Hello.
Why the code below return error at compile time? Am I violating some constraint?
[codebox]#include <stdlib.h>
#include <stdio.h>
global void parcimoniosoKernel(int *zd);
device int viavel(int m, int nos, int *zd);
int main( int argc, char** argv) {
int *zd; cudaMalloc((void **)&zd, sizeof(int) * 10);
parcimoniosoKernel<<<1, 1>>>(zd);
return 0;
global void parcimoniosoKernel(int *zd) {
viavel(60, 60, zd);
device int viavel(int m, int nos, int *zd) {
int i=0;
int w[nos+1];
for (i=1; i<=nos-1; i++) {
int x = zd[i];
w[x] = w[x] + 1;
return 0;
}[/codebox]
error:
[codebox]Signal: Segmentation fault in Code_Expansion phase.
(0): Error: Signal Segmentation fault in phase Code_Expansion – processing aborted
*** Internal stack backtrace:
/usr/local/cuda/open64/lib//be [0x82edd22]
/usr/local/cuda/open64/lib//be [0x82ee700]
/usr/local/cuda/open64/lib//be [0x82eea8c]
/usr/local/cuda/open64/lib//be [0x82edf73]
/usr/local/cuda/open64/lib//be [0x82eed32]
[0x4001e400]
/usr/local/cuda/open64/lib//be [0x81a1dc3]
/usr/local/cuda/open64/lib//be [0x819ea8c]
/usr/local/cuda/open64/lib//be [0x819fd4b]
/usr/local/cuda/open64/lib//be [0x819edb3]
/usr/local/cuda/open64/lib//be [0x81a35a5]
/usr/local/cuda/open64/lib//be [0x81a41cc]
/usr/local/cuda/open64/lib//be [0x81a4735]
/usr/local/cuda/open64/lib//be [0x8180fa5]
/usr/local/cuda/open64/lib//be [0x804c501]
/usr/local/cuda/open64/lib//be [0x804d297]
/usr/local/cuda/open64/lib//be [0x804e5ff]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5) [0x40172775]
/usr/local/cuda/open64/lib//be [0x804aa81]
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be died due to signal 4
[/codebox]
