Hi Mat,
I started out with the basic ‘-g –O0 –mp’ flag set, and compilation failed with a long list of errors. So I stepped back to the default set (as in those in the configure.wrf I posted previously) and progressively worked back to a point which compilation was successful. The most basic set I could get down to was ‘-g –O0 –mp –byteswapio –Mfree’ (I can’t find any mention of ‘-Mfree’ in the PGF User Guide, so I’m unsure of its effect).
I ran the compiled executable in pgdbg, with pgienv omp on, and I can reach the first OMP command, which is in the subroutine SOLVE_EM.
pgdbg> step
Stopped at 0x490705, function solve_em, file solve_em.f, line 1523
#1523: !$OMP PARALLEL DO &
pgdbg> step
pgserv 27022: pr_ptrace (req PTRACE_PEEKTEXT, pid 27023)
pgserv 27022: read: unable to read address 0x490728
pgserv 27022: read: unable to read address 0x85f2d0
pgserv 27022: read: unable to read address 0x8600e0
pgserv 27022: read: unable to read address 0x85fe58
pgserv 27022: read: unable to read address 0x4ca6f0
pgserv 27022: read: unable to read address 0xb7a688
Stopped at 0x49072a, function solve_em, file solve_em.f, line 1526
#1526: DO ij = 1 , grid%num_tiles
pgdbg> step
The relevant code lines are
!$OMP PARALLEL DO &
!$OMP PRIVATE ( ij )
CALL rk_step_prep ( config_flags, rk_step, &
u_2, v_2, w_2, t_2, ph_2, mu_2, &
moist_2, &
ru, rv, rw, ww, php, alt, muu, muv, &
mub, mut, phb, pb, p, al, alb, &
cqu, cqv, cqw, &
msfu, msfv, msft, &
fnm, fnp, dnw, rdx, rdy, &
num_3d_m, &
ids, ide, jds, jde, kds, kde, &
ims, ime, jms, jme, kms, kme, &
grid%i_start(ij), grid%i_end(ij), &
grid%j_start(ij), grid%j_end(ij), &
k_start, k_end )
END DO
!$OMP END PARALLEL DO
And on stepping into the DO loop, the debugger dies reporting
pgserv 27022: read: stranger PID 27023
db_set_code_brk : DiBreakpointSet fails
pgserv 27022: cont : no threads to continue
I decided it worth running an idealised case compiled with the same configure.wrf (em_quarter_ss), as it does run on 2 cpu’s. The debugger dies at the same location as in the real case, reporting the same errors. As such, I don’t think I’m actually reaching the point where em_real is seg faulting.
