We worked through the Xcode/Mavericks problems
http://www.pgroup.com/products/freepgi/getxcode.pdf
and we built WRFv3 with the following configure.txt
mountainlion% ./configure
checking for perl5… no
checking for perl… found /usr/local/bin/perl (perl)
** WARNING: No path to NETCDF and environment variable NETCDF not set.
** would you like me to try to fix? [y]
n
Will configure for use without NetCDF
PHDF5 not set in environment. Will configure WRF for use without.
$JASPERLIB or $JASPERINC not found in environment, configuring to build without grib2 I/O…
Please select from among the following supported platforms.
- Darwin (MACOS) PGI compiler with pgcc (serial)
- Darwin (MACOS) PGI compiler with pgcc (smpar)
- Darwin (MACOS) PGI compiler with pgcc (dmpar)
- Darwin (MACOS) PGI compiler with pgcc (dm+sm)
- Darwin (MACOS) intel compiler with icc (serial)
- Darwin (MACOS) intel compiler with icc (smpar)
- Darwin (MACOS) intel compiler with icc (dmpar)
- Darwin (MACOS) intel compiler with icc (dm+sm)
- Darwin (MACOS) intel compiler with cc (serial)
- Darwin (MACOS) intel compiler with cc (smpar)
- Darwin (MACOS) intel compiler with cc (dmpar)
- Darwin (MACOS) intel compiler with cc (dm+sm)
- Darwin (MACOS) g95 with gcc (serial)
- Darwin (MACOS) g95 with gcc (dmpar)
- Darwin (MACOS) gfortran with gcc (serial)
- Darwin (MACOS) gfortran with gcc (smpar)
- Darwin (MACOS) gfortran with gcc (dmpar)
- Darwin (MACOS) gfortran with gcc (dm+sm)
- Darwin (MACOS) xlf (serial)
- Darwin (MACOS) xlf (dmpar)
Enter selection [1-20] : 3
Compile for nesting? (1=basic, 2=preset moves, 3=vortex following) [default 1]: 1
Configuration successful. To build the model type compile .
testing for MPI_Comm_f2c and MPI_Comm_c2f
MPI_Comm_f2c and MPI_Comm_c2f are not supported
testing for fseeko and fseeko64
fseeko is supported and handles 64 bit offsets
And here is configure.wrf
configure.wrf
This file was automatically generated by the configure script in the
top level directory. You may make changes to the settings in this
file but be aware they will be overwritten each time you run configure.
Ordinarily, it is necessary to run configure once, when the code is
first installed.
To permanently change options, change the settings for your platform
in the file arch/configure.defaults then rerun configure.
SHELL = /bin/sh
DEVTOP = pwd
LIBINCLUDE = .
.SUFFIXES: .F .i .o .f90 .c
Get core settings from environment (set in compile script)
Note to add a core, this has to be added to.
COREDEFS = -DEM_CORE=$(WRF_EM_CORE)
-DNMM_CORE=$(WRF_NMM_CORE) -DNMM_MAX_DIM=2600
-DCOAMPS_CORE=$(WRF_COAMPS_CORE)
-DDA_CORE=$(WRF_DA_CORE)
-DEXP_CORE=$(WRF_EXP_CORE)
Single location for defining total number of domains. You need
at least 1 + 2*(number of total nests). For example, 1 coarse
grid + three fine grids = 1 + 2(3) = 7, so MAX_DOMAINS=7.
MAX_DOMAINS = 21
DM buffer length for the configuration flags.
CONFIG_BUF_LEN = 32768
Size of bitmasks (in 4byte integers) of stream masks for WRF I/O
MAX_HISTORY = 25
IWORDSIZE = 4
DWORDSIZE = 8
LWORDSIZE = 4
The settings in this section are defaults that may be overridden by the
architecture-specific settings in the next section.
NOTE: Do not modify these default values here. To override these
values, make changes after “Architecture specific settings”.
Native size (in bytes) of Fortran REAL data type on this architecture
Note: to change real wordsize (for example, to promote REALs from
4-byte to 8-byte), modify the definition of RWORDSIZE in the
section following “Architecture specific settings”. Do not
change NATIVE_RWORDSIZE as is it architecture-specific.
NATIVE_RWORDSIZE = 4
Default sed command and script for Fortran source files
#SED_FTN = sed -f $(WRF_SRC_ROOT_DIR)/arch/standard.sed
SED_FTN = $(WRF_SRC_ROOT_DIR)/tools/standard.exe
Hack to work around $(PWD) not changing during OSF1 build.
$(IO_GRIB_SHARE_DIR) is reset during the OSF1 build only.
IO_GRIB_SHARE_DIR =
ESMF switches
These are set up by Config.pl
switch to use separately installed ESMF library for coupling: 1==true
ESMF_COUPLING = 0
select dependences on module_utility.o
ESMF_MOD_DEPENDENCE = $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90/module_utility.o
select -I options for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_INC = -I$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90
select -I options for separately installed ESMF library, if present
ESMF_MOD_INC = $(ESMF_IO_INC)
select cpp token for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_DEFS =
select build target for external/io_esmf vs. external/esmf_time_f90
ESMF_TARGET = esmf_time
ESMFINCLUDEGOESHERE
LIBWRFLIB = libwrflib.a
Settings for Darwin (MACOS) PGI compiler with pgcc (dmpar)
DMPARALLEL = 1
OMPCPP = # -D_OPENMP
OMP = # -mp -Minfo=mp -Mrecursive
OMPCC = # -mp
SFC = pgf90
SCC = pgcc
CCOMP = pgcc
DM_FC = mpif90 -f90=$(SFC)
DM_CC = mpicc -cc=$(SCC) -DMPI2_SUPPORT
FC = $(DM_FC)
CC = $(DM_CC) -DFSEEKO_OK
LD = $(FC)
RWORDSIZE = $(NATIVE_RWORDSIZE)
PROMOTION = -r$(RWORDSIZE) -i4
ARCH_LOCAL = -DMACOS -DNONSTANDARD_SYSTEM_SUBR
CFLAGS_LOCAL = -DMACOS
LDFLAGS_LOCAL =
CPLUSPLUSLIB =
ESMF_LDFLAG = $(CPLUSPLUSLIB)
FCOPTIM = -O2 -fast
FCREDUCEDOPT = $(FCOPTIM)
FCNOOPT = -O0
FCDEBUG = # -g $(FCNOOPT)
FORMAT_FIXED = -Mfixed
FORMAT_FREE = -Mfree
FCSUFFIX =
BYTESWAPIO = -byteswapio
FCBASEOPTS_NO_G = -w $(FORMAT_FREE) $(BYTESWAPIO) $(OMP)
FCBASEOPTS = $(FCBASEOPTS_NO_G) $(FCDEBUG)
MODULE_SRCH_FLAG = -module $(WRF_SRC_ROOT_DIR)/main
TRADFLAG = -traditional
CPP = cpp -C -P -xassembler-with-cpp
AR = ar
ARFLAGS = ru
M4 = m4 -B 14000
RANLIB = ranlib
CC_TOOLS = cc
POSTAMBLE
FGREP = fgrep -iq
ARCHFLAGS = $(COREDEFS) -DIWORDSIZE=$(IWORDSIZE) -DDWORDSIZE=$(DWORDSIZE) -DRWORDSIZE=$(RWORDSIZE) -DLWORDSIZE=$(LWORDSIZE)
$(ARCH_LOCAL)
$(DA_ARCHFLAGS)
-DDM_PARALLEL
-DUSE_ALLOCATABLES
-DGRIB1
-DINTIO
-DLIMIT_ARGS
-DCONFIG_BUF_LEN=$(CONFIG_BUF_LEN)
-DMAX_DOMAINS_F=$(MAX_DOMAINS)
-DMAX_HISTORY=$(MAX_HISTORY)
-DNMM_NEST=$(WRF_NMM_NEST)
CFLAGS = $(CFLAGS_LOCAL) -DDM_PARALLEL
FCFLAGS = $(FCOPTIM) $(FCBASEOPTS)
ESMF_LIB_FLAGS =
ESMF 5 – these are defined in esmf.mk, included above
ESMF_IO_LIB = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
ESMF_IO_LIB_EXT = -L$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 -lesmf_time
INCLUDE_MODULES = $(MODULE_SRCH_FLAG)
$(ESMF_MOD_INC) $(ESMF_LIB_FLAGS)
-I$(WRF_SRC_ROOT_DIR)/main
-I$(WRF_SRC_ROOT_DIR)/external/io_netcdf
-I$(WRF_SRC_ROOT_DIR)/external/io_int
-I$(WRF_SRC_ROOT_DIR)/frame
-I$(WRF_SRC_ROOT_DIR)/share
-I$(WRF_SRC_ROOT_DIR)/phys
-I$(WRF_SRC_ROOT_DIR)/chem -I$(WRF_SRC_ROOT_DIR)/inc
-I$(NETCDFPATH)/include \
REGISTRY = Registry
LIB_BUNDLED =
$(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5/libfftpack.a
$(WRF_SRC_ROOT_DIR)/external/io_grib1/libio_grib1.a
$(WRF_SRC_ROOT_DIR)/external/io_grib_share/libio_grib_share.a
$(WRF_SRC_ROOT_DIR)/external/io_int/libwrfio_int.a
$(ESMF_IO_LIB)
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a
$(WRF_SRC_ROOT_DIR)/frame/module_internal_header_util.o
$(WRF_SRC_ROOT_DIR)/frame/pack_utils.o
LIB_EXTERNAL =
LIB = $(LIB_BUNDLED) $(LIB_EXTERNAL) $(LIB_LOCAL)
LDFLAGS = $(OMP) $(FCFLAGS) $(LDFLAGS_LOCAL)
ENVCOMPDEFS =
WRF_CHEM = 0
CPPFLAGS = $(ARCHFLAGS) $(ENVCOMPDEFS) -I$(LIBINCLUDE) $(TRADFLAG)
NETCDFPATH =
PNETCDFPATH =
bundled: wrf_ioapi_includes wrfio_grib_share wrfio_grib1 wrfio_int esmf_time fftpack
external: $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a gen_comms_rsllite module_dm_rsllite $(ESMF_TARGET)
externals: bundled external
gen_comms_serial :
( /bin/rm -f $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c )
module_dm_serial :
( if [ ! -e module_dm.F ] ; then /bin/cp module_dm_warning module_dm.F ; cat module_dm_stubs.F >> module_dm.F ; fi )
gen_comms_rsllite :
( if [ ! -e $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ] ; then
/bin/cp $(WRF_SRC_ROOT_DIR)/tools/gen_comms_warning $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ;
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/gen_comms.c >> $(WRF_SRC_ROOT_DIR)/tools/gen_comms.c ; fi )
module_dm_rsllite :
cat $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/module_dm.F >> module_dm.F ; fi )
wrfio_nf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_netcdf ;
make NETCDFPATH=“$(NETCDFPATH)” RANLIB=“$(RANLIB)” CPP=“$(CPP)”
CC=“$(SCC)” CFLAGS=“$(CFLAGS)”
FC=“$(SFC) $(PROMOTION) $(FCFLAGS)” TRADFLAG=“$(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” )
wrfio_pnf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_pnetcdf ;
make NETCDFPATH=“$(PNETCDFPATH)” RANLIB=“$(RANLIB)” CPP=“$(CPP) $(ARCHFLAGS)”
FC=“$(FC) $(PROMOTION) $(FCFLAGS)” TRADFLAG=“$(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” )
wrfio_grib_share :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib_share ;
make CC=“$(SCC)” CFLAGS=“$(CFLAGS)” RM=“$(RM)” RANLIB=“$(RANLIB)” CPP=“$(CPP)”
FC=“$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)” TRADFLAG=“$(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” archive)
wrfio_grib1 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib1 ;
wrfio_grib2 :
( cd $(WRF_SRC_ROOT_DIR)/external/io_grib2 ;
make CC=“$(SCC)” CFLAGS=“$(CFLAGS) " RM=”$(RM)" RANLIB=“$(RANLIB)”
CPP=“$(CPP)”
FC=“$(SFC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)” TRADFLAG=“-traditional” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)”
FIXED=“$(FORMAT_FIXED)” archive)
wrfio_int :
( cd $(WRF_SRC_ROOT_DIR)/external/io_int ;
make CC=“$(CC)” RM=“$(RM)” RANLIB=“$(RANLIB)” CPP=“$(CPP)”
FC=“$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)” FGREP=“$(FGREP)”
TRADFLAG=“$(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” ARCHFLAGS=“$(ARCHFLAGS)” all )
esmf_time :
( cd $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90 ;
make FC=“$(SFC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)” RANLIB=“$(RANLIB)”
CPP=“$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc -I. $(ARCHFLAGS) $(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” )
fftpack :
( cd $(WRF_SRC_ROOT_DIR)/external/fftpack/fftpack5 ;
make FC=“$(SFC)” FFLAGS=“$(PROMOTION) $(FCDEBUG) $(FCBASEOPTS)” RANLIB=“$(RANLIB)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” )
atm_ocn :
( cd $(WRF_SRC_ROOT_DIR)/external/atm_ocn ;
CPP=“$(CPP)”
FC=“$(DM_FC) $(PROMOTION) -I. $(FCDEBUG) $(FCBASEOPTS) $(FCSUFFIX)” TRADFLAG=“-traditional” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)”
FIXED=“$(FORMAT_FIXED)” )
$(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a :
( cd $(WRF_SRC_ROOT_DIR)/external/RSL_LITE ; make CC=“$(CC) $(CFLAGS)”
FC=“$(FC) $(FCFLAGS) $(PROMOTION) $(BYTESWAPIO)”
CPP=“$(CPP) -I. $(ARCHFLAGS) $(TRADFLAG)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” ;
$(RANLIB) $(WRF_SRC_ROOT_DIR)/external/RSL_LITE/librsl_lite.a )
Macros, these should be generic for all machines
LN = ln -sf
MAKE = make -i -r
RM = rm -f
These sub-directory builds are identical across all architectures
wrf_ioapi_includes :
( cd $(WRF_SRC_ROOT_DIR)/external/ioapi_share ;
$(MAKE) NATIVE_RWORDSIZE=“$(NATIVE_RWORDSIZE)” RWORDSIZE=“$(RWORDSIZE)” AR=“$(AR)” ARFLAGS=“$(ARFLAGS)” )
wrfio_esmf :
( cd $(WRF_SRC_ROOT_DIR)/external/io_esmf ;
make FC=“$(FC) $(PROMOTION) $(FCDEBUG) $(FCBASEOPTS) $(ESMF_MOD_INC)”
RANLIB=“$(RANLIB)” CPP=“$(CPP) $(POUND_DEF) " AR=”$(AR)" ARFLAGS=“$(ARFLAGS)” )
There is probably no reason to modify these rules
.F.i:
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $.F > $@
mv $.i $(DEVTOP)/pick/$.f90
cp $.F $(DEVTOP)/pick
.F.o:
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $.F > $.bb
$(SED_FTN) $.bb | $(CPP) > $.f90
$(RM) $.b $.bb
@ if echo $(ARCHFLAGS) | $(FGREP) ‘DVAR4D’; then
echo COMPILING $.F for 4DVAR ;
$(WRF_SRC_ROOT_DIR)/var/build/da_name_space.pl $.f90 > $.f90.tmp ;
mv $.f90.tmp $.f90 ;
fi
if $(FGREP) ‘!$$OMP’ $.f90 ; then
if [ -n “$(OMP)” ] ; then echo COMPILING $.F WITH OMP ; fi ;
$(FC) -o $@ -c $(FCFLAGS) $(OMP) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $.f90 ;
else
if [ -n “$(OMP)” ] ; then echo COMPILING $.F WITHOUT OMP ; fi ;
$(FC) -o $@ -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $.f90 ;
fi
.F.f90:
$(RM) $@
$(SED_FTN) $.F > $.b
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $.b > $@
$(RM) $.b
.f90.o:
$(RM) $@
$(FC) -o $@ -c $(FCFLAGS) $(PROMOTION) $(FCSUFFIX) $*.f90
setfeenv.o : setfeenv.c
$(RM) $@
$(CCOMP) -o $@ -c $(CFLAGS) $(OMPCC) $*.c
.c.o:
$(RM) $@
$(CC) -o $@ -c $(CFLAGS) $*.c
A little more adventurous. Allow full opt on
mediation_integrate.o \
shift_domain_em.o \
solve_em.o ← gets a little kick from SOLVE_EM_SPECIAL too, if defined
mediation_feedback_domain.o : mediation_feedback_domain.F
mediation_force_domain.o : mediation_force_domain.F
mediation_interp_domain.o : mediation_interp_domain.F
compile these without high optimization to speed compile
convert_nmm.o : convert_nmm.F
init_modules_em.o : init_modules_em.F
input_wrf.o : input_wrf.F
module_io.o : module_io.F
module_comm_dm.o : module_comm_dm.F
module_comm_dm_0.o : module_comm_dm_0.F
module_comm_dm_1.o : module_comm_dm_1.F
module_comm_dm_2.o : module_comm_dm_2.F
module_comm_dm_3.o : module_comm_dm_3.F
module_comm_nesting_dm.o : module_comm_nesting_dm.F
module_configure.o : module_configure.F
module_dm.o : module_dm.F
module_domain.o : module_domain.F
module_domain_type.o : module_domain_type.F
module_alloc_space_0.o : module_alloc_space_0.F
module_alloc_space_1.o : module_alloc_space_1.F
module_alloc_space_2.o : module_alloc_space_2.F
module_alloc_space_3.o : module_alloc_space_3.F
module_alloc_space_4.o : module_alloc_space_4.F
module_alloc_space_5.o : module_alloc_space_5.F
module_alloc_space_6.o : module_alloc_space_6.F
module_alloc_space_7.o : module_alloc_space_7.F
module_alloc_space_8.o : module_alloc_space_8.F
module_alloc_space_9.o : module_alloc_space_9.F
module_tiles.o : module_tiles.F
module_fddaobs_rtfdda.o : module_fddaobs_rtfdda.F
module_initialize.o : module_initialize.F
module_physics_init.o : module_physics_init.F
module_initialize_b_wave.o : module_initialize_b_wave.F
module_initialize_hill2d_x.o : module_initialize_hill2d_x.F
module_initialize_quarter_ss.o : module_initialize_quarter_ss.F
module_initialize_real.o : module_initialize_real.F
module_initialize_real.o: module_initialize_real.F
module_initialize_squall2d_x.o : module_initialize_squall2d_x.F
module_initialize_squall2d_y.o : module_initialize_squall2d_y.F
module_integrate.o : module_integrate.F
module_io_mm5.o : module_io_mm5.F
module_io_wrf.o : module_io_wrf.F
module_si_io.o : module_si_io.F
module_state_description.o : module_state_description.F
output_wrf.o : output_wrf.F
solve_interface.o : solve_interface.F
start_domain.o : start_domain.F
start_domain_nmm.o : start_domain_nmm.F
start_em.o : start_em.F
wrf_bdyin.o : wrf_bdyin.F
wrf_bdyout.o : wrf_bdyout.F
wrf_ext_read_field.o : wrf_ext_read_field.F
wrf_ext_write_field.o : wrf_ext_write_field.F
wrf_fddaobs_in.o : wrf_fddaobs_in.F
wrf_histin.o : wrf_histin.F
wrf_histout.o : wrf_histout.F
wrf_inputin.o : wrf_inputin.F
wrf_inputout.o : wrf_inputout.F
wrf_restartin.o : wrf_restartin.F
wrf_restartout.o : wrf_restartout.F
wrf_tsin.o : wrf_tsin.F
nl_get_0_routines.o : nl_get_0_routines.F
nl_get_1_routines.o : nl_get_1_routines.F
nl_set_0_routines.o : nl_set_0_routines.F
nl_set_1_routines.o : nl_set_1_routines.F
convert_nmm.o
init_modules_em.o
module_dm.o
module_initialize.o
module_integrate.o
module_io_mm5.o
module_io_wrf.o
module_si_io.o
module_tiles.o
output_wrf.o
solve_interface.o
start_domain.o
start_domain_nmm.o
shift_domain_nmm.o
start_em.o
wrf_fddaobs_in.o
wrf_tsin.o :
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $(OMPCPP) $.b > $.f90
$(RM) $.b
fi
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $.f90 ;
else
$(FC) -c $(PROMOTION) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ;
fi
#solve_em.o :
$(RM) $@
$(CPP) -I$(WRF_SRC_ROOT_DIR)/inc $(CPPFLAGS) $.b > $.f90
$(RM) $*.b
$(FC) -o $@ -c $(FCFLAGS) $(MODULE_DIRS) $(PROMOTION) $(FCSUFFIX) $(SOLVE_EM_SPECIAL) $(OMP) $*.f90
module_sf_ruclsm.o : module_sf_ruclsm.F
$(RM) $@
$(RM) $.b
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $(OMP) $.f90 ;
else
$(FC) -c $(PROMOTION) $(FCREDUCEDOPT) $(FCBASEOPTS) $(MODULE_DIRS) $(FCSUFFIX) $*.f90 ;
fi
compile without OMP
input_wrf.o
module_domain.o
module_io.o
wrf_bdyin.o
wrf_bdyout.o
wrf_histin.o
wrf_histout.o
wrf_inputin.o
wrf_inputout.o
wrf_restartin.o
wrf_restartout.o
module_alloc_space.o
module_comm_dm.o
module_comm_dm_0.o
module_comm_dm_1.o
module_comm_dm_2.o
module_comm_dm_3.o
$(RM) $@
fi
$(RM) $.b $.bb
$(FC) -c $(PROMOTION) $(FCSUFFIX) $(FCNOOPT) $(FCBASEOPTS) $(MODULE_DIRS) $.f90
