Hi everybody,
First of all I appology for my english level ^^
Being new user of GPU programming, i started following all steps to install CUDA and i could use it with the Samples programs proposed with the installation…
But trying to compile my algorithm (coded on Code::Blocks under Ubuntu) that uses Lemon libraries, Thread and mutex libraries aswell (handled by c++11) I started having some weird errors…
I tried changing the IDE and use Nsight … and even try by changing makefiles and try to copy configuration on a sample but no way to make the algorithm work even by not using yet CUDA …
Here you can see the errors I get:
from ../src/MyHybridGPUAlgo.cpp:8:
/usr/include/c++/4.8/cmath:1609:3: note: constexpr float std::round(float)
round(float __x)
/usr/include/c++/4.8/cmath:1613:3: note: constexpr long double std::round(long double)
round(long double __x)
In file included from /usr/include/c++/4.8/random:52:0,
from /usr/include/c++/4.8/bits/stl_algo.h:65,
from /usr/include/c++/4.8/algorithm:62,
from /usr/local/include/lemon/core.h:23,
from /usr/local/include/lemon/list_graph.h:26,
from ../src/../include/../include/graph.h:6,
from ../src/../include/functions.h:7,
/usr/include/c++/4.8/bits/random.tcc:1624:33: error: call of overloaded ‘sqrt(double)’ is ambiguous
_M_s1 = std::sqrt(__np * __1p) * (1 + _M_d1 / (4 * __np));
/usr/include/c++/4.8/bits/random.tcc:1624:33: note: candidates are:
In file included from /home/-/Desktop/lemon-1.3.1/lemon/math.h:30:0,
from /usr/include/c++/4.8/cmath:44,
from /usr/include/c++/4.8/random:38,
/usr/include/c++/4.8/cmath:482:3: note: constexpr float std::sqrt(float)
sqrt(float __x)
/usr/include/c++/4.8/cmath:486:3: note: constexpr long double std::sqrt(long double)
sqrt(long double __x)
/usr/include/c++/4.8/bits/random.tcc:1625:33: error: call of overloaded ‘sqrt(double)’ is ambiguous
_M_s2 = std::sqrt(__np * __1p) * (1 + _M_d2 / (4 * _M_t * __1p));
/usr/include/c++/4.8/bits/random.tcc:1625:33: note: candidates are:
sqrt(float __x)
/usr/include/c++/4.8/bits/random.tcc:1627:25: error: call of overloaded ‘exp(double&)’ is ambiguous
_M_a1 = std::exp(_M_c) * _M_s1 * __spi_2;
/usr/include/c++/4.8/bits/random.tcc:1627:25: note: candidates are:
/usr/include/c++/4.8/cmath:241:3: note: constexpr float std::exp(float)
exp(float __x)
/usr/include/c++/4.8/cmath:245:3: note: constexpr long double std::exp(long double)
exp(long double __x)
/usr/include/c++/4.8/bits/random.tcc:1632:48: error: call of overloaded ‘exp(double)’ is ambiguous
* std::exp(-_M_d1 * _M_d1 / (2 * __s1s)));
/usr/include/c++/4.8/bits/random.tcc:1632:48: note: candidates are:
exp(float __x)
/usr/include/c++/4.8/bits/random.tcc:1635:44: error: call of overloaded ‘exp(double)’ is ambiguous
* std::exp(-_M_d2 * _M_d2 / (2 * __s2s)));
/usr/include/c++/4.8/bits/random.tcc:1635:44: note: candidates are:
exp(float __x)
/usr/include/c++/4.8/bits/random.tcc:1636:33: error: call of overloaded ‘lgamma(double)’ is ambiguous
_M_lf = (std::lgamma(__np + 1)
/usr/include/c++/4.8/bits/random.tcc:1636:33: note: candidates are:
/usr/include/c++/4.8/cmath:1406:3: note: constexpr float std::lgamma(float)
lgamma(float __x)
/usr/include/c++/4.8/cmath:1410:3: note: constexpr long double std::lgamma(long double)
lgamma(long double __x)
/usr/include/c++/4.8/bits/random.tcc:1638:34: error: call of overloaded ‘log(double)’ is ambiguous
_M_lp1p = std::log(__pa / __1p);
/usr/include/c++/4.8/bits/random.tcc:1638:34: note: candidates are:
/usr/include/c++/4.8/cmath:357:3: note: constexpr float std::log(float)
log(float __x)
/usr/include/c++/4.8/cmath:361:3: note: constexpr long double std::log(long double)
log(long double __x)
/usr/include/c++/4.8/bits/random.tcc:1640:46: error: call of overloaded ‘log(double)’ is ambiguous
_M_q = -std::log(1 - (__p12 - __pa) / __1p);
/usr/include/c++/4.8/bits/random.tcc:1640:46: note: candidates are:
log(float __x)
/usr/include/c++/4.8/bits/random.tcc:1644:28: error: call of overloaded ‘log(double)’ is ambiguous
_M_q = -std::log(1 - __p12);
/usr/include/c++/4.8/bits/random.tcc:1644:28: note: candidates are:
log(float __x)
/usr/include/c++/4.8/bits/random.tcc: In member function ‘std::binomial_distribution<_IntType>::result_type std::binomial_distribution<_IntType>::operator()(_UniformRandomNumberGenerator&, const std::binomial_distribution<_IntType>::param_type&)’:
/usr/include/c++/4.8/bits/random.tcc:1732:24: error: call of overloaded ‘floor(const double&)’ is ambiguous
__x = std::floor(__y);
/usr/include/c++/4.8/bits/random.tcc:1732:24: note: candidates are:
/usr/include/c++/4.8/cmath:279:3: note: constexpr float std::floor(float)
floor(float __x)
/usr/include/c++/4.8/cmath:283:3: note: constexpr long double std::floor(long double)
floor(long double __x)
/usr/include/c++/4.8/bits/random.tcc:1744:25: error: call of overloaded ‘floor(double)’ is ambiguous
__x = std::floor(-__y);
/usr/include/c++/4.8/bits/random.tcc:1744:25: note: candidates are:
floor(float __x)
/usr/include/c++/4.8/bits/random.tcc:1755:27: error: call of overloaded ‘floor(const double&)’ is ambiguous
/usr/include/c++/4.8/bits/random.tcc:1755:27: note: candidates are:
floor(float __x)
/usr/include/c++/4.8/bits/random.tcc:1767:28: error: call of overloaded ‘floor(double)’ is ambiguous
/usr/include/c++/4.8/bits/random.tcc:1767:28: note: candidates are:
floor(float __x)
/usr/include/c++/4.8/bits/random.tcc:1776:35: error: call of overloaded ‘lgamma(double)’ is ambiguous
std::lgamma(__np + __x + 1)
/usr/include/c++/4.8/bits/random.tcc:1776:35: note: candidates are:
lgamma(float __x)
/usr/include/c++/4.8/bits/random.tcc: In member function ‘std::piecewise_linear_distribution<_RealType>::result_type std::piecewise_linear_distribution<_RealType>::operator()(_UniformRandomNumberGenerator&, const std::piecewise_linear_distribution<_RealType>::param_type&)’:
/usr/include/c++/4.8/bits/random.tcc:3289:33: error: call of overloaded ‘sqrt(const double&)’ is ambiguous
__x += 0.5 * (std::sqrt(__d) - __b) / __a;
/usr/include/c++/4.8/bits/random.tcc:3289:33: note: candidates are:
sqrt(float __x)
In file included from ../src/MyHybridGPUAlgo.cpp:13:0:
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h: In constructor ‘lemon::NetworkSimplex<GR, V, C>::BlockSearchPivotRule::BlockSearchPivotRule(lemon::NetworkSimplex<GR, V, C>&)’:
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:373:70: error: call of overloaded ‘sqrt(double)’ is ambiguous
std::sqrt(double(_search_arc_num))),
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:373:70: note: candidates are:
sqrt(float __x)
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h: In constructor ‘lemon::NetworkSimplex<GR, V, C>::CandidateListPivotRule::CandidateListPivotRule(lemon::NetworkSimplex<GR, V, C>&)’:
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:450:71: error: call of overloaded ‘sqrt(double)’ is ambiguous
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:450:71: note: candidates are:
sqrt(float __x)
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h: In constructor ‘lemon::NetworkSimplex<GR, V, C>::AlteringListPivotRule::AlteringListPivotRule(lemon::NetworkSimplex<GR, V, C>&)’:
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:567:70: error: call of overloaded ‘sqrt(double)’ is ambiguous
/home/-/Desktop/lemon-1.3.1/lemon/network_simplex.h:567:70: note: candidates are:
sqrt(float __x)
make: *** [src/MyHybridGPUAlgo.o] Error 1
17:52:00 Build Finished (took 1s.271ms)
So please can anyone help me by at least explaining to me why I get those errors … :)
Thank you …
Cordially
