Hello, I have installed PREP-CHEM-SRC-1.5 and WRFV3.9 with PGI compilers with the options described in the following files:
PREP-CHEM-SRC-1.5 compilation options: include.mk.pgi.wrf
# include.mk.pgi.wrf
# Define make (gnu make works best).
MAKE=/usr/bin/make
# Activate appropriate parts below, comment out others.
# NCAR Graphics.
# If you are using a standard installation of NCAR Graphics, set:
# LOADER=ncargf90
# in the machine-dependent sections below
#LIBNCARG=
# If you are using the NCAR dummy libraries...
NCARG_DIR=$(BASE)
#LIBNCARG=-L$(NCARG_DIR) -lncarg-$(UTILS_VERSION) -lncarg_c-$(UTILS_VERSION) \
# -lncarg_gks-$(UTILS_VERSION)
LIBNCARG=$(BASE)/libncarg-$(UTILS_VERSION)-$(OPT).a
# If you are using a real distribution of NCAR Graphics...
#NCARG_DIR=/usr/local/ncarg-4.3.0/lib
#LIBNCARG=-L$(NCARG_DIR) -lncarg -lncarg_gks -lncarg_c -L/usr/X11R6/lib -lX11 -ldl
# NETCDF libraries
NETCDF=/home/ryzen/netcdf
NETCDF_INC=-I$(NETCDF)/include
NETCDF_LIBS=-L$(NETCDF)/lib -lnetcdf -lnetcdff
# HDF libraries
HDF5=/home/ryzen/hdf5
HDF5_INC=-I$(HDF5)/include
HDF5_LIB=-L$(HDF5)/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ldl -L/home/ryzen/zlib/lib -lz
# Machine-dependent options.
#----------------- LINUX Portland Group pgf77/gcc ---------------
CMACH=PC_LINUX1
F_COMP=/opt/pgi/linux86-64/16.5/bin/pgf90
C_COMP=/opt/pgi/linux86-64/16.5/bin/pgcc
LOADER=/opt/pgi/linux86-64/16.5/bin/pgf90
C_LOADER=/opt/pgi/linux86-64/16.5/bin/pgcc
LIBS=
MOD_EXT=mod
F_OPTS= -Mpreprocess -D$(CHEM) -Mbyteswapio -Mbounds -traceback
C_OPTS=
LOADER_OPTS= -Mbounds -traceback
# If compiling for a single-CPU platform only (without MPI):
PAR_LIBS=
PAR_DEFS=
# For IBM,HP,SGI,ALPHA use these:
ARCHIVE=ar rs
# For NEC SX-6
#ARCHIVE=sxar rs
# For SUN,CONVEX
#ARCHIVE=ar r'
WRFV3-9 compilation options: configure.wrf
# configure.wrf
# Original configure options used:
# ./configure
# Compiler choice: 54
# Nesting option: 1
# This file was automatically generated by the configure script in the
# top level directory. You may make changes to the settings in this
# file but be aware they will be overwritten each time you run configure.
# Ordinarily, it is necessary to run configure once, when the code is
# first installed.
# To permanently change options, change the settings for your platform
# in the file arch/configure_new.defaults then rerun configure.
SHELL = /bin/sh
DEVTOP = `pwd`
LIBINCLUDE = .
.SUFFIXES: .F .i .o .f90 .c
#### Get core settings from environment (set in compile script)
#### Note to add a core, this has to be added to.
COREDEFS = -DEM_CORE=$(WRF_EM_CORE) \
-DNMM_CORE=$(WRF_NMM_CORE) -DNMM_MAX_DIM=2600 \
-DCOAMPS_CORE=$(WRF_COAMPS_CORE) \
-DDA_CORE=$(WRF_DA_CORE) \
-DEXP_CORE=$(WRF_EXP_CORE)
#### Single location for defining total number of domains. You need
#### at least 1 + 2*(number of total nests). For example, 1 coarse
#### grid + three fine grids = 1 + 2(3) = 7, so MAX_DOMAINS=7.
MAX_DOMAINS = 21
#### DM buffer length for the configuration flags.
CONFIG_BUF_LEN = 65536
#### Size of bitmasks (in 4byte integers) of stream masks for WRF I/O
MAX_HISTORY = 25
IWORDSIZE = 4
DWORDSIZE = 8
LWORDSIZE = 4
#### The settings in this section are defaults that may be overridden by the
#### architecture-specific settings in the next section.
#### NOTE: Do not modify these default values here. To override these
#### values, make changes after "Architecture specific settings".
#### Native size (in bytes) of Fortran REAL data type on this architecture ####
#### Note: to change real wordsize (for example, to promote REALs from
#### 4-byte to 8-byte), modify the definition of RWORDSIZE in the
#### section following "Architecture specific settings". Do not
#### change NATIVE_RWORDSIZE as is it architecture-specific.
NATIVE_RWORDSIZE = 4
#### Default sed command and script for Fortran source files ####
#SED_FTN = sed -f $(WRF_SRC_ROOT_DIR)/arch/standard.sed
SED_FTN = $(WRF_SRC_ROOT_DIR)/tools/standard.exe
# Hack to work around $(PWD) not changing during OSF1 build.
# $(IO_GRIB_SHARE_DIR) is reset during the OSF1 build only.
IO_GRIB_SHARE_DIR =
#### ESMF switches ####
#### These are set up by Config.pl ####
# switch to use separately installed ESMF library for coupling: 1==true
ESMF_COUPLING = 0
# select dependences on module_utility.o
ESMF_MOD_DEPENDENCE = $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90/module_utility.o
# select -I options for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_INC = -I$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90
# select -I options for separately installed ESMF library, if present
ESMF_MOD_INC = $(ESMF_IO_INC)
# select cpp token for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_DEFS =
# select build target for external/io_esmf vs. external/esmf_time_f90
ESMF_TARGET = esmf_time
# ESMFINCLUDEGOESHERE
#### NETCDF4 pieces
NETCDF4_IO_OPTS = -DUSE_NETCDF4_FEATURES -DWRFIO_NCD_LARGE_FILE_SUPPORT
GPFS =
CURL =
HDF5 =
ZLIB =
DEP_LIB_PATH =
NETCDF4_DEP_LIB = $(DEP_LIB_PATH) $(HDF5) $(ZLIB) $(GPFS) $(CURL)
# NETCDF4INCLUDEGOESHERE
LIBWRFLIB = libwrflib.a
#### Architecture specific settings ####
# Settings for Linux x86_64 ppc64le i486 i586 i686, PGI compiler with pgcc (dmpar)
DESCRIPTION = PGI ($SFC/$SCC)
DMPARALLEL = 1
OMPCPP = # -D_OPENMP
OMP = # -mp -Minfo=mp -Mrecursive
OMPCC = # -mp
SFC = pgf90
SCC = pgcc
CCOMP = pgcc
DM_FC = mpif90
DM_CC = mpicc -DMPI2_SUPPORT
FC = time $(DM_FC)
CC = $(DM_CC) -DFSEEKO64_OK
LD = $(FC)
RWORDSIZE = $(NATIVE_RWORDSIZE)
PROMOTION = -r$(RWORDSIZE) -i4
ARCH_LOCAL = -DNONSTANDARD_SYSTEM_SUBR -DWRF_USE_CLM
CFLAGS_LOCAL = -w -O3
LDFLAGS_LOCAL =
CPLUSPLUSLIB =
ESMF_LDFLAG = $(CPLUSPLUSLIB)
FCOPTIM = -O3 #-fastsse -Mvect=noaltcode -Msmartalloc -Mprefetch=distance:8 -Mfprelaxed # -Minfo=all =Mneginfo=all
FCREDUCEDOPT = $(FCOPTIM)
FCNOOPT = -O0
FCDEBUG = # -g $(FCNOOPT) # -C -Ktrap=fp -traceback
FORMAT_FIXED = -Mfixed
FORMAT_FREE = -Mfree
FCSUFFIX =
BYTESWAPIO = -byteswapio
FCBASEOPTS_NO_G = -w $(FORMAT_FREE) $(BYTESWAPIO) $(OMP)
FCBASEOPTS = $(FCBASEOPTS_NO_G) $(FCDEBUG)
MODULE_SRCH_FLAG = -module $(WRF_SRC_ROOT_DIR)/main
TRADFLAG = -traditional-cpp
CPP = /lib/cpp -P -nostdinc
AR = ar
ARFLAGS = ru
M4 = m4 -B 14000
RANLIB = ranlib
RLFLAGS =
CC_TOOLS = $(SCC)
# POSTAMBLE
FGREP = fgrep -iq
ARCHFLAGS = $(COREDEFS) -DIWORDSIZE=$(IWORDSIZE) -DDWORDSIZE=$(DWORDSIZE) -DRWORDSIZE=$(RWORDSIZE) -DLWORDSIZE=$(LWORDSIZE) \
$(ARCH_LOCAL) \
$(DA_ARCHFLAGS) \
-DDM_PARALLEL \
-DNETCDF \
-DHDF5 \
-DUSE_ALLOCATABLES \
-DGRIB1 \
-DINTIO \
-DKEEP_INT_AROUND \
-DLIMIT_ARGS \
-DCONFIG_BUF_LEN=$(CONFIG_BUF_LEN) \
-DMAX_DOMAINS_F=$(MAX_DOMAINS) \
-DMAX_HISTORY=$(MAX_HISTORY) \
-DNMM_NEST=$(WRF_NMM_NEST)
CFLAGS = $(CFLAGS_LOCAL) -DDM_PARALLEL \
-DMAX_HISTORY=$(MAX_HISTORY) -DNMM_CORE=$(WRF_NMM_CORE)
FCFLAGS = $(FCOPTIM) $(FCBASEOPTS)
ESMF_LIB_FLAGS =
# ESMF 5 -- these are defined in esmf.mk, included above
ESMF_IO_LIB = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
ESMF_IO_LIB_EXT = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
INCLUDE_MODULES = $(MODULE_SRCH_FLAG) \
$(ESMF_MOD_INC) $(ESMF_LIB_FLAGS) \
-I$(WRF_SRC_ROOT_DIR)/main \
-I$(WRF_SRC_ROOT_DIR)/external/io_netcdf \
-I$(WRF_SRC_ROOT_DIR)/external/io_int \
-I$(WRF_SRC_ROOT_DIR)/frame \
-I$(WRF_SRC_ROOT_DIR)/share \
-I$(WRF_SRC_ROOT_DIR)/phys \
-I$(WRF_SRC_ROOT_DIR)/chem -I$(WRF_SRC_ROOT_DIR)/inc \
-I$(NETCDFPATH)/include \
REGISTRY = Registry
CC_TOOLS_CFLAGS = -DNMM_CORE=$(WRF_NMM_CORE)
LIB_BUNDLED = \
$(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5/libfftpack.a \
$(WRF_SRC_ROOT_DIR)/external/io_grib1/libio_grib1.a \
$(WRF_SRC_ROOT_DIR)/external/io_grib_share/libio_grib_share.a \
$(WRF_SRC_ROOT_DIR)/external/io_int/libwrfio_int.a \
$(ESMF_IO_LIB) \
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a \
$(WRF_SRC_ROOT_DIR)/frame/module_internal_header_util.o \
$(WRF_SRC_ROOT_DIR)/frame/pack_utils.o
LIB_EXTERNAL = \
-L$(WRF_SRC_ROOT_DIR)/external/io_netcdf -lwrfio_nf -L/home/ryzen/netcdf/lib -lnetcdff -lnetcdf -L/home/ryzen/hdf5/lib -lhdf5_fortran -lhdf5 -lm -lz
LIB = $(LIB_BUNDLED) $(LIB_EXTERNAL) $(LIB_LOCAL) $(LIB_WRF_HYDRO)
LDFLAGS = $(OMP) $(FCFLAGS) $(LDFLAGS_LOCAL)
ENVCOMPDEFS = -DWRF_CHEM -DBUILD_CHEM=1
WRF_CHEM = 1
CPPFLAGS = $(ARCHFLAGS) $(ENVCOMPDEFS) -I$(LIBINCLUDE) $(TRADFLAG)
NETCDFPATH = /home/ryzen/netcdf
HDF5PATH = /home/ryzen/hdf5
WRFPLUSPATH =
RTTOVPATH =
PNETCDFPATH =
bundled: io_only
external: io_only $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a gen_comms_rsllite module_dm_rsllite $(ESMF_TARGET)
io_only: esmf_time wrfio_nf \
wrf_ioapi_includes wrfio_grib_share wrfio_grib1 wrfio_int fftpack
externals: io_only bundled external
gen_comms_serial :
( /bin/rm -f $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c )
module_dm_serial :
( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; cat module_dm_stubs.F >> module_dm.F ; fi )
gen_comms_rsllite :
( if [ ! -e $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ] ; then \
/bin/cp $(WRF_SRC_ROOT_DIR)/tools/gen_comms_warning $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; \
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/gen_comms.c >> $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; fi )
module_dm_rsllite :
( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; \
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/module_dm.F >> module_dm.F ; fi )
wrfio_nf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_netcdf ; \
make $(J) NETCDFPATH="$(NETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
CC="$(SCC)" CFLAGS="$(CFLAGS)" \
FC="$(SFC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_pnf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_pnetcdf ; \
make $(J) NETCDFPATH="$(PNETCDFPATH)" RANLIB="$(RANLIB)" CPP="$(CPP) $(ARCHFLAGS)" \
FC="$(FC) $(PROMOTION) $(OMP) $(FCFLAGS)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_grib_share :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib_share ; \
make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" archive)
wrfio_grib1 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib1 ; \
wrfio_grib2 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib2 ; \
make $(J) CC="$(SCC)" CFLAGS="$(CFLAGS) " RM="$(RM)" RANLIB="$(RANLIB)" \
CPP="$(CPP)" \
FC="$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
FIXED="$(FORMAT_FIXED)" archive)
wrfio_int :
( cd $(WRF_SRC_ROOT_DIR)/external/io_int ; \
make $(J) CC="$(CC)" CFLAGS_LOCAL="$(CFLAGS_LOCAL)" RM="$(RM)" RANLIB="$(RANLIB)" CPP="$(CPP)" \
FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(OMP)" FGREP="$(FGREP)" \
TRADFLAG="$(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ARCHFLAGS="$(ARCHFLAGS)" all )
esmf_time :
( cd $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 ; \
make $(J) FC="$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" \
CPP="$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc -I. $(ARCHFLAGS) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
fftpack :
( cd $(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5 ; \
make $(J) FC="$(SFC)" FFLAGS="$(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)" RANLIB="$(RANLIB)" AR="$(AR)" \
ARFLAGS="$(ARFLAGS)" CPP="$(CPP)" CPPFLAGS="$(CPPFLAGS)" RM="$(RM)" )
atm_ocn :
( cd $(WRF_SRC_ROOT_DIR)/external/atm_ocn ; \
CPP="$(CPP)" CPPFLAGS="$(CPPFLAGS)" \
FC="$(DM_FC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)" TRADFLAG="-traditional" AR="$(AR)" ARFLAGS="$(ARFLAGS)" \
FIXED="$(FORMAT_FIXED)" )
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a :
( cd $(WRF_SRC_ROOT_DIR)/external/RSL_LITE ; make $(J) CC="$(CC) $(CFLAGS)" \
FC="$(FC) $(FCFLAGS) $(OMP) $(PROMOTION) $(BYTESWAPIO)" \
CPP="$(CPP) -I. $(ARCHFLAGS) $(OMPCPP) $(TRADFLAG)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" ;\
$(RANLIB) $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a )
# Macros, these should be generic for all machines
LN = ln -sf
MAKE = make -i -r
RM = rm -f
# These sub-directory builds are identical across all architectures
wrf_ioapi_includes :
( cd $(WRF_SRC_ROOT_DIR)/external/ioapi_share ; \
$(MAKE) NATIVE_RWORDSIZE="$(NATIVE_RWORDSIZE)" RWORDSIZE="$(RWORDSIZE)" AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
wrfio_esmf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_esmf ; \
make FC="$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(ESMF_MOD_INC)" \
RANLIB="$(RANLIB)" CPP="$(CPP) $(POUND_DEF) " AR="$(AR)" ARFLAGS="$(ARFLAGS)" )
# There is probably no reason to modify these rules
.F.i:
$(RM) $@
sed -e "s/grid%mu/gridmu/g" -e "s/grid%Mu/gridMu/g" -e "s/^\!.*'.*//" -e "s/^ *\!.*'.*//" $*.F > $*.G
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.G > $*.H
sed -e "s/gridmu/grid%mu/g" -e "s/gridMu/grid%Mu/g" $*.H > $*.i
mv $*.i $(DEVTOP)/pick/$*.f90
cp $*.F $(DEVTOP)/pick
.F.o:
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.G > $*.H
sed -e "s/gridmu/grid%mu/g" -e "s/gridMu/grid%Mu/g" $*.H > $*.bb
$(SED_FTN) $*.bb | $(CPP) $(TRADFLAG) > $*.f90
$(RM) $*.G $*.H $*.bb
@ if echo $(ARCHFLAGS) | $(FGREP) 'DVAR4D'; then \
echo COMPILING $*.F for 4DVAR ; \
$(WRF_SRC_ROOT_DIR)/var/build/da_name_space.pl $*.f90 > $*.f90.tmp ; \
mv $*.f90.tmp $*.f90 ; \
fi
$(FC) -o $@ -c $(FCFLAGS) $(OMP) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $*.f90
.F.f90:
$(RM) $@
$(SED_FTN) $*.G > $*.H
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.H > $*.I
sed -e "s/gridmu/grid%mu/g" -e "s/gridMu/grid%Mu/g" $*.I > $@
$(RM) $*.G $*.H $*.I
.f90.o:
$(RM) $@
$(FC) -o $@ -c $(FCFLAGS) $(PROMOTION) $(FCSUFFIX) $*.f90
setfeenv.o : setfeenv.c
$(RM) $@
$(CCOMP) -o $@ -c $(CFLAGS) $(OMPCC) $*.c
.c.o:
$(RM) $@
$(CC) -o $@ -c $(CFLAGS) $*.c
# A little more adventurous. Allow full opt on
# mediation_integrate.o \
# shift_domain_em.o \
# solve_em.o <-- gets a little kick from SOLVE_EM_SPECIAL too, if defined
# mediation_feedback_domain.o : mediation_feedback_domain.F
# mediation_force_domain.o : mediation_force_domain.F
# mediation_interp_domain.o : mediation_interp_domain.F
# compile these without high optimization to speed compile
track_driver.o : track_driver.F
convert_nmm.o : convert_nmm.F
init_modules_em.o : init_modules_em.F
input_wrf.o : input_wrf.F
module_io.o : module_io.F
module_comm_dm.o : module_comm_dm.F
module_comm_dm_0.o : module_comm_dm_0.F
module_comm_dm_1.o : module_comm_dm_1.F
module_comm_dm_2.o : module_comm_dm_2.F
module_comm_dm_3.o : module_comm_dm_3.F
module_comm_nesting_dm.o : module_comm_nesting_dm.F
module_configure.o : module_configure.F
module_domain.o : module_domain.F
module_domain_type.o : module_domain_type.F
module_alloc_space_0.o : module_alloc_space_0.F
module_alloc_space_1.o : module_alloc_space_1.F
module_alloc_space_2.o : module_alloc_space_2.F
module_alloc_space_3.o : module_alloc_space_3.F
module_alloc_space_4.o : module_alloc_space_4.F
module_alloc_space_5.o : module_alloc_space_5.F
module_alloc_space_6.o : module_alloc_space_6.F
module_alloc_space_7.o : module_alloc_space_7.F
module_alloc_space_8.o : module_alloc_space_8.F
module_alloc_space_9.o : module_alloc_space_9.F
module_tiles.o : module_tiles.F
module_initialize.o : module_initialize.F
module_physics_init.o : module_physics_init.F
module_initialize_squall2d_x.o : module_initialize_squall2d_x.F
module_initialize_squall2d_y.o : module_initialize_squall2d_y.F
module_initialize_scm_xy.o : module_initialize_scm_xy.F
module_integrate.o : module_integrate.F
module_io_mm5.o : module_io_mm5.F
module_io_wrf.o : module_io_wrf.F
module_si_io.o : module_si_io.F
module_wps_io_arw.o : module_wps_io_arw.F
module_state_description.o : module_state_description.F
output_wrf.o : output_wrf.F
solve_interface.o : solve_interface.F
start_domain.o : start_domain.F
wrf_bdyin.o : wrf_bdyin.F
wrf_bdyout.o : wrf_bdyout.F
wrf_ext_read_field.o : wrf_ext_read_field.F
wrf_ext_write_field.o : wrf_ext_write_field.F
wrf_fddaobs_in.o : wrf_fddaobs_in.F
wrf_histin.o : wrf_histin.F
wrf_histout.o : wrf_histout.F
wrf_inputin.o : wrf_inputin.F
wrf_inputout.o : wrf_inputout.F
wrf_restartin.o : wrf_restartin.F
wrf_restartout.o : wrf_restartout.F
wrf_tsin.o : wrf_tsin.F
nl_get_0_routines.o : nl_get_0_routines.F
nl_get_1_routines.o : nl_get_1_routines.F
nl_set_0_routines.o : nl_set_0_routines.F
nl_set_1_routines.o : nl_set_1_routines.F
track_driver.o \
convert_nmm.o \
init_modules_em.o \
module_initialize.o \
module_initialize_squall2d_x.o \
module_initialize_squall2d_y.o \
module_initialize_scm_xy.o \
module_integrate.o \
module_io_mm5.o \
module_io_wrf.o \
module_si_io.o \
module_wps_io_arw.o \
module_tiles.o \
output_wrf.o \
solve_interface.o \
start_domain.o \
wrf_fddaobs_in.o \
wrf_tsin.o :
$(RM) $@
$(SED_FTN) $*.F > $*.b
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.b > $*.f90
$(RM) $*.b
fi
if $(FGREP) '!$$OMP' $*.f90 ; then \
if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITH OMP ; fi ; \
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
else \
if [ -n "$(OMP)" ] ; then echo COMPILING $*.F WITHOUT OMP ; fi ; \
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
fi
#solve_em.o :
# $(RM) $@
# $(SED_FTN) $*.F > $*.b
# $(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $*.b > $*.f90
# $(RM) $*.b
# $(FC) -o $@ -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $(SOLVE_EM_SPECIAL) $(OMP) $*.f90
module_sf_ruclsm.o : module_sf_ruclsm.F
$(RM) $@
$(RM) $*.b
echo COMPILING $*.F WITH OMP ; \
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $*.f90 ; \
else \
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ; \
fi
# compile without OMP
input_wrf.o \
module_domain.o \
module_domain_type.o \
module_physics_init.o \
module_io.o \
wrf_bdyin.o \
wrf_bdyout.o \
wrf_ext_read_field.o \
wrf_ext_write_field.o \
wrf_histin.o \
wrf_histout.o \
wrf_inputin.o \
wrf_inputout.o \
wrf_restartin.o \
wrf_restartout.o \
module_state_description.o \
module_alloc_space.o \
module_alloc_space_0.o \
module_alloc_space_1.o \
module_alloc_space_2.o \
module_alloc_space_3.o \
module_alloc_space_4.o \
module_alloc_space_5.o \
module_alloc_space_6.o \
module_alloc_space_7.o \
module_alloc_space_8.o \
module_alloc_space_9.o \
module_comm_dm.o \
module_comm_dm_0.o \
module_comm_dm_1.o \
module_comm_dm_2.o \
module_comm_dm_3.o \
module_comm_nesting_dm.o \
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $*.F > $*.bb
fi
$(RM) $*.b $*.bb
$(FC) -c $(PROMOTION) $(FCSUFFIX) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $*.f90
Both programmes compile without errors and create the corresponding executable files. However, when attempts are made to use convert_emiss.exe in WRF-CHEM in order to convert Prep-chem-sources input (volc_d01) into WRF-CHEM input, I receive the following error:
past opening wrfinput_d01
I am reading global volcanic emissions, dims: = 1 599 1 300
OPENED FILE: volc_d01
PGFIO-F-231/formatted read/internal file/error on data conversion.
In source file convert_emiss.f90, at line number 520
Line 520 convert_emiss.f90: read(unit=dname2(1:4), FMT=‘(I4)’)beg_yr
I have successfully run this conversion when the programmes have been made with other compilers, but compiling with PGI gives this issue. Does anyone have any idea what could be causing this problem?
