My system:
- Mac OSX El Capitan 10.11.6.
- Xcode version 8.2.1 (8C1002)
- System compiler is Apple LLVM version 8.0.0 (clang-800.0.42.1)
I tried to build a trivial C program but it fails as follows.
$ /opt/pgi/osx86-64/16.10/bin/pgcc tls.c
PGC-W-0267-#warning – This version of Xcode is not supported by PGI (/opt/pgi/osx86-64/16.10/include/sys/cdefs.h: 2126)
PGC-W-0267-#warning – “Unsupported compiler detected” (/usr/include/sys/cdefs.h: 81)
PGC-S-0226-Syntax error in #if (/Library/Developer/CommandLineTools/usr/bin/…/lib/clang/8.0.0/include/stdint.h: 31)
PGC/x86-64 OSX 16.10-0: compilation completed with severe errors
However, when I build with C++11, there is no problem.
$ /opt/pgi/osx86-64/16.10/bin/pgc++ --c++11 tls.c
On the other hand, building with the default C++ language fails, but this makes sense since C99 fixed-width integer types were not added to C++ until C++11.
$ /opt/pgi/osx86-64/16.10/bin/pgc++ tls.c
“/usr/include/sys/_types/_int8_t.h”, line 30: error: invalid redeclaration of
type name “int8_t” (declared at line 235 of
“/Library/Developer/CommandLineTools/usr/bin/…/lib/clang/8.0.0/inclu
de/stdint.h”)
typedef __signed char int8_t;
1 error detected in the compilation of “tls.c”.
For completeness, neither C99 nor C11 work:
$ /opt/pgi/osx86-64/16.10/bin/pgcc -c11 tls.c
$ /opt/pgi/osx86-64/16.10/bin/pgcc -c99 tls.c
The source code is as follows.
$ cat tls.c
#include <stdio.h>
#include <stdlib.h>
#include <omp.h>
int p;
#pragma omp threadprivate(p)
int s;
int main(int argc, char **argv)
#pragma omp parallel
printf(“%d: %p %p\n”, omp_get_thread_num(), &p, &s );
return 0;
