I have a problem with the compilation of my code. I’m a newbie in graphic card program and i don’t understand why there is an error.
Could anyone have a look to explain me where are my mistakes?
Makefile
[codebox]
Build script for project
Add source files here
EXECUTABLE := myVectorAdd
Cuda source files (compiled with cudacc)
CUFILES := myVectorAdd.cu\
cppIntegration.cu\
C/C++ source files (compiled with gcc / c++)
CCFILES := main.cpp \
CFLAGS := -W -Wall -ansi -pedantic
LDFLAGS :=\
NVCCFLAGS += --host-compilation ‘C’
Rules and targets
include ../../common/common.mk[/codebox]
myAddVector.cu
[codebox]include “vectorCst.h”
global void vectorAdd(const float* A,const float* B,float* R){
int index = blockDim.x * blockIdx.x + threadIdx.x;
if(index < vectorSize) R[index] = A[index] + B[index];
}[/codebox]
cppIntegration.cpp
[codebox]include “myVectorAdd.cu”
include <cutil_inline.h>
include <cuda.h>
//premier version
extern “C”
void computeAddOnDevice(const float* V1,const float* V2,float* VR){
vectorAdd<<<blocksPerGrid, threadsPerBlock>>>(V1, V2, VR);
cudaThreadSynchronize();//wait the result before doing anything else
cudaThreadExit();
[/codebox]
main.cpp
[codebox]include
include <stdio.h>
include <string.h>
include <cuda.h>
include “cppIntegration.cu”
include “cutil_inline.h”
using namespace std;
extern “C” void computeAddOnDevice(const float* V1,const float* V2,float* VR);
int main(int argc,char** argv){
cout << "Commencement du programme" << endl;
// shrLog("Starting up CUDA context...\n");
if( cutCheckCmdLineFlag(argc, (const char**)argv, "device") )
cutilDeviceInit(argc, argv);
else
cudaSetDevice( cutGetMaxGflopsDeviceId() );
float* h_A;
float* h_B;
float* h_Result;
float* d_A;
float* d_B;
float* d_Result;
h_A = new float[vectorSize];
h_B = new float[vectorSize];
h_Result = new float[vectorSize];
d_A = new float[vectorSize];
d_B = new float[vectorSize];
d_Result = new float[vectorSize];
memset(h_A,0,vectorSize);
memset(h_B,0,vectorSize);
memset(h_Result,0,vectorSize);
memset(d_A,0,vectorSize);
memset(d_B,0,vectorSize);
memset(d_Result,0,vectorSize);
cudaMemcpy(d_A, h_A, vectorSize, cudaMemcpyHostToDevice);
cudaMemcpy(d_B, h_B, vectorSize, cudaMemcpyHostToDevice);
cudaMemcpy(d_Result, h_Result, vectorSize, cudaMemcpyHostToDevice);
computeAddOnDevice(d_A,d_B,d_Result);
cudaMemcpy(h_Result, d_Result, vectorSize, cudaMemcpyDeviceToHost);
for(int i = 0;i< vectorSize;++i){
cout << d_Result[i] << endl;
//free variables
delete h_A;
delete h_B;
delete h_Result;
cudaFree(d_A);
cudaFree(d_B);
cudaFree(d_Result);
cout << "fin du programme" << endl;
return 0;
}[/codebox]
vectorCst.h
[codebox]#ifndef VECTOR_CST_H
define VECTOR_CST_H
const int vectorSize = 3;
/(vectorSize + threadsPerBlock - 1) / threadsPerBlock/
const unsigned int blocksPerGrid = 4;
/256/
const unsigned int threadsPerBlock = vectorSize / blocksPerGrid + (vectorSize % blocksPerGrid == 0?0:1);
endif[/codebox]
Here is what console says
[codebox]
In file included from cppIntegration.cu:1,
from main.cpp:6:
myVectorAdd.cu:3: error: expected constructor, destructor, or type conversion before ‘void’
In file included from main.cpp:6:
cppIntegration.cu: In function ‘void computeAddOnDevice(const float*, const float*, float*)’:
cppIntegration.cu:8: error: ‘vectorAdd’ was not declared in this scope
cppIntegration.cu:8: error: expected primary-expression before ‘<’ token
cppIntegration.cu:8: error: expected primary-expression before ‘>’ token
cppIntegration.cu:8: warning: left-hand operand of comma has no effect
cppIntegration.cu:8: warning: right-hand operand of comma has no effect
make: *** [obj/x86_64/release/main.cpp.o] Erreur 1
[/codebox]
