I have installed PGI Workstation Complete in Fedora Core 4 system. I need it to compile MM5 model. but when I try to compile, I am getting this:
error while loading shared libraries: /opt/pgi/linux86/6.1/lib/libpgc.so: cannot restore segment prot after reloc: Permission denied
it seems that problem is with reading the libraries, because at the end of output appears:
/opt/pgi/linux86/6.1/lib/libf2c.a(open.o)(.text+0x35f): In function f_open': open.c: warning: the use of tmpnam’ is dangerous, better use mkstemp' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x19d): In function l_R’:
lread.c: undefined reference to __ctype_b' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x248):lread.c: undefined reference to __ctype_b’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x2a6):lread.c: undefined reference to __ctype_b' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x2ce):lread.c: undefined reference to __ctype_b’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x77e): In function l_L': lread.c: undefined reference to __ctype_b’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x9ba):lread.c: more undefined references to `__ctype_b’ follow
make[1]: [terrain.exe] Error 2 (ignored)
all the make.out file look so:
uname -a > .tmpfile
grep crayx1 .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for CRAY X1” ;
( cd src ; make -i -f Makefile.x1 all
“RM = /bin/rm -f” “RM_LIST = *.o *.f core .tmpfile terrain.exe data_area.exe rdem.exe rdnml”
“LN = ln -s” “MACH = crayx1”
“MAKE = make -i -f Makefile” “CPP = cpp”
“CPPFLAGS = -eZ -I. -DNCARG -DRECLENBYTE -UCRAY”
“FC = ftn” "FCFLAGS = -I. -ra "
"LDOPTIONS = " "CFLAGS = "
"LOCAL_LIBRARIES= " ) ;
else
grep CRAY .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for CRAY” ;
( cd src ; make -i -f Makefile all
“LN = ln -s” “MACH = CRAY”
“MAKE = make -i -f Makefile” “CPP = /opt/ctl/bin/cpp”
“CPPFLAGS = -I. -C -P -DNCARG -DRECLENBYTE”
“FC = f90” “FCFLAGS = -I.”
“LOCAL_LIBRARIES= -L/usr/local/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lm” ) ;
else
grep OSF .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for Compaq” ;
“LN = ln -s” “MACH = DEC”
“MAKE = make -i -f Makefile” “CPP = /usr/bin/cpp”
“CPPFLAGS = -I. -C -P -DNCARG”
“FC = f77” “FCFLAGS = -I. -convert big_endian -fpe”
“LOCAL_LIBRARIES= -L/usr/local/ncarg/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lm” ) ;
else
grep IRIX .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for SGI” ;
“LN = ln -s” “MACH = SGI”
“MAKE = make -i -f Makefile” “CPP = /lib/cpp”
“FC = f77” “FCFLAGS = -I. -n32”
“LDOPTIONS = -n32” “CFLAGS = -I. -n32”
“LOCAL_LIBRARIES= -L/usr/local/ncarg/lib -L/usr/local/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lm” ) ;
else
grep HP .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for HP” ;
“LN = ln -s” “MACH = HP”
“MAKE = make -i -f Makefile” “CPP = /opt/langtools/lbin/cpp”
“CPPFLAGS= -I. -C -P -DNCARG -DRECLENBYTE”
“FC = f77” “FCFLAGS = -I. -O”
"LDOPTIONS = " “CFLAGS = -Aa”
else
grep SUN .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for SUN” ;
“LN = ln -s” “MACH = SUN”
“MAKE = make -i -f Makefile” “CPP = /usr/ccs/lib/cpp”
“CPPFLAGS=-I. -C -P -DNCARG -DRECLENBYTE”
“FC = f77” “FCFLAGS = -I.”
"LDOPTIONS = " “CFLAGS = -I.”
“LOCAL_LIBRARIES= -L/usr/local/ncarg/lib -L/usr/openwin/lib -L/usr/dt/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lm” ) ;
else
grep AIX .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for IBM” ;
“LN = ln -s” “MACH = IBM”
“MAKE = make -i -f Makefile” “CPP = /usr/lib/cpp”
“FC = xlf” “FCFLAGS = -I. -O -qmaxmem=-1”
“LDOPTIONS = -bmaxstack:512000000 -bmaxdata:2000000000” “CFLAGS = -I.”
“LOCAL_LIBRARIES= -L/usr/local/lib32/r4i4 -lncarg -lncarg_gks -lncarg_c -lX11 -lm” ) ;
else
grep Darwin .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for MAC” ;
“CPPFLAGS = -I. -C -P -DNONCARG -DRECLENBYTE -xassembler-with-cpp”
“FC = xlf” "FCFLAGS = -I. -O "
“LDOPTIONS = -Wl,-stack_size,10000000,-stack_addr,0xc0000000” “CFLAGS = -I.”
“LOCAL_LIBRARIES= -L/usr/local/ncarg/lib -lncarg -lncarg_gks -lncarg_c -L/usr/X11R6/lib -lX11 -lm” ) ;
else
grep Linux .tmpfile ;
if [ $? = 0 ]; then echo “Compiling for Linux” ;
“CPPFLAGS = -I. -C -traditional -DNCARG -DRECLENBYTE”
“FC = pgf90” “FCFLAGS = -I. -byteswapio”
“LOCAL_LIBRARIES= -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -L/opt/pgi/linux86/lib -L/usr/lib -lf2c” ) ;
else echo “Do not know how to compile for the cat .tmpfile machine.”
fi ;
fi ;
fi ;
fi ;
fi ;
fi ;
fi ;
fi ;
fi ;
fi ;
( /bin/rm -f terrain.exe ; ln -s src/terrain.exe . ) ;
Linux localhost.localdomain 2.6.11-1.1369_FC4smp #1 SMP Thu Jun 2 23:08:39 EDT 2005 i686 i686 i386 GNU/Linux
Compiling for Linux
make[1]: Entering directory /home/audrius/TERRAIN/src' /bin/rm -f ia.f cut -c1-72 ia.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > ia.f /bin/rm -f ia.o pgf90 -c -I. -byteswapio ia.f /bin/rm -f ia.f /bin/rm -f anal2.f cut -c1-72 anal2.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > anal2.f /bin/rm -f anal2.o pgf90 -c -I. -byteswapio anal2.f /bin/rm -f anal2.f /bin/rm -f bint.f cut -c1-72 bint.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > bint.f /bin/rm -f bint.o pgf90 -c -I. -byteswapio bint.f /bin/rm -f bint.f /bin/rm -f bndry.f cut -c1-72 bndry.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > bndry.f /bin/rm -f bndry.o pgf90 -c -I. -byteswapio bndry.f /bin/rm -f bndry.f /bin/rm -f crlnd.f cut -c1-72 crlnd.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crlnd.f /bin/rm -f crlnd.o pgf90 -c -I. -byteswapio crlnd.f /bin/rm -f crlnd.f /bin/rm -f crter.f cut -c1-72 crter.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crter.f /bin/rm -f crter.o pgf90 -c -I. -byteswapio crter.f /bin/rm -f crter.f /bin/rm -f dfclrs.f cut -c1-72 dfclrs.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > dfclrs.f /bin/rm -f dfclrs.o pgf90 -c -I. -byteswapio dfclrs.f /bin/rm -f dfclrs.f /bin/rm -f exaint.f cut -c1-72 exaint.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > exaint.f /bin/rm -f exaint.o pgf90 -c -I. -byteswapio exaint.f /bin/rm -f exaint.f /bin/rm -f finprt.f cut -c1-72 finprt.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > finprt.f /bin/rm -f finprt.o pgf90 -c -I. -byteswapio finprt.f /bin/rm -f finprt.f /bin/rm -f fudger.f cut -c1-72 fudger.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > fudger.f /bin/rm -f fudger.o pgf90 -c -I. -byteswapio fudger.f /bin/rm -f fudger.f /bin/rm -f interp.f cut -c1-72 interp.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > interp.f /bin/rm -f interp.o pgf90 -c -I. -byteswapio interp.f /bin/rm -f interp.f /bin/rm -f label.f cut -c1-72 label.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > label.f /bin/rm -f label.o pgf90 -c -I. -byteswapio label.f /bin/rm -f label.f /bin/rm -f lakes.f cut -c1-72 lakes.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > lakes.f /bin/rm -f lakes.o pgf90 -c -I. -byteswapio lakes.f /bin/rm -f lakes.f /bin/rm -f latlon.f cut -c1-72 latlon.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > latlon.f /bin/rm -f latlon.o pgf90 -c -I. -byteswapio latlon.f /bin/rm -f latlon.f /bin/rm -f llxy.f cut -c1-72 llxy.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > llxy.f /bin/rm -f llxy.o pgf90 -c -I. -byteswapio llxy.f /bin/rm -f llxy.f /bin/rm -f mxmnll.f cut -c1-72 mxmnll.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > mxmnll.f /bin/rm -f mxmnll.o pgf90 -c -I. -byteswapio mxmnll.f /bin/rm -f mxmnll.f /bin/rm -f nestll.f cut -c1-72 nestll.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > nestll.f /bin/rm -f nestll.o pgf90 -c -I. -byteswapio nestll.f /bin/rm -f nestll.f /bin/rm -f oned.f cut -c1-72 oned.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > oned.f /bin/rm -f oned.o pgf90 -c -I. -byteswapio oned.f /bin/rm -f oned.f /bin/rm -f outpt.f cut -c1-72 outpt.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > outpt.f /bin/rm -f outpt.o pgf90 -c -I. -byteswapio outpt.f /bin/rm -f outpt.f /bin/rm -f output.f cut -c1-72 output.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > output.f /bin/rm -f output.o pgf90 -c -I. -byteswapio output.f /bin/rm -f output.f /bin/rm -f pltter.f cut -c1-72 pltter.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > pltter.f /bin/rm -f pltter.o pgf90 -c -I. -byteswapio pltter.f /bin/rm -f pltter.f /bin/rm -f rdldtr.f cut -c1-72 rdldtr.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > rdldtr.f /bin/rm -f rdldtr.o pgf90 -c -I. -byteswapio rdldtr.f /bin/rm -f rdldtr.f /bin/rm -f replace.f cut -c1-72 replace.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > replace.f /bin/rm -f replace.o pgf90 -c -I. -byteswapio replace.f /bin/rm -f replace.f /bin/rm -f rflp.f cut -c1-72 rflp.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > rflp.f /bin/rm -f rflp.o pgf90 -c -I. -byteswapio rflp.f /bin/rm -f rflp.f /bin/rm -f setup.f cut -c1-72 setup.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > setup.f /bin/rm -f setup.o pgf90 -c -I. -byteswapio setup.f /bin/rm -f setup.f /bin/rm -f sint.f cut -c1-72 sint.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > sint.f /bin/rm -f sint.o pgf90 -c -I. -byteswapio sint.f /bin/rm -f sint.f /bin/rm -f smth121.f cut -c1-72 smth121.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > smth121.f /bin/rm -f smth121.o pgf90 -c -I. -byteswapio smth121.f /bin/rm -f smth121.f /bin/rm -f smther.f cut -c1-72 smther.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > smther.f /bin/rm -f smther.o pgf90 -c -I. -byteswapio smther.f /bin/rm -f smther.f /bin/rm -f smthtr.f cut -c1-72 smthtr.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > smthtr.f /bin/rm -f smthtr.o pgf90 -c -I. -byteswapio smthtr.f /bin/rm -f smthtr.f /bin/rm -f terdrv.f cut -c1-72 terdrv.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > terdrv.f /bin/rm -f terdrv.o pgf90 -c -I. -byteswapio terdrv.f /bin/rm -f terdrv.f /bin/rm -f terrain.f cut -c1-72 terrain.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > terrain.f /bin/rm -f terrain.o pgf90 -c -I. -byteswapio terrain.f /bin/rm -f terrain.f /bin/rm -f tfudge.f cut -c1-72 tfudge.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > tfudge.f /bin/rm -f tfudge.o pgf90 -c -I. -byteswapio tfudge.f /bin/rm -f tfudge.f /bin/rm -f vtran.f cut -c1-72 vtran.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > vtran.f /bin/rm -f vtran.o pgf90 -c -I. -byteswapio vtran.f /bin/rm -f vtran.f /bin/rm -f xyobsll.f cut -c1-72 xyobsll.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > xyobsll.f /bin/rm -f xyobsll.o pgf90 -c -I. -byteswapio xyobsll.f /bin/rm -f xyobsll.f /bin/rm -f hiresmap.f cut -c1-72 hiresmap.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > hiresmap.f /bin/rm -f hiresmap.o pgf90 -c -I. -byteswapio hiresmap.f /bin/rm -f hiresmap.f /bin/rm -f plots.f cut -c1-72 plots.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > plots.f /bin/rm -f plots.o pgf90 -c -I. -byteswapio plots.f /bin/rm -f plots.f /bin/rm -f crvst.f cut -c1-72 crvst.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crvst.f /bin/rm -f crvst.o pgf90 -c -I. -byteswapio crvst.f /bin/rm -f crvst.f /bin/rm -f crvst30s.f cut -c1-72 crvst30s.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crvst30s.f /bin/rm -f crvst30s.o pgf90 -c -I. -byteswapio crvst30s.f /bin/rm -f crvst30s.f /bin/rm -f nestbdy.f cut -c1-72 nestbdy.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > nestbdy.f /bin/rm -f nestbdy.o pgf90 -c -I. -byteswapio nestbdy.f /bin/rm -f nestbdy.f /bin/rm -f crsoil.f cut -c1-72 crsoil.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crsoil.f /bin/rm -f crsoil.o pgf90 -c -I. -byteswapio crsoil.f /bin/rm -f crsoil.f /bin/rm -f equate.f cut -c1-72 equate.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > equate.f /bin/rm -f equate.o pgf90 -c -I. -byteswapio equate.f /bin/rm -f equate.f /bin/rm -f labels.f cut -c1-72 labels.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > labels.f /bin/rm -f labels.o pgf90 -c -I. -byteswapio labels.f /bin/rm -f labels.f /bin/rm -f labelv.f cut -c1-72 labelv.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > labelv.f /bin/rm -f labelv.o pgf90 -c -I. -byteswapio labelv.f /bin/rm -f labelv.f /bin/rm -f patch.f cut -c1-72 patch.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > patch.f /bin/rm -f patch.o pgf90 -c -I. -byteswapio patch.f /bin/rm -f patch.f /bin/rm -f plotcon.f cut -c1-72 plotcon.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > plotcon.f /bin/rm -f plotcon.o pgf90 -c -I. -byteswapio plotcon.f /bin/rm -f plotcon.f /bin/rm -f watercheck.f cut -c1-72 watercheck.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > watercheck.f /bin/rm -f watercheck.o pgf90 -c -I. -byteswapio watercheck.f /bin/rm -f watercheck.f /bin/rm -f crlwmsk.f cut -c1-72 crlwmsk.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > crlwmsk.f /bin/rm -f crlwmsk.o pgf90 -c -I. -byteswapio crlwmsk.f /bin/rm -f crlwmsk.f /bin/rm -f soil_tg.f cut -c1-72 soil_tg.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > soil_tg.f /bin/rm -f soil_tg.o pgf90 -c -I. -byteswapio soil_tg.f /bin/rm -f soil_tg.f /bin/rm -f water_vfr.f cut -c1-72 water_vfr.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > water_vfr.f /bin/rm -f water_vfr.o pgf90 -c -I. -byteswapio water_vfr.f /bin/rm -f water_vfr.f /bin/rm -f check_data.f cut -c1-72 check_data.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > check_data.f /bin/rm -f check_data.o pgf90 -c -I. -byteswapio check_data.f /bin/rm -f check_data.f /bin/rm -f terrestial_info.f cut -c1-72 terrestial_info.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > terrestial_info.f /bin/rm -f terrestial_info.o pgf90 -c -I. -byteswapio terrestial_info.f /bin/rm -f terrestial_info.f /bin/rm -f write_fieldrec.f cut -c1-72 write_fieldrec.F | /lib/cpp -I. -C -traditional -DNCARG -DRECLENBYTE -DSGI > write_fieldrec.f /bin/rm -f write_fieldrec.o pgf90 -c -I. -byteswapio write_fieldrec.f /bin/rm -f write_fieldrec.f pgf90 -o terrain.exe ia.o anal2.o bint.o bndry.o crlnd.o crter.o dfclrs.o exaint.o finprt.o fudger.o interp.o label.o lakes.o latlon.o llxy.o mxmnll.o nestll.o oned.o outpt.o output.o pltter.o rdldtr.o replace.o rflp.o setup.o sint.o smth121.o smther.o smthtr.o terdrv.o terrain.o tfudge.o vtran.o xyobsll.o hiresmap.o plots.o crvst.o crvst30s.o nestbdy.o crsoil.o equate.o labels.o labelv.o patch.o plotcon.o watercheck.o crlwmsk.o soil_tg.o water_vfr.o check_data.o terrestial_info.o write_fieldrec.o -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -L/opt/pgi/linux86/lib -L/usr/lib -lf2c /opt/pgi/linux86/6.1/lib/libf2c.a(open.o)(.text+0x35f): In function f_open’:
open.c: warning: the use of tmpnam' is dangerous, better use mkstemp’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x19d): In function l_R': lread.c: undefined reference to __ctype_b’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x248):lread.c: undefined reference to __ctype_b' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x2a6):lread.c: undefined reference to __ctype_b’
/opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x2ce):lread.c: undefined reference to __ctype_b' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x77e): In function l_L’:
lread.c: undefined reference to __ctype_b' /opt/pgi/linux86/6.1/lib/libf2c.a(lread.o)(.text+0x9ba):lread.c: more undefined references to __ctype_b’ follow
/bin/rm -f data_area.exe
pgf90 -o data_area.exe latlon.o llxy.o mxmnll.o nestll.o rflp.o setup.o outpt.o vtran.o search.o data30s.o data_area.o -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -L/opt/pgi/linux86/lib -L/usr/lib -lf2c
/bin/rm -f rdem.exe
pgf90 -o rdem.exe cr30sdata.o read30s.o rdem.o ia.o -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -L/opt/pgi/linux86/lib -L/usr/lib -lf2c
make[1]: Leaving directory `/home/audrius/TERRAIN/src’
Any suggestions, ideas or comments would be appreciated.
