Dear All,
I am working with an atmospheric+oceanic+waves coupled model (COAWST).
This system uses WRF+ROMS+SWAM models. This system compiles and works well on our Cray computer. Now I am struggling to compile a toy version of it in my MacBook air with PGI compilers. I am doing on this machine:
Darwin MacBook-Air-de-Luciano.local 13.3.0 Darwin Kernel Version 13.3.0: Tue Jun 3 21:27:35 PDT 2014; root:xnu-2422.110.17~1/RELEASE_X86_64 x86_64
The system compiles well the routines however when it needs compile the libs it
fails. I have a long log file with all messages, but I don’t know how to append here. Below I am copying the main compilation flags and just a little of the log file. This message (Undefined symbols for architecture x86_64) always come across. I am using -m64 and compiling on 64 bits.
I appreciate any comments/suggestions.
Cheers
Luciano
[[list=mpif90 -o ndown.exe -O2 -fast -w -Mfree -byteswapio -Mnomod ndown_em.o …/dyn_em/module_initialize_real.o libwrflib.a -L/usr/local/netcdf-4.3.2/lib -L/usr/local/netcdf-4.3.2/lib -lnetcdf -lm
Undefined symbols for architecture x86_64:
“esmf_calendarmod$8", referenced from:
MAIN in ndown_em.o
“add_to_bufsize_for_field_c”, referenced from:
add_to_bufsize_for_field in libwrflib.a(module_quilt_outbuf_ops.o)
“byte_bcast”, referenced from:
wrf_dm_bcast_bytes in libwrflib.a(module_dm.o)
“cfft1b”, referenced from:
module_stoch_do_fftback_along_x in libwrflib.a(module_stoch.o)
module_stoch_do_fftback_along_y in libwrflib.a(module_stoch.o)
“cfft1i”, referenced from:
module_stoch_setup_stoch_skebs in libwrflib.a(module_stoch.o)
module_stoch_setup_stoch_sppt in libwrflib.a(module_stoch.o)
“dfft1b”, referenced from:
module_polarfft_polar_filter_fft_2d_ncar in libwrflib.a(module_polarfft.o)
“dfft1f”, referenced from:
“dfft1i”, referenced from:
“esmf_alarmclockmod”, referenced from:
.C9_310 in ndown_em.o
.C32_338 in module_initialize_real.o
.C13_284 in libwrflib.a(module_date_time.o)
.C6_17662 in libwrflib.a(nest_init_utils.o)
.C121_284 in libwrflib.a(module_io_domain.o)
.C70_285 in libwrflib.a(module_io_quilt.o)
anon in libwrflib.a(init_modules.o)
“esmf_alarmclockmod_esmf_alarmcreate”, referenced from:
module_domain_domain_alarm_create in libwrflib.a(module_domain.o)
“esmf_alarmmod$esmf_alarm$td”, referenced from:
module_domain_type$domain$td$ld in libwrflib.a(module_domain_type.o)
“esmf_alarmmod”, referenced from:
“esmf_alarmmod_esmf_alarmdestroy”, referenced from:
module_domain_domain_alarms_destroy in libwrflib.a(module_domain.o)
“esmf_alarmmod_esmf_alarmdisable”, referenced from:
setup_timekeeping in libwrflib.a(set_timekeeping.o)
“esmf_alarmmod_esmf_alarmenable”, referenced from:
“esmf_alarmmod_esmf_alarmget”, referenced from:
input_wrf in libwrflib.a(input_wrf.o)
output_wrf in libwrflib.a(output_wrf.o)
solve_em in libwrflib.a(solve_em.o)
module_diag_afwa_afwa_diagnostics_driver in libwrflib.a(module_diag_afwa.o)
“esmf_alarmmod_esmf_alarmisringing”, referenced from:
med_before_solve_io in libwrflib.a(mediation_integrate.o)
med_last_solve_io in libwrflib.a(mediation_integrate.o)
med_latbound_in in libwrflib.a(mediation_integrate.o)
“esmf_alarmmod_esmf_alarmringeroff”, referenced from:
“esmf_alarmmod_esmf_alarmringeron”, referenced from:
“esmf_alarmmod_esmf_alarmset”, referenced from:
“esmf_basemod”, referenced from:
“esmf_basetimemod”, referenced from:
“esmf_calendarmod”, referenced from:
“esmf_clockmod$esmf_clock$td”, referenced from:
module_domain_alloc_and_configure_domain in libwrflib.a(module_domain.o)
“esmf_clockmod”, referenced from:
“esmf_clockmod_esmf_clockadvance”, referenced from:
module_domain_domain_clockadvance in libwrflib.a(module_domain.o)
“esmf_clockmod_esmf_clockcreate”, referenced from:
module_domain_domain_clock_create in libwrflib.a(module_domain.o)
“esmf_clockmod_esmf_clockdestroy”, referenced from:
module_domain_domain_clock_destroy in libwrflib.a(module_domain.o)
“esmf_clockmod_esmf_clockget”, referenced from:
wrf_clockprint in libwrflib.a(module_date_time.o)
module_domain_domain_get_current_time in libwrflib.a(module_domain.o)
module_domain_domain_get_start_time in libwrflib.a(module_domain.o)
module_domain_domain_get_stop_time in libwrflib.a(module_domain.o)
module_domain_domain_get_time_step in libwrflib.a(module_domain.o)
module_domain_domain_get_advancecount in libwrflib.a(module_domain.o)
“esmf_clockmod_esmf_clockisstoptime”, referenced from:
module_domain_domain_clockisstoptime in libwrflib.a(module_domain.o)
med_nest_force in libwrflib.a(mediation_integrate.o)
“esmf_clockmod_esmf_clockset”, referenced from:
module_domain_domain_clock_set in libwrflib.a(module_domain.o)
dfi_bck_init in libwrflib.a(dfi.o)
dfi_fwd_init in libwrflib.a(dfi.o)
dfi_startfwd_init in libwrflib.a(dfi.o)
dfi_startbck_init in libwrflib.a(dfi.o)
adapt_timestep in libwrflib.a(adapt_timestep_em.o)
“esmf_mod”, referenced from:
“esmf_stubs”, referenced from:
“esmf_stubs_esmf_finalize”, referenced from:
MAIN in ndown_em.o
“esmf_stubs_esmf_initialize”, referenced from:
MAIN in ndown_em.o
“esmf_timeintervalmod”, referenced from:
“esmf_timeintervalmod_esmf_timeintervaldiff”, referenced from:
“esmf_timeintervalmod_esmf_timeintervaldivquot”, referenced from:
adjust_io_timestr in libwrflib.a(module_io_domain.o)
“esmf_timeintervalmod_esmf_timeintervaleq”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalget”, referenced from:
wrf_timeinttoa in libwrflib.a(module_date_time.o)
module_domain_domain_clock_get in libwrflib.a(module_domain.o)
module_domain_test_adjust_io_timestr in libwrflib.a(module_domain.o)
module_domain_domain_time_test in libwrflib.a(module_domain.o)
optfil_driver in libwrflib.a(dfi.o)
“esmf_timeintervalmod_esmf_timeintervalgt”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalispositive”, referenced from:
module_domain_domain_clockisstopsubtime in libwrflib.a(module_domain.o)
“esmf_timeintervalmod_esmf_timeintervalle”, referenced from:
“esmf_timeintervalmod_esmf_timeintervallt”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalne”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalprodi”, referenced from:
calc_dt in libwrflib.a(adapt_timestep_em.o)
“esmf_timeintervalmod_esmf_timeintervalquoti”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalset”, referenced from:
“esmf_timeintervalmod_esmf_timeintervalsum”, referenced from:
“esmf_timemod”, referenced from:
“esmf_timemod_esmf_timecopy”, referenced from:
module_domain_domain_get_time_since_sim_start in libwrflib.a(module_domain.o)
module_integrate_integrate in libwrflib.a(module_integrate.o)
“esmf_timemod_esmf_timedec”, referenced from:
module_domain_is_alarm_tstep in libwrflib.a(module_domain.o)
“esmf_timemod_esmf_timediff”, referenced from:
“esmf_timemod_esmf_timeeq”, referenced from:
module_domain_domain_last_time_step in libwrflib.a(module_domain.o)
module_domain_domain_clockisstarttime in libwrflib.a(module_domain.o)
module_domain_domain_clockissimstarttime in libwrflib.a(module_domain.o)
med_nest_initial in libwrflib.a(mediation_integrate.o)
“esmf_timemod_esmf_timege”, referenced from:
“esmf_timemod_esmf_timeget”, referenced from:
wrf_timetoa in libwrflib.a(module_date_time.o)
module_domain_domain_setgmtetc in libwrflib.a(module_domain.o)
module_first_rk_step_part1_first_rk_step_part1 in libwrflib.a(module_first_rk_step_part1.o)
“esmf_timemod_esmf_timegt”, referenced from:
module_nesting_nests_to_open in libwrflib.a(module_nesting.o)
“esmf_timemod_esmf_timeinc”, referenced from:
“esmf_timemod_esmf_timele”, referenced from:
“esmf_timemod_esmf_timelt”, referenced from:
module_bc_time_utilities_lbc_read_time in libwrflib.a(module_bc_time_utilities.o)
“esmf_timemod_esmf_timene”, referenced from:
track_driver in libwrflib.a(track_driver.o)
“esmf_timemod_esmf_timeset”, referenced from:
wrf_atotime in libwrflib.a(module_date_time.o)
module_domain_domain_get_sim_start_time in libwrflib.a(module_domain.o)
“ext_gr1_get_dom_td_char”, referenced from:
module_io_wrf_get_dom_td_char_arr in libwrflib.a(module_io.o)
“ext_gr1_get_dom_td_double”, referenced from:
module_io_wrf_get_dom_td_double_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_td_double_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_td_integer”, referenced from:
module_io_wrf_get_dom_td_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_td_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_td_logical”, referenced from:
module_io_wrf_get_dom_td_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_td_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_td_real”, referenced from:
module_io_wrf_get_dom_td_real_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_td_real_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_ti_char”, referenced from:
module_io_wrf_get_dom_ti_char_arr in libwrflib.a(module_io.o)
“ext_gr1_get_dom_ti_double”, referenced from:
module_io_wrf_get_dom_ti_double_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_ti_double_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_ti_integer”, referenced from:
module_io_wrf_get_dom_ti_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_ti_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_ti_logical”, referenced from:
module_io_wrf_get_dom_ti_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_ti_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_get_dom_ti_real”, referenced from:
module_io_wrf_get_dom_ti_real_arr in libwrflib.a(module_io.o)
module_io_wrf_get_dom_ti_real_sca in libwrflib.a(module_io.o)
“ext_gr1_get_next_time”, referenced from:
module_io_wrf_get_next_time in libwrflib.a(module_io.o)
“ext_gr1_get_next_var”, referenced from:
module_io_wrf_get_next_var in libwrflib.a(module_io.o)
“ext_gr1_get_previous_time”, referenced from:
module_io_wrf_get_previous_time in libwrflib.a(module_io.o)
“ext_gr1_get_var_info”, referenced from:
module_io_wrf_get_var_info in libwrflib.a(module_io.o)
“ext_gr1_get_var_td_char”, referenced from:
module_io_wrf_get_var_td_char_arr in libwrflib.a(module_io.o)
“ext_gr1_get_var_td_double”, referenced from:
module_io_wrf_get_var_td_double_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_td_double_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_td_integer”, referenced from:
module_io_wrf_get_var_td_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_td_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_td_logical”, referenced from:
module_io_wrf_get_var_td_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_td_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_td_real”, referenced from:
module_io_wrf_get_var_td_real_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_td_real_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_ti_char”, referenced from:
module_io_wrf_get_var_ti_char_arr in libwrflib.a(module_io.o)
“ext_gr1_get_var_ti_double”, referenced from:
module_io_wrf_get_var_ti_double_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_ti_double_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_ti_integer”, referenced from:
module_io_wrf_get_var_ti_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_ti_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_ti_logical”, referenced from:
module_io_wrf_get_var_ti_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_ti_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_get_var_ti_real”, referenced from:
module_io_wrf_get_var_ti_real_arr in libwrflib.a(module_io.o)
module_io_wrf_get_var_ti_real_sca in libwrflib.a(module_io.o)
“ext_gr1_inquire_filename”, referenced from:
module_wrf_quilt_quilt in libwrflib.a(module_io_quilt.o)
module_wrf_quilt_quilt_pnc in libwrflib.a(module_io_quilt.o)
module_io_wrf_inquire_filename in libwrflib.a(module_io.o)
“ext_gr1_inquire_opened”, referenced from:
module_io_wrf_inquire_opened in libwrflib.a(module_io.o)
“ext_gr1_ioclose”, referenced from:
module_io_wrf_ioclose in libwrflib.a(module_io.o)
“ext_gr1_ioexit”, referenced from:
module_io_wrf_ioexit in libwrflib.a(module_io.o)
“ext_gr1_ioinit”, referenced from:
module_io_wrf_ioinit in libwrflib.a(module_io.o)
“ext_gr1_iosync”, referenced from:
module_io_wrf_iosync in libwrflib.a(module_io.o)
“ext_gr1_open_for_read”, referenced from:
module_io_wrf_open_for_read in libwrflib.a(module_io.o)
“ext_gr1_open_for_read_begin”, referenced from:
module_io_wrf_open_for_read_begin in libwrflib.a(module_io.o)
“ext_gr1_open_for_read_commit”, referenced from:
module_io_wrf_open_for_read_commit in libwrflib.a(module_io.o)
“ext_gr1_open_for_write_begin”, referenced from:
module_io_wrf_open_for_write_begin in libwrflib.a(module_io.o)
“ext_gr1_open_for_write_commit”, referenced from:
module_io_wrf_open_for_write_commit in libwrflib.a(module_io.o)
“ext_gr1_put_dom_td_char”, referenced from:
module_io_wrf_put_dom_td_char_arr in libwrflib.a(module_io.o)
“ext_gr1_put_dom_td_double”, referenced from:
module_io_wrf_put_dom_td_double_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_td_double_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_td_integer”, referenced from:
module_io_wrf_put_dom_td_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_td_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_td_logical”, referenced from:
module_io_wrf_put_dom_td_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_td_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_td_real”, referenced from:
module_io_wrf_put_dom_td_real_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_td_real_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_ti_char”, referenced from:
module_io_wrf_put_dom_ti_char_arr in libwrflib.a(module_io.o)
“ext_gr1_put_dom_ti_double”, referenced from:
module_io_wrf_put_dom_ti_double_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_ti_double_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_ti_integer”, referenced from:
module_io_wrf_put_dom_ti_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_ti_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_ti_logical”, referenced from:
module_io_wrf_put_dom_ti_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_ti_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_put_dom_ti_real”, referenced from:
module_io_wrf_put_dom_ti_real_arr in libwrflib.a(module_io.o)
module_io_wrf_put_dom_ti_real_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_td_char”, referenced from:
module_io_wrf_put_var_td_char_arr in libwrflib.a(module_io.o)
“ext_gr1_put_var_td_double”, referenced from:
module_io_wrf_put_var_td_double_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_td_double_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_td_integer”, referenced from:
module_io_wrf_put_var_td_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_td_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_td_logical”, referenced from:
module_io_wrf_put_var_td_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_td_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_td_real”, referenced from:
module_io_wrf_put_var_td_real_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_td_real_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_ti_char”, referenced from:
module_io_wrf_put_var_ti_char_arr in libwrflib.a(module_io.o)
“ext_gr1_put_var_ti_double”, referenced from:
module_io_wrf_put_var_ti_double_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_ti_double_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_ti_integer”, referenced from:
module_io_wrf_put_var_ti_integer_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_ti_integer_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_ti_logical”, referenced from:
module_io_wrf_put_var_ti_logical_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_ti_logical_sca in libwrflib.a(module_io.o)
“ext_gr1_put_var_ti_real”, referenced from:
module_io_wrf_put_var_ti_real_arr in libwrflib.a(module_io.o)
module_io_wrf_put_var_ti_real_sca in libwrflib.a(module_io.o)
“ext_gr1_read_field”, referenced from:
wrf_read_field1 in libwrflib.a(module_io.o)
“ext_gr1_set_time”, referenced from:
module_io_wrf_set_time in libwrflib.a(module_io.o)
“ext_gr1_write_field”, referenced from:
wrf_write_field1 in libwrflib.a(module_io.o)
module_quilt_outbuf_ops_write_outbuf in libwrflib.a(module_quilt_outbuf_ops.o)
“ext_int_get_dom_td_char”, referenced from:
“ext_int_get_dom_td_double”, referenced from:
“ext_int_get_dom_td_integer”, referenced from:
“ext_int_get_dom_td_logical”, referenced from:
“ext_int_get_dom_td_real”, referenced from:
“ext_int_get_dom_ti_char”, referenced from:
“ext_int_get_dom_ti_double”, referenced from:
“ext_int_get_dom_ti_integer”, referenced from:
“ext_int_get_dom_ti_logical”, referenced from:
“ext_int_get_dom_ti_real”, referenced from:
“ext_int_get_next_time”, referenced from:
“ext_int_get_next_var”, referenced from:
“ext_int_get_var_td_char”, referenced from:
“ext_int_get_var_td_double”, referenced from:
“ext_int_get_var_td_integer”, referenced from:
“ext_int_get_var_td_logical”, referenced from:
“ext_int_get_var_td_real”, referenced from:
“ext_int_get_var_ti_char”, referenced from:
“ext_int_get_var_ti_double”, referenced from:
“ext_int_get_var_ti_integer”, referenced from:
“ext_int_get_var_ti_logical”, referenced from:
“ext_int_get_var_ti_real”, referenced from:
“ext_int_inquire_filename”, referenced from:
“ext_int_inquire_opened”, referenced from:
“ext_int_ioclose”, referenced from:
“ext_int_ioexit”, referenced from:
“ext_int_ioinit”, referenced from:
“ext_int_iosync”, referenced from:
“ext_int_open_for_read”, referenced from:
“ext_int_open_for_write_begin”, referenced from:
“ext_int_open_for_write_commit”, referenced from:
“ext_int_put_dom_td_char”, referenced from:
“ext_int_put_dom_td_double”, referenced from:
“ext_int_put_dom_td_integer”, referenced from:
“ext_int_put_dom_td_logical”, referenced from:
“ext_int_put_dom_td_real”, referenced from:
“ext_int_put_dom_ti_char”, referenced from:
“ext_int_put_dom_ti_double”, referenced from:
“ext_int_put_dom_ti_integer”, referenced from:
“ext_int_put_dom_ti_logical”, referenced from:
“ext_int_put_dom_ti_real”, referenced from:
“ext_int_put_var_td_char”, referenced from:
“ext_int_put_var_td_double”, referenced from:
“ext_int_put_var_td_integer”, referenced from:
“ext_int_put_var_td_logical”, referenced from:
“ext_int_put_var_td_real”, referenced from:
“ext_int_put_var_ti_char”, referenced from:
“ext_int_put_var_ti_double”, referenced from:
“ext_int_put_var_ti_integer”, referenced from:
“ext_int_put_var_ti_logical”, referenced from:
“ext_int_put_var_ti_real”, referenced from:
“ext_int_read_field”, referenced from:
“ext_int_set_time”, referenced from:
“ext_int_write_field”, referenced from:
“ext_ncd_get_dom_td_char”, referenced from:
“ext_ncd_get_dom_td_double”, referenced from:
“ext_ncd_get_dom_td_integer”, referenced from:
“ext_ncd_get_dom_td_logical”, referenced from:
“ext_ncd_get_dom_td_real”, referenced from:
“ext_ncd_get_dom_ti_char”, referenced from:
“ext_ncd_get_dom_ti_double”, referenced from:
“ext_ncd_get_dom_ti_integer”, referenced from:
“ext_ncd_get_dom_ti_logical”, referenced from:
“ext_ncd_get_dom_ti_real”, referenced from:
“ext_ncd_get_next_time”, referenced from:
“ext_ncd_get_next_var”, referenced from:
“ext_ncd_get_previous_time”, referenced from:
“ext_ncd_get_var_info”, referenced from:
“ext_ncd_get_var_td_char”, referenced from:
“ext_ncd_get_var_td_double”, referenced from:
“ext_ncd_get_var_td_integer”, referenced from:
“ext_ncd_get_var_td_logical”, referenced from:
“ext_ncd_get_var_td_real”, referenced from:
“ext_ncd_get_var_ti_char”, referenced from:
“ext_ncd_get_var_ti_double”, referenced from:
“ext_ncd_get_var_ti_integer”, referenced from:
“ext_ncd_get_var_ti_logical”, referenced from:
“ext_ncd_get_var_ti_real”, referenced from:
“ext_ncd_inquire_filename”, referenced from:
“ext_ncd_inquire_opened”, referenced from:
“ext_ncd_ioclose”, referenced from:
“ext_ncd_ioexit”, referenced from:
“ext_ncd_ioinit”, referenced from:
“ext_ncd_iosync”, referenced from:
“ext_ncd_open_for_read”, referenced from:
“ext_ncd_open_for_read_begin”, referenced from:
“ext_ncd_open_for_read_commit”, referenced from:
“ext_ncd_open_for_write_begin”, referenced from:
“ext_ncd_open_for_write_commit”, referenced from:
“ext_ncd_put_dom_td_char”, referenced from:
“ext_ncd_put_dom_td_double”, referenced from:
“ext_ncd_put_dom_td_integer”, referenced from:
“ext_ncd_put_dom_td_logical”, referenced from:
“ext_ncd_put_dom_td_real”, referenced from:
“ext_ncd_put_dom_ti_char”, referenced from:
“ext_ncd_put_dom_ti_double”, referenced from:
“ext_ncd_put_dom_ti_integer”, referenced from:
“ext_ncd_put_dom_ti_logical”, referenced from:
“ext_ncd_put_dom_ti_real”, referenced from:
“ext_ncd_put_var_td_char”, referenced from:
“ext_ncd_put_var_td_double”, referenced from:
“ext_ncd_put_var_td_integer”, referenced from:
“ext_ncd_put_var_td_logical”, referenced from:
“ext_ncd_put_var_td_real”, referenced from:
“ext_ncd_put_var_ti_char”, referenced from:
“ext_ncd_put_var_ti_double”, referenced from:
“ext_ncd_put_var_ti_integer”, referenced from:
“ext_ncd_put_var_ti_logical”, referenced from:
“ext_ncd_put_var_ti_real”, referenced from:
“ext_ncd_read_field”, referenced from:
“ext_ncd_set_time”, referenced from:
“ext_ncd_write_field”, referenced from:
“fraction_to_string”, referenced from:
“get_mask”, referenced from:
module_domain_warn_me_or_set_mask in libwrflib.a(module_domain.o)
module_io_on_stream in libwrflib.a(module_io.o)
“init_retrieve_pieces_of_field”, referenced from:
“init_store_piece_of_field”, referenced from:
“int_pack_data”, referenced from:
wrf_quilt_write_field in libwrflib.a(module_io_quilt.o)
“m_attrvect”, referenced from:
.C2_304 in libwrflib.a(module_integrate.o)
.STATICS8 in libwrflib.a(atm_coupler.o)
"m_attrvect_clean”, referenced from:
atm_coupler_mod_finalize_atm_coupling in libwrflib.a(atm_coupler.o)
“m_attrvect_exportrattrsp_”, referenced from:
atm_coupler_mod_atmfocn_coupling in libwrflib.a(atm_coupler.o)
atm_coupler_mod_atmfwav_coupling in libwrflib.a(atm_coupler.o)
“m_attrvect_importrattrsp_”, referenced from:
atm_coupler_mod_atm2ocn_coupling in libwrflib.a(atm_coupler.o)
atm_coupler_mod_atm2wav_coupling in libwrflib.a(atm_coupler.o)
“m_attrvect_init_”, referenced from:
atm_coupler_mod_initialize_atm_coupling in libwrflib.a(atm_coupler.o)
“m_attrvect_zero_”, referenced from:
“m_globalsegmap”, referenced from:
“m_globalsegmap_clean_”, referenced from:
“m_globalsegmap_initd_”, referenced from:
“m_globalsegmap_lsize_”, referenced from:
“m_list”, referenced from:
“m_mctworld”, referenced from:
“m_mctworld_clean_”, referenced from:
“m_mctworld_initd_”, referenced from:
“m_router”, referenced from:
“m_router_initd_”, referenced from:
atm_coupler_mod_initialize_atm_routers in libwrflib.a(atm_coupler.o)
“m_string”, referenced from:
“m_transfer”, referenced from:
“m_transfer_irecv_”, referenced from:
“m_transfer_isend_”, referenced from:
“m_transfer_waitrecv_”, referenced from:
“m_transfer_waitsend_”, referenced from:
“module_ext_internal”, referenced from:
“module_ext_internal_init_module_ext_internal”, referenced from:
init_modules in libwrflib.a(init_modules.o)
“module_internal_header_util”, referenced from:
“module_internal_header_util_get_hdr_rec_size”, referenced from:
“module_internal_header_util_get_hdr_tag”, referenced from:
“module_internal_header_util_int_gen_handle_header”, referenced from:
wrf_quilt_open_for_write_commit in libwrflib.a(module_io_quilt.o)
wrf_quilt_ioclose in libwrflib.a(module_io_quilt.o)
wrf_quilt_ioexit in libwrflib.a(module_io_quilt.o)
“module_internal_header_util_int_gen_noop_header”, referenced from:
wrf_quilt_open_for_write_begin in libwrflib.a(module_io_quilt.o)
wrf_quilt_set_time in libwrflib.a(module_io_quilt.o)
wrf_quilt_put_dom_ti_real in libwrflib.a(module_io_quilt.o)
wrf_quilt_put_dom_ti_integer in libwrflib.a(module_io_quilt.o)
“module_internal_header_util_int_gen_ofwb_header”, referenced from:
“module_internal_header_util_int_gen_ti_header_char”, referenced from:
wrf_quilt_put_dom_ti_char in libwrflib.a(module_io_quilt.o)
wrf_quilt_put_var_ti_char in libwrflib.a(module_io_quilt.o)
“module_internal_header_util_int_gen_ti_header_integer”, referenced from:
“module_internal_header_util_int_gen_ti_header_real”, referenced from:
“module_internal_header_util_int_gen_write_field_header”, referenced from:
“module_internal_header_util_int_get_handle_header”, referenced from:
“module_internal_header_util_int_get_noop_header”, referenced from:
“module_internal_header_util_int_get_ofwb_header”, referenced from:
“module_internal_header_util_int_get_td_header_integer”, referenced from:
“module_internal_header_util_int_get_td_header_real”, referenced from:
“module_internal_header_util_int_get_ti_header_char”, referenced from:
“module_internal_header_util_int_get_ti_header_integer”, referenced from:
“module_internal_header_util_int_get_ti_header_real”, referenced from:
“module_internal_header_util_int_get_write_field_header”, referenced from:
“module_symbols_util”, referenced from:
“module_utility”, referenced from:
“mpi_x_comm_size”, referenced from:
module_wrf_quilt_init_module_wrf_quilt in libwrflib.a(module_io_quilt.o)
“nf_close”, referenced from:
write_track in libwrflib.a(track_driver.o)
“nf_create”, referenced from:
“nf_def_dim”, referenced from:
“nf_def_var”, referenced from:
“nf_enddef”, referenced from:
“nf_inq_varid”, referenced from:
“nf_put_att_text”, referenced from:
“nf_put_vara_int”, referenced from:
“nf_put_vara_real”, referenced from:
“nf_put_vara_text”, referenced from:
“perturb_real”, referenced from:
wrf_read_field in libwrflib.a(module_io.o)
“reset_mask”, referenced from:
“retrieve_pieces_of_field_c”, referenced from:
retrieve_pieces_of_field in libwrflib.a(module_quilt_outbuf_ops.o)
“rfftmb”, referenced from:
module_fdda_spnudging_spectralnudgingfilterfft2dncar in libwrflib.a(module_fdda_spnudging.o)
“rfftmf”, referenced from:
“rfftmi”, referenced from:
_module_fdda_spnudging_spectralnudging
