I perform compilation with option -ta=tesla:cc60 recommended by pgaccelinfo tool. I get the following error message
function: plate
line: 275
Current region was compiled for:
NVIDIA Tesla GPU sm60
Available accelerators:
device[1]: Native X86 (CURRENT DEVICE)
The accelerator does not match the profile for which this program was compiled
The pgaccelinfo tool yields
CUDA Driver Version: 8000
NVRM version: NVIDIA UNIX x86_64 Kernel Module 367.48 Sat Sep 3 18:21:08 PDT 2016
Device Number: 0
Device Name: Tesla P100-PCIE-16GB
Device Revision Number: 6.0
Global Memory Size: 17066885120
Number of Multiprocessors: 56
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 405 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: Yes
Memory Clock Rate: 715 MHz
Memory Bus Width: 4096 bits
L2 Cache Size: 4194304 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
PGI Compiler Option: -ta=tesla:cc60
Many thanks in advance,
Andrey
