PGI 12.9: PGF90-W-0155-Compiler failed ... Load of NULL symb
I have tried the new 12.9 version of the compiler, for an OpenACC code. I am seeing a new error message (I don’t remember seing this in previous version):
PGF90-W-0155-Compiler failed to translate accelerator region (see -Minfo messages): Load of NULL symbol (test_diag_level.f90: 71)
  1. I have made a reduce test code were I can reproduce the error message (see below)
  2. Is there an option to force the compiler to crash when it can not translate an accelerator region which has an explicit “parallel” or “loop” construct. Indeed in my case the kernel are embeded in a large data region, and there is no point to compute this one loop on the CPU as the data is not valid there at this point.
! test programme OpenACC
module data_field
  implicit none
  real, allocatable :: zdia_2d(:), hk_2d(:), hk1_2d(:), hhl(:,:)
  integer, allocatable :: k_2d(:)
END module data_field
module data_allocation
CONTAINS
  subroutine my_allocation(nvec,nlevel)
    USE data_field, only:  zdia_2d, hk_2d, hk1_2d, hhl,k_2d
    integer :: nvec, nlevel
    allocate(zdia_2d(nvec), hk_2d(nvec), hk1_2d(nvec), hhl(nvec,nlevel),k_2d(nvec))
  end subroutine my_allocation
  subroutine my_deallocation
    deallocate(zdia_2d, hk_2d, hk1_2d, hhl,k_2d)
  end subroutine my_deallocation
end module data_allocation
module computation
  implicit none
contains
SUBROUTINE diag_level_gpu (ipstart, ipend, ke1, zdia_2d, k_2d,      &
                       hk_2d, hk1_2d, hhl)
!GPU version : it is faster to go through the whole data then to preform a
! reduction lcheck logical
   INTEGER, INTENT(IN) :: &
      ipstart,ipend,    & ! start end end indices of horizontal domain
      ke1                 ! vertical dimension of hhl
   REAL, INTENT(IN) :: &
      zdia_2d(:)  !diagnostic height
   INTEGER, INTENT(INOUT) :: &
      k_2d(:)     !index field of the upper level index
                    !to be used of near surface diagnostics
   REAL, INTENT(INOUT) :: &
        hk_2d(:), & ! mid level height above ground belonging to 'k_2d'
        hk1_2d(:)    ! mid level height above ground of the previous layer (below)
   REAL , INTENT(IN)    :: &
      hhl(:,:)    ! height of half levels
   INTEGER :: ip,k
   REAL  :: zhk_2d, zhk1_2d
   INTEGER :: zk_2d
!$acc data present(zdia_2d, k_2d, hk_2d, hk1_2d, hhl )
   !$acc parallel
   !$acc loop gang vector
   DO ip=ipstart,ipend
      DO k=k_2d(ip)-1,1,-1
!!$         IF ( hk_2d(ip)<zdia_2d(ip) ) THEN !diagnostic level is above current layer
!!$            k_2d(ip)=k
!!$            hk1_2d(ip)=hk_2d(ip)
!!$            hk_2d(ip)=(hhl(ip,k)+hhl(ip,k+1))*0.5-hhl(ip,ke1)
!!$          END IF
          !XL: alternative implementation due to issue with PGI 11.9
      zk_2d = k_2d(ip)
      zhk_2d = hk_2d(ip)
      zhk1_2d = hk1_2d(ip)
      IF ( zhk_2d < zdia_2d(ip) ) THEN !diagnostic level is above current layer
         zk_2d=k
         zhk1_2d=zhk_2d
         zhk_2d=(hhl(ip,k)+hhl(ip,k+1))*0.5-hhl(ip,ke1)
      END IF
      hk_2d(ip)=zhk_2d
      hk1_2d(ip)=zhk1_2d
      k_2d(ip) = zk_2d
   END DO
END DO
!$acc end parallel
!$acc end data
END SUBROUTINE diag_level_gpu
end module computation
program main
  USE data_allocation, only:  my_allocation, my_deallocation
  USE computation, only: diag_level_gpu
  implicit none
  integer :: nvec,nlevel, nargs,i,j,k,nt
  character*10 arg
  integer :: nblock
  real :: rt
  INTEGER ::  icountnew, icountold, icountrate, icountmax
  nargs = command_argument_count()
  nlevel=8
  if( nargs == 1 ) then
     call getarg( 1, arg )
     read(arg,'(i)') nvec
  else
     stop('usage ./test n')
  endif
  CALL my_allocation(nvec,nlevel)
!$acc data create(zdia_2d, hk_2d, hk1_2d, hhl,k_2d)
  !init
 !$acc parallel
 !$acc loop
 do i=1,nvec
    zdia_2d(i) = 10.0*(1+1/i)
    hk_2d(i) = 10.5
    hk1_2d(i)= 10.0
    k_2d=2
 end do
 !$acc end parallel
 !$acc parallel
 do k=1,nlevel
 !$acc loop
 do i=1,nvec
   hhl=5.0*(k-1)
 end do
 end do
 !$acc end parallel
 CALL SYSTEM_CLOCK(COUNT=icountold,COUNT_RATE=icountrate,COUNT_MAX=icountmax)
 call diag_level_gpu (1, nvec, nlevel, zdia_2d, k_2d,      &
                       hk_2d, hk1_2d, hhl)
 CALL SYSTEM_CLOCK(COUNT=icountnew)
  !$acc update host(k_2d,hk_2d, hk1_2d)
  !$acc end data
 rt = ( REAL(icountnew) - REAL(icountold) ) / REAL(icountrate)
 print*, 'n=', nvec, sum(hk_2d)/nvec, sum(hk1_2d)/nvec, sum(k_2d)/nvec
  write(*,20) rt*1.0e3
20 format( ' time/step=', f10.5, ' ms' )
  CALL my_deallocation
end program main
pgf90 -Minfo -ta=nvidia -o test_diag_level test_diag_level.f90
diag_level_gpu:
69, Generating present(hhl(:,:))
Regards,
Xavier
Hi Xavier,
Sorry about this. I thought we got all of your issue taken take of in 12.9. Luckily, this one is easy to work around if you use “kernels” instead of “parallel”.
% diff -u test_diag_level.f90 test_diag_level2.f90
--- test_diag_level.f90	2012-09-25 07:47:52.626865000 -0700
+++ test_diag_level2.f90	2012-09-25 08:20:40.678979000 -0700
@@ -65,7 +65,7 @@
-   !$acc parallel
+   !$acc kernels
    DO ip=ipstart,ipend
@@ -92,7 +92,7 @@
    END DO
 END DO
-!$acc end parallel
+!$acc end kernels
 !$acc end data
% pgf90 -c -acc test_diag_level2.f90 -V12.9 -Minfo=accel
diag_level_gpu:
     66, Generating present(hhl(:,:))
         Generating present(hk1_2d(:))
         Generating present(hk_2d(:))
I have submitted TPR#18942 for the error with “parallel”.
Best Regards,
Mat
