The following
module mod
use cudafor
contains
attributes(global) subroutine sub(int,n)
implicit none
integer :: i,n
real :: a
integer(8) :: int(n)
do i=1,n
a=i
int(i)=n*cos(a)
end do
end subroutine sub
end module mod
generates the error message
PGF90-S-0000-Internal compiler error. unsupported operation 105 (compiler.CUF: 13)
0 inform, 0 warnings, 1 severes, 0 fatal for sub
compiler.001.gpu(16): error: expected an expression1 error detected in the compilation of “/tmp/pgnvdhk9cvOu9fZPe.nv0”.
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code 0 (compiler.CUF: 12)
PGF90/x86-64 Linux 11.1-0: compilation aborted
Exit 2
When I replace " integer(8) :: int(n)" by integer :: int(n)" the compilation completes successfully. This is also the case if I replace “cos(a)” by “nint(cos(a))”
What am I doing wrong?
BTW, I compile with “pgfortran -c compiler.CUF -Mcuda=keepgpu” so that I can look at the file called compiler.001.gpu to see what the compiler might be talking about in its obscure message.
