Thanks for the reply,
Inside of Visual Studios all of the files seem to build fine using the default output/intermediate directories, however, when I change these, one of my files fails to compile. The build log is as follows:
Compiling Project ...
src\terrain_cell_class.f90
c:\program files (x86)\pgi\win32\12.5\bin\pgfortran.exe -Hx,123,8 -Hx,123,0x40000 -Hx,0,0x40000000 -Mx,0,0x40000000 -Hx,0,0x20000000 -g -Bstatic -Mbackslash -Mfree -I"c:\program files (x86)\pgi\win32\12.5\include" -I"C:\Program Files\PGI\Microsoft Open Tools 10\include" -I"C:\Program Files\PGI\Microsoft Open Tools 10\PlatformSDK\include" -Minform=warn -module "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib" -o "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj" -c "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90"
Command exit code: 2
So I decided to try running this from a command prompt using:
pgfortran -Hx,123,8 -Hx,123,0x40000 -Hx,0,0x40000000 -Mx,0,0x40000000 -Hx,0,0x20000000 -g -Bstatic -Mbackslash -Mfree -I"c:\program files (x86)\pgi\win32\12.5\include" -I"C:\Program Files\PGI\Microsoft Open Tools 10\include" -I"C:\Program Files\PGI\Microsoft Open Tools 10\PlatformSDK\include" -Minform=warn -module "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib" -o "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj" -c "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90"
This failed to execute so I tried:
pgfortran -g -Bstatic -Mbackslash -Mfree -Minform=warn -module "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib" -o "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj" -c "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90"
This command caused windows to report that ‘pgf901.exe’ had stopped working. When I added the -v flag, however, the command executed and seemed to compile the file successfully.
pgfortran -g -Bstatic -Mbackslash -Mfree -Minform=warn -module "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib" -o "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj" -c -v "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90"
Output:
"C:\Program Files (x86)\PGI/win32/12.5/bin\pgf901.EXE" "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90" -debug -x 120 0x200 -opt 0 -inform warn -nohpf -nostatic -x 15 2 -x 49 0x400004 -x 51 0x20 -x 57 0x4c -x 58 0x10000 -x 124 0x1000 -x 120 0x80000000 -x 59 4 -x 51 0x20 -x 119 0x1000 -x 121 0x10000 -x 124 0x401 -x 19 0x400000 -x 119 0x9900000 -x 57 0x7b0000 -x 58 0x78031040 -x 119 0x610400 -x 120 0x80000000 -x 59 4 -x 15 2 -x 48 5375 -stdinc "C:\Program Files (x86)\PGI/win32/12.5/include;C:/Program Files/PGI/Microsoft Open Tools 10/include/sys;C:/Program Files/PGI/Microsoft Open Tools 10/include;C:/Program Files/PGI/Microsoft Open Tools 10/PlatformSDK/include" -def __extension__= -def _MT -def _M_IX86=600 -def _M_IX86_FP=0 -def _WIN32 -def __WIN32 -def __WIN32__ -def i386 -def__i386 -def __i386__ -def __unaligned= -def _INTEGRAL_MAX_BITS=64 -def __amd64__ -def __SSE__ -def __MMX__ -def __SSE2__ -def __SSE3__ -def __SSSE3__ -def fastcall= -def __PGI_TOOLS10 -freeform -vect 48 -y 54 1 -x 49 0x1000 -x 124 0x40 -freeform -moddir C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib" -modexport C:\Users\testUser\AppData\Local\Temp\pgfortran3bzGwlNms5qlO.cmod -modindex C:\Users\testUser\AppData\Local\Temp\pgfortran4cHGwJGruWe6e.cmdx -output C:\Users\testUser\AppData\Local\Temp\pgfortran2arGwZGOakh3p.ilm
NOTE: your trial license will expire in 14 days, 9.28 hours.
0 inform, 0 warnings, 0 severes, 0 fatal for terrain_cell_class
0 inform, 0 warnings, 0 severes, 0 fatal for new_terrain_cell
0 inform, 0 warnings, 0 severes, 0 fatal for delete_terrain_cell
0 inform, 0 warnings, 0 severes, 0 fatal for init_terrain_cell
0 inform, 0 warnings, 0 severes, 0 fatal for set_os_type
0 inform, 0 warnings, 0 severes, 0 fatal for get_filename
0 inform, 0 warnings, 0 severes, 0 fatal for read_dted_file
0 inform, 0 warnings, 0 severes, 0 fatal for read_dted_headers
0 inform, 0 warnings, 0 severes, 0 fatal for get_cell_height_deg
0 inform, 0 warnings, 0 severes, 0 fatal for cached_height
0 inform, 0 warnings, 0 severes, 0 fatal for readinto_height
0 inform, 0 warnings, 0 severes, 0 fatal for get_ground_range_incr
0 inform, 0 warnings, 0 severes, 0 fatal for rms_path
0 inform, 0 warnings, 0 severes, 0 fatal for rms_area
0 inform, 0 warnings, 0 severes, 0 fatal for rms_area_cell
0 inform, 0 warnings, 0 severes, 0 fatal for read_into_dted_file
0 inform, 0 warnings, 0 severes, 0 fatal for clear_cell_cache
0 inform, 0 warnings, 0 severes, 0 fatal for not_found
0 inform, 0 warnings, 0 severes, 0 fatal for get_indexes
0 inform, 0 warnings, 0 severes, 0 fatal for bytes2height
PGF90/x86 Windows 12.5-0: compilation successful
"C:\Program Files (x86)\PGI/win32/12.5/bin\pgf902.EXE" C:\Users\testUser\AppData\Local\Temp\pgfortran2arGwZGOakh3p.ilm -fn "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90" -debug -x 120 0x200 -opt 0 -inform warn -x 51 0x20 -x 120 0x80000000 -x 59 4 -x 119 0xa11400 -x 119 0x8900000 -x 122 0x44 -x 19 0x400000-x 28 0x40000 -x 123 0x1000 -x 127 4 -x 127 17 -x 119 0x1610400 -x 92 1 -y 80 0x1000 -y 124 0x1000 -tp sandybridge -x 70 0x8000 -x 122 1 -x 120 0x200 -x 51 0x20 -x 119 0x1000 -x 121 0x10000 -x 124 0x401 -x 119 0x1400000 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 15 2 -astype 0 -x 124 1 -x 124 0x40 -cmdline "+pgfortran C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\futils\src\terrain_cell_class.f90 -g -Bstatic -Mbackslash -Mfree -Minform=warn -module C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib -o C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj -c -v" -asm C:\Users\testUser\AppData\Local\Temp\pgfortran5dPGw7K9QTf2o.s
"C:\Program Files (x86)\PGI/win32/12.5/bin\as32.EXE" C:\Users\testUser\AppData\Local\Temp\pgfortran5dPGw7K9QTf2o.s -o C:\Users\testUser\AppData\Local\Temp\pgfortran6eXGwtmkBStqx.obj
"C:\Program Files (x86)\PGI/win32/12.5/bin\pgcnv.EXE" C:\Users\testUser\AppData\Local\Temp\pgfortran6eXGwtmkBStqx.obj "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj"
"C:\Program Files (x86)\PGI/win32/12.5/bin\pgappend.EXE" -noerror "C:\Users\testUser\Documents\Visual Studio 2010\Projects\RRT-Build\BuildDir\lib\terrain_cell_class.obj" -name .IPDINFO C:\Users\testUser\AppData\Local\Temp\pgfortran3bzGwlNms5qlO.cmod -name .IPEINFO C:\Users\testUser\AppData\Local\Temp\pgfortran4cHGwJGruWe6e.cmdx
Unlinking C:\Users\testUser\AppData\Local\Temp\pgfortran2arGwZGOakh3p.ilm
Unlinking C:\Users\testUser\AppData\Local\Temp/pgfortran2arGwZGOakh3p.dbg
Unlinking C:\Users\testUser\AppData\Local\Temp\pgfortran3bzGwlNms5qlO.cmod
Unlinking C:\Users\testUser\AppData\Local\Temp\pgfortran4cHGwJGruWe6e.cmdx
Unlinking C:\Users\testUser\AppData\Local\Temp\pgfortran5dPGw7K9QTf2o.s
Unlinking C:\Users\testUser\AppData\Local\Temp\pgfortran6eXGwtmkBStqx.obj
Thanks,
John
