I am trying to use CuPP to integrate CUDA into a genome alignment program calls SOAP as a project for school. My system is Ubuntu 64 bits w/ CUDA 2.1. I was very interested in using the STL memory managing capability of CuPP.
I compiled CuPP and all the examples worked out fine.
However, as I am trying to integrate vector_complex into the program, by adding the call function, and the include files.
I get the error:
kernel_vector_complex.cu(12): error: operand of "*" must be a pointer
1 error detected in the compilation of "/tmp/tmpxft_000056ab_00000000-5_kernel_vector_complex.cpp2.i".
make: *** [kernel_vector_complex.o] Error 255
I’ve been trying to figure this out for the last 3 hours and nothing worked.
I used the exact same code which was given in the example.
/usr/local/cuda/bin/nvcc -c kernel_kernel.cu -O3 -I/usr/local/cuda/include -I /media/disk/dinh/cupp/include -o kernel_kernel.o
/usr/include/boost/mpl/aux_/integral_wrapper.hpp:72: error: `&' cannot appear in a constant-expression
/usr/include/boost/mpl/aux_/integral_wrapper.hpp:72: error: template argument 2 is invalid
/usr/include/boost/mpl/aux_/integral_wrapper.hpp:73: error: `&' cannot appear in a constant-expression
/usr/include/boost/mpl/aux_/integral_wrapper.hpp:73: error: template argument 2 is invalid
/usr/include/boost/mpl/size_t_fwd.hpp:23: error: expected unqualified-id before â[â token
/usr/include/boost/mpl/size_t_fwd.hpp:26: error: âmpl_::size_tâ has not been declared
/usr/include/boost/mpl/aux_/integral_wrapper.hpp:42: error: expected unqualified-id before â[â token
In file included from kernel_kernel.cu:17:
/tmp/tmpxft_00006114_00000000-1_kernel_kernel.cudafe1.stub.c:19: error: expected `;' at end of input
/tmp/tmpxft_00006114_00000000-1_kernel_kernel.cudafe1.stub.c:19: error: expected `}' at end of input
make: *** [kernel_kernel.o] Error 255
