Hello guys! i already installed WRF & PGI 13.9 and it worked until it occurred to me update PGI to 15.10 version :v, this not compile and i back to my 13.9 version but the problem is NOT COMPILE AGAIN :‘’‘’(((
can you help me please :‘’‘’(
my wrf.configure file:
# configure.wrf
# This file was automatically generated by the configure script in the
# top level directory. You may make changes to the settings in this
# file but be aware they will be overwritten each time you run configure.
# Ordinarily, it is necessary to run configure once, when the code is
# first installed.
# To permanently change options, change the settings for your platform
# in the file arch/configure.defaults then rerun configure.
SHELL = /bin/sh
DEVTOP = `pwd`
LIBINCLUDE = .
.SUFFIXES: .F .i .o .f90 .c
#### Get core settings from environment (set in compile script)
#### Note to add a core, this has to be added to.
COREDEFS = -DEM_CORE=$(WRF_EM_CORE) \
-DNMM_CORE=$(WRF_NMM_CORE) -DNMM_MAX_DIM=2600 \
-DCOAMPS_CORE=$(WRF_COAMPS_CORE) \
-DDA_CORE=$(WRF_DA_CORE) \
-DEXP_CORE=$(WRF_EXP_CORE)
#### Single location for defining total number of domains. You need
#### at least 1 + 2*(number of total nests). For example, 1 coarse
#### grid + three fine grids = 1 + 2(3) = 7, so MAX_DOMAINS=7.
MAX_DOMAINS = 21
#### DM buffer length for the configuration flags.
CONFIG_BUF_LEN = 65536
#### Size of bitmasks (in 4byte integers) of stream masks for WRF I/O
MAX_HISTORY = 25
IWORDSIZE = 4
DWORDSIZE = 8
LWORDSIZE = 4
#### The settings in this section are defaults that may be overridden by the
#### architecture-specific settings in the next section.
#### NOTE: Do not modify these default values here. To override these
#### values, make changes after "Architecture specific settings".
#### Native size (in bytes) of Fortran REAL data type on this architecture ####
#### Note: to change real wordsize (for example, to promote REALs from
#### 4-byte to 8-byte), modify the definition of RWORDSIZE in the
#### section following "Architecture specific settings". Do not
#### change NATIVE_RWORDSIZE as is it architecture-specific.
NATIVE_RWORDSIZE = 4
#### Default sed command and script for Fortran source files ####
#SED_FTN = sed -f $(WRF_SRC_ROOT_DIR)/arch/standard.sed
SED_FTN = $(WRF_SRC_ROOT_DIR)/tools/standard.exe
# Hack to work around $(PWD) not changing during OSF1 build.
# $(IO_GRIB_SHARE_DIR) is reset during the OSF1 build only.
IO_GRIB_SHARE_DIR =
#### ESMF switches ####
#### These are set up by Config.pl ####
# switch to use separately installed ESMF library for coupling: 1==true
ESMF_COUPLING = 0
# select dependences on module_utility.o
ESMF_MOD_DEPENDENCE = $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90/module_utility.o
# select -I options for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_INC = -I$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90
# select -I options for separately installed ESMF library, if present
ESMF_MOD_INC = $(ESMF_IO_INC)
# select cpp token for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_DEFS =
# select build target for external/io_esmf vs. external/esmf_time_f90
ESMF_TARGET = esmf_time
# ESMFINCLUDEGOESHERE
#### NETCDF4 pieces
NETCDF4_IO_OPTS = -DUSE_NETCDF4_FEATURES -DWRFIO_NCD_LARGE_FILE_SUPPORT
GPFS =
CURL =
HDF5 =
ZLIB =
DEP_LIB_PATH =
NETCDF4_DEP_LIB = $(DEP_LIB_PATH) $(HDF5) $(ZLIB) $(GPFS) $(CURL)
# NETCDF4INCLUDEGOESHERE
LIBWRFLIB = libwrflib.a
#### Architecture specific settings ####
# Settings for Linux x86_64 ppc64le i486 i586 i686, PGI compiler with pgcc (dmpar)
DESCRIPTION = PGI ($SFC/$SCC)
DMPARALLEL = 1
OMPCPP = # -D_OPENMP
OMP = # -mp -Minfo=mp -Mrecursive
OMPCC = # -mp
SFC = /opt/pgi/linux86-64/13.9/bin/pgf90
SCC = /opt/pgi/linux86-64/13.9/bin/pgcc
CCOMP = /opt/pgi/linux86-64/13.9/bin/pgcc
DM_FC = /opt/pgi/linux86-64/13.9/mpi/mpich/bin/mpif90
DM_CC = /opt/pgi/linux86-64/13.9/mpi/mpich/bin/mpicc -DMPI2_SUPPORT
FC = time $(DM_FC)
CC = $(DM_CC) -DFSEEKO64_OK
LD = $(FC)
RWORDSIZE = $(NATIVE_RWORDSIZE)
PROMOTION = -r$(RWORDSIZE) -i4
ARCH_LOCAL = -DNONSTANDARD_SYSTEM_SUBR -DWRF_USE_CLM
CFLAGS_LOCAL = -w -O3
LDFLAGS_LOCAL =
CPLUSPLUSLIB =
ESMF_LDFLAG = $(CPLUSPLUSLIB)
FCOPTIM = -O3 #-fastsse -Mvect=noaltcode -Msmartalloc -Mprefetch=distance:8 -Mfprelaxed # -Minfo=all =Mneginfo=all
FCREDUCEDOPT = $(FCOPTIM)
FCNOOPT = -O0
FCDEBUG = # -g $(FCNOOPT) # -C -Ktrap=fp -traceback
FORMAT_FIXED = -Mfixed
FORMAT_FREE = -Mfree
FCSUFFIX =
BYTESWAPIO = -byteswapio
FCBASEOPTS_NO_G = -w $(FORMAT_FREE) $(BYTESWAPIO) $(OMP)
FCBASEOPTS = $(FCBASEOPTS_NO_G) $(FCDEBUG)
MODULE_SRCH_FLAG = -module $(WRF_SRC_ROOT_DIR)/main
TRADFLAG = -traditional
CPP = /lib/cpp -P
AR = ar
ARFLAGS = ru
M4 = m4 -B 14000
RANLIB = ranlib
CC_TOOLS = $(SCC)
# POSTAMBLE
FGREP = fgrep -iq
ARCHFLAGS = $(COREDEFS) -DIWORDSIZE=$(IWORDSIZE) -DDWORDSIZE=$(DWORDSIZE) -DRWORDSIZE=$(RWORDSIZE) -DLWORDSIZE=$(LWORDSIZE) \
$(ARCH_LOCAL) \
$(DA_ARCHFLAGS) \
-DDM_PARALLEL \
-DNETCDF \
-DUSE_ALLOCATABLES \
-DGRIB1 \
-DINTIO \
-DLIMIT_ARGS \
-DCONFIG_BUF_LEN=$(CONFIG_BUF_LEN) \
-DMAX_DOMAINS_F=$(MAX_DOMAINS) \
-DMAX_HISTORY=$(MAX_HISTORY) \
-DNMM_NEST=$(WRF_NMM_NEST)
CFLAGS = $(CFLAGS_LOCAL) -DDM_PARALLEL \
-DMAX_HISTORY=$(MAX_HISTORY) -DNMM_CORE=$(WRF_NMM_CORE)
FCFLAGS = $(FCOPTIM) $(FCBASEOPTS)
ESMF_LIB_FLAGS =
# ESMF 5 -- these are defined in esmf.mk, included above
ESMF_IO_LIB = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
ESMF_IO_LIB_EXT = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
INCLUDE_MODULES = $(MODULE_SRCH_FLAG) \
$(ESMF_MOD_INC) $(ESMF_LIB_FLAGS) \
-I$(WRF_SRC_ROOT_DIR)/main \
-I$(WRF_SRC_ROOT_DIR)/external/io_netcdf \
-I$(WRF_SRC_ROOT_DIR)/external/io_int \
-I$(WRF_SRC_ROOT_DIR)/frame \
-I$(WRF_SRC_ROOT_DIR)/share \
-I$(WRF_SRC_ROOT_DIR)/phys \
-I$(WRF_SRC_ROOT_DIR)/chem -I$(WRF_SRC_ROOT_DIR)/inc \
-I$(NETCDFPATH)/include \
REGISTRY = Registry
CC_TOOLS_CFLAGS = -DNMM_CORE=$(WRF_NMM_CORE)
LIB_BUNDLED = \
$(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5/libfftpack.a \
$(WRF_SRC_ROOT_DIR)/external/io_grib1/libio_grib1.a \
$(WRF_SRC_ROOT_DIR)/external/io_grib_share/libio_grib_share.a \
$(WRF_SRC_ROOT_DIR)/external/io_int/libwrfio_int.a \
$(ESMF_IO_LIB) \
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a \
$(WRF_SRC_ROOT_DIR)/frame/module_internal_header_util.o \
$(WRF_SRC_ROOT_DIR)/frame/pack_utils.o
LIB_EXTERNAL = \
-L$(WRF_SRC_ROOT_DIR)/external/io_netcdf -lwrfio_nf -L/opt/wrf/libraries/lib -lnetcdff -lnetcdf
LIB = $(LIB_BUNDLED) $(LIB_EXTERNAL) $(LIB_LOCAL) $(LIB_WRF_HYDRO)
LDFLAGS = $(OMP) $(FCFLAGS) $(LDFLAGS_LOCAL)
ENVCOMPDEFS =
WRF_CHEM = 0
CPPFLAGS = $(ARCHFLAGS) $(ENVCOMPDEFS) -I$(LIBINCLUDE) $(TRADFLAG)
NETCDFPATH = /opt/wrf/libraries
PNETCDFPATH =
bundled: io_only
external: io_only $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a gen_comms_rsllite module_dm_rsllite $(ESMF_TARGET)
io_only: esmf_time wrfio_nf \
wrf_ioapi_includes wrfio_grib_share wrfio_grib1 wrfio_int fftpack
externals: io_only bundled external
gen_comms_serial :
( /bin/rm -f $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c )
module_dm_serial :
( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; cat module_dm_stubs.F >> module_dm.F ; fi )
gen_comms_rsllite :
( if [ ! -e $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ] ; then \
/bin/cp $(WRF_SRC_ROOT_DIR)/tools/gen_comms_warning $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; \
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/gen_comms.c >> $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; fi )
module_dm_rsllite :
( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; \
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/module_dm.F >> module_dm.F ; fi )
wrfio_nf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_netcdf ; \
make $(J) NETCDFPATH="$(NETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
CC="$(SCC)" CFLAGS="$(CFLAGS)" \
FC="$(SFC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_pnf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_pnetcdf ; \
make $(J) NETCDFPATH="$(PNETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP) $(ARCHFLAGS)" \
FC="$(FC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_grib_share :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib_share ; \
make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" archive)
wrfio_grib1 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib1 ; \
wrfio_grib2 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib2 ; \
make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS) " RM="$(RM)" RANLIB="$(RANLIB)" \
CPP="$(CPP)" \
FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
FIXED="$(FORMAT_FIXED)" archive)
wrfio_int :
( cd $(WRF_SRC_ROOT_DIR)/external/io_int ; \
make $(J) CC="$(CC)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(OMP)" FGREP="$(FGREP)" \
TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ARCHFLAGS="$(ARCHFLAGS)" all )
esmf_time :
( cd $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 ; \
make $(J) FC="$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" \
CPP="$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc -I. $(ARCHFLAGS) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
fftpack :
( cd $(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5 ; \
make $(J) FC="$(SFC)" FFLAGS="$(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" AR="$(AR)" \
ARFLAGS="$(ARFLAGS)" CPP="$(CPP)" CPPFLAGS="$(CPPFLAGS)" RM="$(RM)" )
atm_ocn :
( cd $(WRF_SRC_ROOT_DIR)/external/atm_ocn ; \
CPP="$(CPP)" CPPFLAGS="$(CPPFLAGS)" \
FC="$(DM_FC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
FIXED="$(FORMAT_FIXED)" )
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a :
( cd $(WRF_SRC_ROOT_DIR)/external/RSL_LITE ; make $(J) CC="$(CC) $(CFLAGS)" \
FC="$(FC) $(FCFLAGS) $(OMP) $(PROMOTION) $(BYTESWAPIO)" \
CPP="$(CPP) -I. $(ARCHFLAGS) $(OMPCPP) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ;\
$(RANLIB) $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a )
# Macros, these should be generic for all machines
LN = ln -sf
MAKE = make -i -r
RM = rm -f
# These sub-directory builds are identical across all architectures
wrf_ioapi_includes :
( cd $(WRF_SRC_ROOT_DIR)/external/ioapi_share ; \
$(MAKE) NATIVE_RWORDSIZE="$(NATIVE_RWORDSIZE)" RWORDSIZE="$(RWORDSIZE)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_esmf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_esmf ; \
make FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(ESMF_MOD_INC)" \
RANLIB="$(RANLIB)" CPP="$(CPP) $(POUND_DEF) " AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
# There is probably no reason to modify these rules
.F.i:
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.F > $@
mv $*.i $(DEVTOP)/pick/$*.f90
cp $*.F $(DEVTOP)/pick
.F.o:
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.F > $*.bb
$(SED_FTN) $*.bb | $(CPP) $(TRADFLAG) > $*.f90
$(RM) $*.b $*.bb
@ if echo $(ARCHFLAGS) | $(FGREP) 'DVAR4D'; then \
echo COMPILING $*.F for 4DVAR ; \
$(WRF_SRC_ROOT_DIR)/var/build/da_name_space.pl $*.f90 > $*.f90.tmp ; \
mv $*.f90.tmp $*.f90 ; \
fi
$(FC) -o $@ -c $(FCFLAGS) $(OMP) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $*.f90
.F.f90:
$(RM) $@
$(SED_FTN) $*.F > $*.b
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.b > $@
$(RM) $*.b
.f90.o:
$(RM) $@
$(FC) -o $@ -c $(FCFLAGS) $(PROMOTION) $(FCSUFFIX) $*.f90
setfeenv.o : setfeenv.c
$(RM) $@
$(CCOMP) -o $@ -c $(CFLAGS) $(OMPCC) $*.c
.c.o:
$(RM) $@
$(CC) -o $@ -c $(CFLAGS) $*.c
# A little more adventurous. Allow full opt on
# mediation_integrate.o \
# shift_domain_em.o \
# solve_em.o <-- gets a little kick from SOLVE_EM_SPECIAL too, if defined
# mediation_feedback_domain.o : mediation_feedback_domain.F
# mediation_force_domain.o : mediation_force_domain.F
# mediation_interp_domain.o : mediation_interp_domain.F
# compile these without high optimization to speed compile
mediation_integrate.o : mediation_integrate.F
track_driver.o : track_driver.F
convert_nmm.o : convert_nmm.F
init_modules_em.o : init_modules_em.F
input_wrf.o : input_wrf.F
module_io.o : module_io.F
module_comm_dm.o : module_comm_dm.F
module_comm_dm_0.o : module_comm_dm_0.F
module_comm_dm_1.o : module_comm_dm_1.F
module_comm_dm_2.o : module_comm_dm_2.F
module_comm_dm_3.o : module_comm_dm_3.F
module_comm_nesting_dm.o : module_comm_nesting_dm.F
module_configure.o : module_configure.F
module_dm.o : module_dm.F
module_domain.o : module_domain.F
module_domain_type.o : module_domain_type.F
module_alloc_space_0.o : module_alloc_space_0.F
module_alloc_space_1.o : module_alloc_space_1.F
module_alloc_space_2.o : module_alloc_space_2.F
module_alloc_space_3.o : module_alloc_space_3.F
module_alloc_space_4.o : module_alloc_space_4.F
module_alloc_space_5.o : module_alloc_space_5.F
module_alloc_space_6.o : module_alloc_space_6.F
module_alloc_space_7.o : module_alloc_space_7.F
module_alloc_space_8.o : module_alloc_space_8.F
module_alloc_space_9.o : module_alloc_space_9.F
module_tiles.o : module_tiles.F
module_fddaobs_rtfdda.o : module_fddaobs_rtfdda.F
module_initialize.o : module_initialize.F
module_physics_init.o : module_physics_init.F
module_initialize_b_wave.o : module_initialize_b_wave.F
module_initialize_hill2d_x.o : module_initialize_hill2d_x.F
module_initialize_quarter_ss.o : module_initialize_quarter_ss.F
module_initialize_real.o : module_initialize_real.F
module_initialize_real.o: module_initialize_real.F
module_initialize_squall2d_x.o : module_initialize_squall2d_x.F
module_initialize_squall2d_y.o : module_initialize_squall2d_y.F
module_initialize_scm_xy.o : module_initialize_scm_xy.F
module_integrate.o : module_integrate.F
module_io_mm5.o : module_io_mm5.F
module_io_wrf.o : module_io_wrf.F
module_si_io.o : module_si_io.F
module_wps_io_arw.o : module_wps_io_arw.F
module_state_description.o : module_state_description.F
output_wrf.o : output_wrf.F
solve_interface.o : solve_interface.F
start_domain.o : start_domain.F
start_em.o : start_em.F
wrf_bdyin.o : wrf_bdyin.F
wrf_bdyout.o : wrf_bdyout.F
wrf_ext_read_field.o : wrf_ext_read_field.F
wrf_ext_write_field.o : wrf_ext_write_field.F
wrf_fddaobs_in.o : wrf_fddaobs_in.F
wrf_histin.o : wrf_histin.F
wrf_histout.o : wrf_histout.F
wrf_inputin.o : wrf_inputin.F
wrf_inputout.o : wrf_inputout.F
wrf_restartin.o : wrf_restartin.F
wrf_restartout.o : wrf_restartout.F
wrf_tsin.o : wrf_tsin.F
nl_get_0_routines.o : nl_get_0_routines.F
nl_get_1_routines.o : nl_get_1_routines.F
nl_set_0_routines.o : nl_set_0_routines.F
nl_set_1_routines.o : nl_set_1_routines.F
track_driver.o \
convert_nmm.o \
init_modules_em.o \
module_dm.o \
module_fddaobs_rtfdda.o \
module_initialize.o \
module_initialize_b_wave.o \
module_initialize_hill2d_x.o \
module_initialize_quarter_ss.o \
module_initialize_real.o \
module_initialize_squall2d_x.o \
module_initialize_squall2d_y.o \
module_initialize_scm_xy.o \
module_integrate.o \
module_io_mm5.o \
module_io_wrf.o \
module_si_io.o \
module_wps_io_arw.o \
module_tiles.o \
output_wrf.o \
solve_interface.o \
start_domain.o \
start_em.o \
wrf_fddaobs_in.o \
wrf_tsin.o :
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.b > $*.f90
$(RM) $*.b
fi
if $(FGREP) '!$$OMP' $*.f90 ; then \
if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITH OMP ; fi ; \
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
else \
if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITHOUT OMP ; fi ; \
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
fi
#solve_em.o :
# $(RM) $@
# $(SED_FTN) $*.F > $*.b
# $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.b > $*.f90
# $(RM) $*.b
# $(FC) -o $@ -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $(SOLVE_EM_SPECIAL) $(OMP) $*.f90
module_sf_ruclsm.o : module_sf_ruclsm.F
$(RM) $@
$(RM) $*.b
echo COMPILING $*.F WITH OMP ; \
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
else \
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
fi
# compile without OMP
input_wrf.o \
module_domain.o \
module_domain_type.o \
module_physics_init.o \
module_io.o \
wrf_bdyin.o \
wrf_bdyout.o \
wrf_ext_read_field.o \
wrf_ext_write_field.o \
wrf_histin.o \
wrf_histout.o \
wrf_inputin.o \
wrf_inputout.o \
wrf_restartin.o \
wrf_restartout.o \
module_state_description.o \
module_alloc_space.o \
module_alloc_space_0.o \
module_alloc_space_1.o \
module_alloc_space_2.o \
module_alloc_space_3.o \
module_alloc_space_4.o \
module_alloc_space_5.o \
module_alloc_space_6.o \
module_alloc_space_7.o \
module_alloc_space_8.o \
module_alloc_space_9.o \
module_comm_dm.o \
module_comm_dm_0.o \
module_comm_dm_1.o \
module_comm_dm_2.o \
module_comm_dm_3.o \
module_comm_nesting_dm.o \
$(RM) $@
fi
$(RM) $*.b $*.bb
$(FC) -c $(PROMOTION) $(FCSUFFIX) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $*.f90
the error during compilation
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:73: undefined reference to `MPI_Comm_f2c'
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:78: undefined reference to `ompi_mpi_int'
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:99: undefined reference to `ompi_mpi_comm_world'
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:112: undefined reference to `ompi_mpi_char'
libwrflib.a(collect_on_comm.o): In function `dst_on_comm':
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:157: undefined reference to `MPI_Comm_f2c'
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:162: undefined reference to `ompi_mpi_int'
/root/Build_WRF/WRFV3/frame/./collect_on_comm.c:183: undefined reference to `ompi_mpi_char'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_in_place__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Win_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_unweighted'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_STATUS_IGNORE'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_ARGV_NULL'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_datatype_match_size'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Errhandler_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_argvs_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_param_check'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_finalized'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_argv_null__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_bottom'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_fortran_multiple_argvs_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_UNWEIGHTED'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_errhandler_create'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_registered_datareps'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Group_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_bottom__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_errcode_intern_lastused'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_datatype_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_file_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_CONVERSION_FN_NULL'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_IN_PLACE'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Message_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_errhandler_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_errcodes_ignore__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_in_place'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_fortran_string_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_set_fortran_mpi2'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_create_keyval_aint'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_set_fortran_mpi1'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Info_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_ERRCODES_IGNORE'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_request_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Comm_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_status_empty'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Win_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_status_ignore'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_create_keyval_fint'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_BOTTOM'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_statuses_ignore__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_fortran_argv_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Errhandler_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_unweighted__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_statuses_ignore'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_ARGVS_NULL'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_weights_empty'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_get_fortran_mpi2'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_initialized'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Info_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_attr_get_fortran_mpi1'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_conversion_fn_null__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_errhandler_invoke'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Type_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Op_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Request_f2c'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_WEIGHTS_EMPTY'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_errcodes_ignore'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_errcodes_intern'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Group_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_conversion_fn_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_FORTRAN_STATUSES_IGNORE'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Op_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_status_ignore__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_fortran_string_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_argv_null'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `ompi_mpi_errors_are_fatal_comm_handler'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_weights_empty__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `mpi_fortran_argvs_null__'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Type_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Request_c2f'
/opt/pgi/linux86-64/13.9/mpi/mpich/lib/libmpi_mpifh.so: undefined reference to `MPI_Message_c2f'
0.23user 0.08system 0:00.32elapsed 98%CPU (0avgtext+0avgdata 391152maxresident)k
0inputs+84200outputs (0major+25224minor)pagefaults 0swaps
make[1]: [em_wrf] Error 2 (ignored)
WRF 3.7.1
PGI 13.9
Openmpi 1.8.8
