Hello, in NVCC, I’m trying to find out a way to only compile the kernel functions that runs on the device, and not compile or link any host codes, which means that it doesn’t need a host cpp compiler such as g++(for Linux) or cl.exe(for Windows).
I’ve tried the --device-c option when compiling .cu with NVCC, but it turns out that NVCC will always check if a host compiler is available.
The problem is that I want to compile/link the host codes by myself, not automatically by NVCC, so I only want it to compile the device codes to obj that can be run with CUDA runtime or sth else…
Maybe the “–cubin” option?
I don’t believe there is a (provided) way if you are starting with a c++ source file (i.e. a .cu file) and using nvcc based on the compilation trajectory. The host compiler C++ preprecessor is always called first, and you can confirm this by setting --verbose in nvcc compilation. On linux, for example, the first actual tool/command issued is to gcc.
The ptxas tool can be used to compile PTX code to device code (SASS) without invokiing any other tool or compiler.
