Hi all,
I’m getting “undefined reference to” errors when i compile the WRFV2.1.1 from UCAR with PGI compiler 6.1. I have successfully compile netcdf with PGI compiler and i’m using a machine with Redhat 9 and the following info:
Linux 2.4.21-4.ELsmp #1 SMP Fri Oct 3 17:31:21 EDT 2003 i686 athlon i386 GNU/Linux.
Below is the errors i got after issue ./compile em_real
ranlib libwrflib.a
pgf90 -o real.exe -fast -w -byteswapio -Mfree -tp p6 -byteswapio real_em.o ../dyn_em/module_initialize_real.o libwrflib.a -L../external/io_netcdf -lwrfio_nf -L/tmp/final/lib -lnetcdf -L../external/io_grib1 -lio_grib1 ../frame/module_internal_header_util.o ../frame/pack_utils.o -L../external/esmf_time_f90 -lesmf_time
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0xb14): In function ncx_get_float_uchar': : **undefined reference to __mth_i_fixux’**
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0xd23): In function ncx_put_float_uchar': : **undefined reference to __mth_i_floatux’**
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0xfc4): In function ncx_get_double_uchar': : undefined reference to __mth_i_dfixux’
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0x1203): In function ncx_put_double_uchar': : undefined reference to __mth_i_dfloatux’
make[1]: [em_real] Error 2 (ignored)
pgf90 -o ndown.exe -fast -w -byteswapio -Mfree -tp p6 -byteswapio ndown_em.o ../dyn_em/module_initialize_real.o libwrflib.a -L../external/io_netcdf -lwrfio_nf -L/tmp/final/lib -lnetcdf -L../external/io_grib1 -lio_grib1 ../frame/module_internal_header_util.o ../frame/pack_utils.o -L../external/esmf_time_f90 -lesmf_time
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0xb14): In function ncx_get_float_uchar': : undefined reference to __mth_i_fixux’
/tmp/final/lib/libnetcdf.a(ncx.o)(.text+0xd23): In function ncx_put_float_uchar': : undefined reference to __mth_i_floatux’
make[1]: Leaving directory `/tmp/WRFV2/main’
( cd test/em_real ; /bin/rm -f wrf.exe ; ln -s ../../main/wrf.exe . )
if [ 0 -eq 1 ] ; then
( cd test/em_real ; /bin/rm -f wrf_ESMFApp.exe ; ln -s ../../main/wrf_ESMFApp.exe . ) ;
fi
( cd test/em_real ; /bin/rm -f real.exe ; ln -s ../../main/real.exe . )
( cd test/em_real ; /bin/rm -f ndown.exe ; ln -s ../../main/ndown.exe . )
( cd test/em_real ; /bin/rm -f README.namelist ; ln -s ../../run/README.namelist . )
( cd test/em_real ; /bin/rm -f ETAMPNEW_DATA RRTM_DATA ;
ln -sf ../../run/ETAMPNEW_DATA . ;
ln -sf ../../run/RRTM_DATA . ;
if [ 4 -eq 8 ] ; then
ln -sf ../../run/ETAMPNEW_DATA_DBL ETAMPNEW_DATA ;
ln -sf ../../run/RRTM_DATA_DBL RRTM_DATA ;
fi )
( cd test/em_real ; /bin/rm -f GENPARM.TBL ; ln -s ../../run/GENPARM.TBL . )
( cd test/em_real ; /bin/rm -f LANDUSE.TBL ; ln -s ../../run/LANDUSE.TBL . )
( cd test/em_real ; /bin/rm -f SOILPARM.TBL ; ln -s ../../run/SOILPARM.TBL . )
( cd test/em_real ; /bin/rm -f VEGPARM.TBL ; ln -s ../../run/VEGPARM.TBL . )
( cd test/em_real ; /bin/rm -f tr49t67 ; ln -s ../../run/tr49t67 . )
( cd test/em_real ; /bin/rm -f tr49t85 ; ln -s ../../run/tr49t85 . )
( cd test/em_real ; /bin/rm -f tr67t85 ; ln -s ../../run/tr67t85 . )
( cd test/em_real ; /bin/rm -f gribmap.txt ; ln -s ../../run/gribmap.txt . )
( cd run ; /bin/rm -f real.exe ; ln -s ../main/real.exe . )
( cd run ; /bin/rm -f ndown.exe ; ln -s ../main/ndown.exe . )
( cd run ; /bin/rm -f namelist.input ; ln -s ../test/em_real/namelist.input . )
-------------------------------------------END------------------------
I have also put my configure.wrf file just incase some one want to have a look at it
------------------configure.wrf------------------------------------------
Architecture specific settings
Settings for PC Linux i486 i586 i686, PGI compiler (Single-threaded, no nesting)
FC = pgf90
LD = pgf90
CC = gcc
SCC = $(CC)
RWORDSIZE = $(NATIVE_RWORDSIZE)
FC = pgf90
LD = pgf90
CC = gcc
SCC = $(CC)
SFC = $(FC)
PROMOTION = -r$(RWORDSIZE) -i4
CFLAGS =
FCOPTIM = -fast
FCDEBUG = #-g
#FCBASEOPTS = -w -byteswapio -Ktrap=fp -Mfree -tp p6 $(FCDEBUG)
FCBASEOPTS = -w -byteswapio -Mfree -tp p6 $(FCDEBUG) # -Mlfs
FCFLAGS = $(FCOPTIM) $(FCBASEOPTS)
ARCHFLAGS = -DDEREF_KLUDGE -DIO_DEREF_KLUDGE -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=$(RWORDSIZE) -DLWORDSIZE=4
-DNETCDF -DGRIB1
-DTRIEDNTRUE
-DLIMIT_ARGS
INCLUDE_MODULES = -module ../main -I../external/io_netcdf -I../external/io_int -I../external/esmf_time_f90
-I../frame -I../share -I../phys -I../chem -I../inc
PERL = perl
REGISTRY = Registry
LIB = -L../external/io_netcdf -lwrfio_nf -L/tmp/final/lib -lnetcdf
LDFLAGS = $(FCFLAGS) -byteswapio
ENVCOMPDEFS =
WRF_CHEM = 0
CPP = /lib/cpp -C -P -traditional
POUND_DEF = $(COREDEFS) -DNONSTANDARD_SYSTEM -DF90_STANDALONE -DCONFIG_BUF_LEN=$(CONFIG_BUF_LEN) -DMAX_DOMAINS_F=$(MAX_DOMAINS)
CPPFLAGS = -I$(LIBINCLUDE) -C -P $(ARCHFLAGS) $(ENVCOMPDEFS) $(POUND_DEF)
AR = ar ru
M4 = m4
RANLIB = ranlib
NETCDFPATH = /tmp/final
CC_TOOLS = $(CC)
externals : wrf_ioapi_includes wrfio_nf wrfio_grib1 wrfio_int module_dm.F esmf_time
module_dm.F :
( /bin/cp module_dm_warning module_dm.F ; cat module_dm_stubs.F >> module_dm.F )
wrfio_nf :
( cd ../external/io_netcdf ;
make NETCDFPATH=/tmp/final RANLIB=“$(RANLIB)” CPP=“$(CPP)” FC=“$(FC) $(PROMOTION) $(FCFLAGS) -w” TRADFLAG=“-traditional” )
wrfio_grib1 :
( cd ../external/io_grib1 ; \ make CC=“$(SCC)” CFLAGS=“$(CFLAGS)” RANLIB=“$(RANLIB)” CPP=“$(CPP)” FC=“$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) -w” TRADFLAG=“-traditional” )
wrfio_int : ( cd ../external/io_int ; \ make CC=“$(CC)” RANLIB=“$(RANLIB)” CPP=“$(CPP)” SFC=“$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)” FC=“$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) -w”
TRADFLAG=“-traditional” all )
esmf_time :
( cd ../external/esmf_time_f90 ; \ make FC=“$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)” RANLIB=“$(RANLIB)” CPP=“$(CPP) -I../../inc -I. $(POUND_DEF)” )
compile these without high optimization to speed compilesolve_interface.o : solve_interface.F
shift_domain_em.o : shift_domain_em.F
module_io_mm5.o : module_io_mm5.F
module_si_io.o : module_si_io.F
module_io_wrf.o : module_io_wrf.Fmodule_domain.o : module_domain.F
module_start.o : module_start.F
module_initialize.o : module_initialize.F
module_initialize_b_wave.o : module_initialize_b_wave.F
module_initialize_hill2d_x.o : module_initialize_hill2d_x.Fmodule_initialize_quarter_ss.o : module_initialize_quarter_ss.F
module_initialize_squall2d_x.o : module_initialize_squall2d_x.F
module_initialize_squall2d_y.o : module_initialize_squall2d_y.F
module_initialize_real.o : module_initialize_real.F
module_dm.o : module_dm.Fstart_domain.o : start_domain.Fmediation_integrate.o : mediation_integrate.F
module_configure.o : module_configure.F
solve_interface.o
shift_domain_em.o
module_io_mm5.o module_si_io.o module_io_wrf.o module_domain.o \module_start.o module_initialize.o module_initialize_b_wave.o
module_initialize_hill2d_x.o module_initialize_quarter_ss.o
module_initialize_squall2d_x.o module_initialize_squall2d_y.o
module_configure.o
module_initialize_real.o module_dm.o start_domain.o :
$(RM) $@
$(SED_FTN) $.F > $.b
$(CPP) -I../inc $(CPPFLAGS) $.b > $.f
$(RM) $.b
$(FC) -c $(PROMOTION) $(FCBASEOPTS) $(MODULE_DIRS) $.f
if [ ! -e $@ ] ; then \
sleep 10 ; $(FC) -c $(PROMOTION) $(FCBASEOPTS) $(MODULE_DIRS) $*.f ; \
fi
sleep 30 ; $(FC) -c $(PROMOTION) $(FCBASEOPTS) $(MODULE_DIRS) $*.f ; \
fi
sleep 300 ; $(FC) -c $(PROMOTION) $(FCBASEOPTS) $(MODULE_DIRS) $*.f ; \
fi
Macros, these should be generic for all machines
LN = ln -sf
MAKE = make -i -r
RM = rm -f
There is probably no reason to modify these rules
wrf_ioapi_includes :
( cd ../external/ioapi_share ; \ $(MAKE) NATIVE_RWORDSIZE=“$(NATIVE_RWORDSIZE)” RWORDSIZE=“$(RWORDSIZE)” )
.F.i:
$(RM) $@
$(CPP) -I../inc $(CPPFLAGS) $.F > $@
mv $.i $(DEVTOP)/pick/$.f
cp $.F $(DEVTOP)/pick
.F.o:
$(RM) $@
$(RM) $.b
$(FC) -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $.f
sleep 10 ; $(FC) -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $*.f ; \
fi
fi
.F.f:
$(RM) $@
$(CPP) -I../inc $(CPPFLAGS) $.b > $@ $(RM) $.b
.f.o:
$(RM) $@
$(FC) -c $(FCFLAGS) $(PROMOTION) $*.f
sleep 10 ; $(FC) -c $(FCFLAGS) $(PROMOTION) $*.f ; \
fi
fi
.c.o:
$(RM) $@
$(CC) -c $(CFLAGS) $*.c
--------------END configure.wrf--------------------------------------
Thanks,
peterr0
