Trying to compile WRF model on an Intel processor, REd Hat Linux machine with pgi 6. Having very limited success (as in, it seems that calls to C routines from fortran code may be an issue here). Here is an excerpt from a post on the WRF forum:
“I am trying to compile WRF 2.1 on a Intel Xeon single processor,
with the latest pgi compilers (6.0), Red Hat Linux 2.6.9-11.ELsmp
(Enterprise release 4, Nahant update 2). netCDF has recently been
installed and compiled with the same compilers with /usr/local/include and
/usr/local/lib as the include and library paths. I cannot compile WRF2.1
em idealized cases (or maybe anything else for that matter - all I’ve
been trying is the ideal cases for now). I was able to compile WRF2.0
cases without any trouble or special massaging of things. Would you
happen to have a configure.wrf file (and any appropriately modified
Makefile, secrets to where to put libraries and links to them, etc e.g.)
that I could go by to successfully compile given the above?”
Here are error messages:
pgf90 -w -byteswapio -Mfree -tp p6 -I. -I…/ioapi_share -c io_int.f
/bin/rm -f module_internal_header_util.o
/bin/rm -f intio_tags.h
/bin/rm -f libwrfio_int.a
ar cr libwrfio_int.a io_int.o
ranlib libwrfio_int.a
if [ -f …/…/frame/pack_utils.o ] ; then
mv diffwrf.F diffwrf.F90 ;
/lib/cpp -C -P -traditional diffwrf.F90 > diffwrf.f ;
pgf90 -w -byteswapio -Mfree -tp p6 -c -I…/ioapi_share
diffwrf.f ;
mv diffwrf.F90 diffwrf.F ;
pgf90 -w -byteswapio -Mfree -tp p6 -o diffwrf
diffwrf.o io_int.o
…/…/frame/module_internal_header_util.o
…/…/frame/module_driver_constants.o
…/…/frame/module_machine.o
…/…/frame/module_wrf_error.o ; fi
… or …
or
-I/mistral/home/michaejs/WRFV2/netcdf_links/include -I…/ioapi_share
diffwrf.f
diffwrf is being built now.
diffwrf.o(.text+0x53c): In function MAIN_': : undefined reference to set_wrf_debug_level_’
wrf_io.o(.text+0x2b2): In function
ext_ncd_support_routines_allochandle_': : undefined reference to wrf_debug_’
wrf_io.o(.text+0x4b9): In function
wrf_io.o(.text+0x6c0): In function
etc etc.
Does anyone have any ideas of what the issue(s) might be and how to correct them?
io_int.o(.text+0x96): In function
module_ext_internal_int_get_fresh_handle_': : undefined reference to wrf_error_fatal_’
io_int.o(.text+0x147): In function
module_ext_internal_init_module_ext_internal_': : undefined reference to wrf_sizeof_integer_’
io_int.o(.text+0x154): In function
`module_ext_internal_init_module_ext_internal_':
