Compatible Inverter for Drive Orin for Vehicle Installation
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We are trying to install the Nvidia Drive Orin in Vehicle, and since the Orin requires only AC power, so can you please suggest any compatible DC to AC Inverters which can be helpful in powering up the Orin in vehicle
The power to developer system is supplied by an SFX12V PS included in the system.
AC voltage 100-240VAC.
AC current 4A at 100VAC / 2A at 240VAC.
Frequency 47-63Hz.
The SFX PSU power supply cold start inrush rating is 65A max at 115VAC, 130A max at 230VAC.
The inverter power budget should be considered.
Is it possible to directly connect DC power to Orin if we remove the SFX12V PS
Hi @JimWang,
Can you recommend an inverter which would work for the specifications provided for powering the Orin system in vehicle
Inverter support at least 300 Watt should work.
