Compiling SDK source files
Hy Guys,
I’m pretty new to GPGPU Development but trying to make some GPU benchmarks on different CUDA languages in a scientific framework.
What I’m trying to do now is just to compile the bandwidth.cpp source file in the OpenCl SDK.
When I try to run the Makefile in ~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release> it works fine but as soon as I try to compile bandwidth.cpp with
[font=“Courier New”]user@computer:~/NVIDIA_GPU_Computing_SDK/OpenCL/src/oclBandwidthTest> gcc -I ~/NVIDIA_GPU_Computing_SDK/OpenCL/common/inc/ -L ~/NVIDIA_GPU_Computing_SDK/OpenCL/common/lib -lOpenCL -L /usr/lib64/libOpenCL.so -I ~/NVIDIA_GPU_Computing_SDK/shared/inc/ oclBandwidthTest.cpp
[/font]
I always get in the console
[font=“Courier New”]/tmp/ccT9pYop.o: In function printHelp()': oclBandwidthTest.cpp:(.text+0x19): undefined reference to shrLog’
oclBandwidthTest.cpp:(.text+0x32): undefined reference to shrLog' oclBandwidthTest.cpp:(.text+0x4b): undefined reference to shrLog’
oclBandwidthTest.cpp:(.text+0x64): undefined reference to shrLog' oclBandwidthTest.cpp:(.text+0x7d): undefined reference to shrLog’
/tmp/ccT9pYop.o:oclBandwidthTest.cpp:(.text+0x96): more undefined references to shrLog' follow /tmp/ccT9pYop.o: In function testDeviceToDeviceTransfer(unsigned int)‘:
oclBandwidthTest.cpp:(.text+0x8cd): undefined reference to shrDeltaT' oclBandwidthTest.cpp:(.text+0x954): undefined reference to shrDeltaT’
/tmp/ccT9pYop.o: In function testHostToDeviceTransfer(unsigned int, accessMode, memoryMode)': oclBandwidthTest.cpp:(.text+0xbea): undefined reference to shrDeltaT’
oclBandwidthTest.cpp:(.text+0xdc5): undefined reference to shrDeltaT' /tmp/ccT9pYop.o: In function testDeviceToHostTransfer(unsigned int, accessMode, memoryMode)‘:
oclBandwidthTest.cpp:(.text+0x11c1): undefined reference to shrDeltaT' /tmp/ccT9pYop.o:oclBandwidthTest.cpp:(.text+0x134a): more undefined references to shrDeltaT’ follow
/tmp/ccT9pYop.o: In function testBandwidthShmoo(memcpyKind, printMode, accessMode, memoryMode, int, int)': oclBandwidthTest.cpp:(.text+0x16b1): undefined reference to shrLog’
oclBandwidthTest.cpp:(.text+0x16e7): undefined reference to shrLog' /tmp/ccT9pYop.o: In function runTest(int, char const**)‘:
oclBandwidthTest.cpp:(.text+0x1b4e): undefined reference to shrCheckCmdLineFlag' oclBandwidthTest.cpp:(.text+0x1b79): undefined reference to shrCheckCmdLineFlag’
…[/font]
and I don’t know what to do to get it working.
Maybe you guys see what I forgot, so please help me, I need this to work desperatly.
Thank you so much!
Running OpenSuse 11.2 x64
OpenCL SW Info:
CL_PLATFORM_NAME: NVIDIA
CL_PLATFORM_VERSION: OpenCL 1.0
OpenCL SDK Version: 1.2.0.16
OpenCL Device Info:
of devices supporting OpenCL = 2:
CL_DEVICE_VENDOR: NVIDIA Corporation
CL_DEVICE_NAME: GeForce GTX 280
CL_DRIVER_VERSION: 190.29
try:
cd ~/NVIDIA_GPU_Computing_SDK/sdk/shared
make
then link ~/NVIDIA_GPU_Computing_SDK/sdk/shared/lib/libshrutil_x86_64.a to your gcc command
may be this will help
Thanks for your quick reply, I tried to link the library with
gcc -I ~/NVIDIA_GPU_Computing_SDK/OpenCL/common/inc/ -L ~/NVIDIA_GPU_Computing_SDK/OpenCL/common/lib/liboclUtil.a -L~/NVIDIA_GPU_Computing_SDK/shared/lib/libshrutil.a -L /usr/lib64/libOpenCL.so -I~/NVIDIA_GPU_Computing_SDK/shared/lib/linux oclBandwidthTest.cpp[/font]
but I get the same errors over and over.
Any other suggestions?
Thank you very much!
-L is for directory containing the lib files and not to specify a lib file
-l is to specify a lib file
when using 64bit your libs must all be 64bit. eg OpenCL/common/lib must be lib64
i donot have opencl on linux, but please try my make file and see if it works
1.save this as ‘Makefile’
  1. then run ‘make’
  2. run ./oclBandwidthTest
to clean run make clean
