I am trying to compile the WRF model version 2.1.2 (weather forecast model) with pgf90 version 5.0 on a linux cluster (Redhat Enterprise 3.0). I get several errors, the first one is:
rm -f ESMF_Calendar.o
sed -f ../../arch/standard.sed ESMF_Calendar.F90 > ESMF_Calendar.b
/lib/cpp -C -P -traditional -I../../inc -I. -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DEXP_CORE=0 -DNONSTANDARD_SYSTEM -DF90_STANDALONE -DCONFIG_BUF_LEN=8192 -DMAX_DOMAINS_F=21 -C -P -I. ESMF_Calendar.b > ESMF_Calendar.f
rm -f ESMF_Calendar.b
pgf90 -r4 -i4 -w -byteswapio -Mfree -tp p6 -c ESMF_Calendar.f
PGF90-S-0155-Illegal component initialization in derived type esmf_daysperyear (ESMF_Calendar.f: 136)
PGF90-S-0155-Illegal component initialization in derived type esmf_daysperyear (ESMF_Calendar.f: 137)
PGF90-S-0155-Illegal component initialization in derived type esmf_daysperyear (ESMF_Calendar.f: 138)
PGF90-S-0155-Illegal component initialization in derived type esmf_calendar (ESMF_Calendar.f: 148)
PGF90-S-0155-Illegal component initialization in derived type esmf_calendar (ESMF_Calendar.f: 149)
PGF90-S-0155-Illegal component initialization in derived type esmf_calendar (ESMF_Calendar.f: 150)
PGF90-S-0155-Illegal component initialization in derived type esmf_calendar (ESMF_Calendar.f: 151)
0 inform, 0 warnings, 7 severes, 0 fatal for esmf_calendarmod
0 inform, 0 warnings, 7 severes, 0 fatal for esmf_calendarcreate
0 inform, 0 warnings, 7 severes, 0 fatal for esmf_calendarinitialized
PGF90/any Linux/x86 5.0-2: compilation completed with severe errors
make[3]: [ESMF_Calendar.o] Error 2 (ignored)
Using Intels ifort compiler 9.0 on the same platform seems to work:
/lib/cpp -traditional -I../../inc -I. -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DEXP_CORE=0 -DNONSTANDARD_SYSTEM -DF90_STANDALONE -DCONFIG_BUF_LEN=8
ifort -real_size 32 -O2 -w -FR -cm -I. -Vaxlib -convert big_endian -mp -c ESMF_Calendar.f
rm -f ESMF_Fraction.o
sed -f ../../arch/standard.sed ESMF_Fraction.F90 > ESMF_Fraction.b
Somewhere I found the info that a PGI patch should solve the problem. Has anybody an idea if this is true, where to find the appropriate patch and how to install it?
Thanks,
Alex
