I’d be happy to help you troubleshoot the issue with compiling llamacpp to detect and use the GPU of the Jetson Orin Nano.
Firstly, let’s ensure that your Jetson Orin Nano is properly set up and configured. The Jetson Orin Nano is a production module that requires a carrier board designed or procured for your end product. Have you attached the module to a carrier board and flashed it with the software image you have developed?
Assuming that your Jetson Orin Nano is properly set up, let’s move on to the compilation of llamacpp. The instructions on the llamacpp Github provide guidance on compiling for CUDA, but it’s possible that there are some specific requirements or configurations that need to be met for the Jetson Orin Nano.
Here are a few potential issues that might be causing the “NO GPU IS DETECTED” message:
- CUDA version: The Jetson Orin Nano uses CUDA 11.4, which might be different from the version used in the llamacpp instructions. Ensure that you are using the correct CUDA version and that it is properly installed on your system.
- GPU architecture: The Jetson Orin Nano has a Ampere GPU architecture, which might require specific configurations or flags during compilation. Check the llamacpp documentation to see if there are any specific requirements for Ampere GPUs.
- Device detection: The Jetson Orin Nano might not be properly detected by the llamacpp compilation process. You can try using the
nvcc compiler to detect the GPU and ensure that it is properly recognized.
- Driver version: The Jetson Orin Nano requires a specific driver version to function properly. Ensure that you are using the correct driver version and that it is properly installed on your system.
To troubleshoot the issue, you can try the following:
- Check the CUDA version: Run
nvcc --version to check the CUDA version installed on your system.
- Check the GPU architecture: Run
nvidia-smi to check the GPU architecture and ensure that it is properly detected.
- Check the device detection: Run
nvcc -o detect_gpu detect_gpu.cu to detect the GPU and ensure that it is properly recognized.
- Check the driver version: Run
nvidia-smi to check the driver version and ensure that it is properly installed.
If none of these troubleshooting steps resolve the issue, you can try using the Jetson Container for llamacpp, which is specifically designed for the Jetson platform. However, since you mentioned that you have already tried this approach and it failed, we might need to dig deeper into the issue.
In comparison to other Jetson devices, the Jetson Orin Nano has a unique GPU architecture and requires specific configurations. The Jetson AGX Orin, for example, has a more powerful GPU and might require different configurations or flags during compilation.
If you provide more details about your compilation process and the errors you are encountering, I can try to provide more specific guidance or pointers to help you resolve the issue.
