When compile the following code with nvfortran,
Program test
implicit none
9001 format("ga00aa : "3x" : "a3"=" 99es14.06)
9002 format("ga00aa : "3x" : "a3"="14x,99es14.06)
9003 format("ga00aa : "3x" : evalue =",es13.05," +",es13.05" i ; evector="es13.05" +"es13.05" i,"es13.05 &
" +"es13.05" i ;")
end Program test
There is such errors:
NVFORTRAN-S-0029-Illegal hexadecimal constant: : (test.F90: 4)
NVFORTRAN-S-0034-Syntax error at or near non-decimal constant 0 (test.F90: 4)
NVFORTRAN-S-0029-Illegal hexadecimal constant: : (test.F90: 5)
NVFORTRAN-S-0034-Syntax error at or near non-decimal constant 0 (test.F90: 5)
NVFORTRAN-S-0029-Illegal hexadecimal constant: :evalue= (test.F90: 6)
NVFORTRAN-S-0034-Syntax error at or near non-decimal constant 0 (test.F90: 6)
0 inform, 0 warnings, 6 severes, 0 fatal for test
However it could be compiled successfully with gfortran. Please, how should I solve it without modifying the code?
