==0.4.2
fonttools==4.61.1
frozendict==2.4.7
frozenlist==1.8.0
fsspec==2025.10.0
ftfy==6.3.1
funasr==1.3.0
g2p-en==2.1.0
gguf==0.17.1
gitdb==4.0.12
GitPython==3.1.46
google-api-core==2.29.0
google-auth==2.47.0
google-cloud-core==2.5.0
google-cloud-storage==3.8.0
google-crc32c==1.8.0
google-resumable-media==2.8.0
googleapis-common-protos==1.72.0
gradio==6.3.0
gradio_client==1.13.3
greenlet==3.3.0
groovy==0.1.2
grpcio==1.76.0
h11==0.16.0
h2==4.3.0
h5py==3.15.1
hf-xet==1.2.0
hpack==4.1.0
httpcore==1.0.9
httpx==0.28.1
httpx-sse==0.4.3
huggingface-hub==0.36.0
humanfriendly==10.0
hydra-core==1.3.2
hyper-connections==0.4.6
hyperframe==6.1.0
HyperPyYAML==1.2.3
identify==2.6.16
idna==3.11
ifaddr==0.2.0
ImageIO==2.37.2
imageio-ffmpeg==0.6.0
importlib_metadata==8.7.1
importlib_resources==6.5.2
inflect==7.5.0
iopath==0.1.10
ipython==9.9.0
ipython_pygments_lexers==1.1.1
isodate==0.7.2
jaconv==0.4.1
jamo==0.4.1
jedi==0.19.2
jieba==0.42.1
Jinja2==3.1.6
jmespath==0.10.0
joblib==1.5.3
json-logic==0.7.0a0
json5==0.13.0
jsonschema==4.26.0
jsonschema-specifications==2025.9.1
julius==0.2.7
kaldifst==1.7.17
kaldiio==2.18.1
keras==3.13.1
kiwisolver==1.4.9
kornia==0.8.2
kornia_rs==0.1.10
language-tags==1.2.0
lazy_loader==0.4
librosa==0.11.0
llvmlite==0.46.0
local-attention==1.11.2
loguru==0.7.3
Mako==1.3.10
Markdown==3.10
markdown-it-py==4.0.0
markdown2==2.5.4
MarkupSafe==2.1.5
matplotlib==3.10.8
matplotlib-inline==0.2.1
matrix-nio==0.25.2
mdurl==0.1.2
mixpanel==5.1.0
ml_collections==1.1.0
ml_dtypes==0.5.4
modelscope==1.33.0
monotonic-alignment-search==0.2.1
more-itertools==10.8.0
mpmath==1.3.0
msgpack==1.1.2
mss==10.1.0
multidict==6.7.0
multiprocess==0.70.18
munch==4.0.0
namex==0.1.0
networkx==3.6.1
ninja==1.11.1.4
nltk==3.9.2
nodeenv==1.10.0
numba==0.63.1
numpy==2.2.6
nvidia-cublas==13.0.0.19
nvidia-cuda-cupti==13.0.48
nvidia-cuda-nvrtc==13.0.48
nvidia-cuda-runtime==13.0.48
nvidia-cudnn-cu13==9.13.0.50
nvidia-cufft==12.0.0.15
nvidia-cufile==1.15.0.42
nvidia-curand==10.4.0.35
nvidia-cusolver==12.0.3.29
nvidia-cusparse==12.6.2.49
nvidia-cusparselt-cu13==0.8.0
nvidia-nccl-cu13==2.27.7
nvidia-nvjitlink==13.0.39
nvidia-nvshmem-cu13==3.3.24
nvidia-nvtx==13.0.39
omegaconf==2.3.0
onnx==1.20.1
onnx-weekly==1.21.0.dev20260112
onnx2torch-py313==1.6.0
onnxruntime==1.23.2
open_clip_torch==3.2.0
openai-whisper==20250625
opencv-python==4.12.0.88
opencv-python-headless==4.12.0.88
optree==0.18.0
orjson==3.11.5
oss2==2.19.1
packaging==25.0
pandas==2.3.3
parso==0.8.5
pathspec==1.0.3
peft==0.18.1
pexpect==4.9.0
phonemizer==3.3.0
piexif==1.1.3
pillow==12.0.0
pip==25.3
platformdirs==4.5.1
pooch==1.8.2
portalocker==3.2.0
praat-parselmouth==0.4.7
pre_commit==4.5.1
proces==0.1.7
prompt_toolkit==3.0.52
propcache==0.4.1
proto-plus==1.27.0
protobuf==6.33.4
psutil==7.2.1
ptyprocess==0.7.0
pure_eval==0.2.3
pyahocorasick==2.3.0
pyarrow==22.0.0
pyasn1==0.6.2
pyasn1_modules==0.4.2
pycparser==2.23
pycryptodome==3.23.0
pydantic==2.12.5
pydantic-settings==2.12.0
pydantic_core==2.41.5
pydub==0.25.1
pyee==13.0.0
PyGithub==2.8.1
Pygments==2.19.2
PyJWT==2.10.1
pylibsrtp==1.0.0
pyloudnorm==0.2.0
PyNaCl==1.6.2
pynndescent==0.6.0
pyOpenSSL==25.3.0
pyparsing==3.3.1
pyphen==0.17.2
pypinyin==0.55.0
pystoi==0.4.1
python-dateutil==2.9.0.post0
python-dotenv==1.2.1
python-multipart==0.0.21
python-slugify==8.0.4
python-socks==2.8.0
pytorch-wpe==0.0.1
pytz==2025.2
PyWavelets==1.9.0
pyworld==0.3.5
PyYAML==6.0.3
questionary==2.1.1
randomname==0.2.1
rdflib==7.5.0
redis==7.1.0
referencing==0.37.0
regex==2025.11.3
replicate==1.0.7
requests==2.32.5
resampy==0.4.3
resemble-perth==1.0.1
rfc3986==1.5.0
rich==14.2.0
rotary-embedding-torch==0.6.5
rpds-py==0.30.0
rsa==4.9.1
ruamel.yaml==0.18.17
ruamel.yaml.clib==0.2.15
ruff==0.14.11
s3tokenizer==0.3.0
s3transfer==0.10.4
safehttpx==0.1.7
safetensors==0.7.0
SAM-2 @ git+https://github.com/facebookresearch/sam2@2b90b9f5ceec907a1c18123530e92e794ad901a4
samplerate==0.1.0
scikit-image==0.26.0
scikit-learn==1.8.0
scipy==1.17.0
segment-anything==1.0
segments==2.3.0
semantic-version==2.10.0
semver==3.0.4
sentencepiece==0.2.1
sentry-sdk==2.49.0
setuptools==70.2.0
shellingham==1.5.4
six==1.17.0
smmap==5.0.2
sounddevice==0.5.3
soundfile==0.13.1
soxr==1.0.0
spandrel==0.4.1
SQLAlchemy==2.0.45
stack-data==0.6.3
starlette==0.49.3
surrealist==1.1.2
sympy==1.14.0
tensorboard==2.20.0
tensorboard-data-server==0.7.2
tensorboardX==2.6.4
termcolor==3.3.0
text-unidecode==1.3
textsearch==0.0.24
textstat==0.7.12
threadpoolctl==3.6.0
tifffile==2025.12.20
tiktoken==0.12.0
timm==1.0.19
tokenizers==0.22.2
toml==0.10.2
tomlkit==0.13.3
torch==2.9.1+cu130
torch-complex==0.4.4
torch-stoi==0.2.3
torchaudio==2.9.1
torchcrepe==0.0.24
torchdiffeq==0.2.5
torchfcpe==0.0.4
torchsde==0.2.6
torchvision==0.24.1
tqdm==4.67.1
traitlets==5.14.3
trampoline==0.1.2
transformers==4.57.3
triton==3.5.1
typeguard==4.4.4
typer==0.21.1
typer-slim==0.21.1
typing-inspection==0.4.2
typing_extensions==4.15.0
tzdata==2025.3
umap-learn==0.5.11
Unidecode==1.4.0
unpaddedbase64==2.1.0
uritemplate==4.2.0
urllib3==2.6.3
uv==0.9.24
uvicorn==0.40.0
vector-quantize-pytorch==1.27.19
vibevoice @ git+https://github.com/FushionHub/VibeVoice.git@3dd860579757310343749cba9623afde9e69c657
virtualenv==20.36.1
vocos==0.1.0
wandb==0.24.0
wcwidth==0.2.14
websocket-client==1.9.0
websockets==15.0.1
Werkzeug==3.1.5
wetext==0.1.2
wheel==0.45.1
x-transformers==2.14.2
xxhash==3.6.0
yarl==1.22.0
zipp==3.23.0
Have you tried –gpu-only when running up ComfyUI?
I use python3 main.py --listen 127.0.0.1 --disable-mmap --use-sage-attention --supports-fp8-compute --gpu-only --cache-none --port 8188
