I have been trying to use openACC on my laptop, MSI GP63 8DR, GTX 1050 ti. I have the following code to compile and I am pretty sure the code is correct since I have tried it on an Online lab where I am taking a course.
The compiler works perfectly for CPU, but when I tried the GPU, the following syntax, it gives the next error.
syntax:
pgcc -fast -ta=tesla:cc60,managed -Minfo=accel -o laplace jacobi.c laplace2d.c && echo “Compilation Successful” && ./laplace
Error:
pgcc-Warning-The -ta=tesla:managed option is not supported for win-64 systems
jacobi.c:
laplace2d.c:
PGC-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Could not find allocated-variable index for symbol (laplace2d.c: 47)
calcNext:
47, Accelerator kernel generated
Generating Tesla code
48, #pragma acc loop gang /* blockIdx.x /
Generating reduction(max:error)
50, #pragma acc loop vector(128) / threadIdx.x */
48, Accelerator restriction: size of the GPU copy of Anew,A is unknown
50, Loop is parallelizable
PGC-F-0704-Compilation aborted due to previous errors. (laplace2d.c)
PGC/x86-64 Windows 18.4-0: compilation aborted
It looks like there is a compatibility issue, well, I don’t know how to fix it without downgrading my OS.
Thank you for reading.
The following is the code I want t compile.
Header ----------------
void initialize(double *restrict A, double *restrict Anew, int m, int n);
double calcNext(double *restrict A, double *restrict Anew, int m, int n);
void swap(double *restrict A, double *restrict Anew, int m, int n);
void deallocate(double *restrict A, double *restrict Anew);
main--------------------------
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <omp.h>
#include “laplace2d.h”
int main(int argc, char** argv)
const int n = 4096;
const int m = 4096;
const int iter_max = 1000;
const double tol = 1.0e-6;
double error = 1.0;
double restrict A = (double)malloc(sizeof(double)nm);
double restrict Anew = (double)malloc(sizeof(double)nm);
initialize(A, Anew, m, n);
printf(“Jacobi relaxation Calculation: %d x %d mesh\n”, n, m);
double st = omp_get_wtime();
int iter = 0;
while ( error > tol && iter < iter_max )
error = calcNext(A, Anew, m, n);
swap(A, Anew, m, n);
if(iter % 100 == 0) printf(“%5d, %0.6f\n”, iter, error);
iter++;
double runtime = omp_get_wtime() - st;
printf(" total: %f s\n", runtime);
deallocate(A, Anew);
return 0;
Function------------------------------------
#include <math.h>
#include <stdlib.h>
#define OFFSET(x, y, m) (((x)*(m)) + (y))
memset(A, 0, n * m * sizeof(double));
memset(Anew, 0, n * m * sizeof(double));
for(int i = 0; i < m; i++){
A _= 1.0;
Anew = 1.0;
double error = 0.0;
#pragma acc parallel loop reduction(max:error)
for( int j = 1; j < n-1; j++)
for( int i = 1; i < m-1; i++ )
Anew[OFFSET(j, i, m)] = 0.25 * ( A[OFFSET(j, i+1, m)] + A[OFFSET(j, i-1, m)]
- A[OFFSET(j-1, i, m)] + A[OFFSET(j+1, i, m)]);
error = fmax( error, fabs(Anew[OFFSET(j, i, m)] - A[OFFSET(j, i , m)]));
return error;
A[OFFSET(j, i, m)] = Anew[OFFSET(j, i, m)];
free(A);
free(Anew);
---------------------------------------------_
