Complete headless Jetson Orin Nano setup (NVMe boot + GNOME & XFCE VNC)
I have written a blog for fully headless setup, covering NVMe SSD flashing and two stable ways to get remote GUI access: GNOME via x11vnc and XFCE fallback. Blog link: Jetson Orin Nano Headless Setup: NVMe Boot, SDK Flashing, and VNC (GNOME & XFCE) - Nandan Manjunatha
Copy-pasting my blog content so that the info is not lost in the future:
This post walks through SSD-based flashing using NVIDIA SDK Manager with a host<->target model, then covers two proven strategies for remote desktop access: a GNOME setup using x11vnc, and a lightweight XFCE fallback using TigerVNC. Expect explicit steps, rationale for each design choice, and configurations that survive reboots and updates, no monitor, no keyboard, and no fragile shortcuts.
Audience & Assumptions:
This guide assumes familiarity with Linux, SSH, and systemd. It is written for developers running Jetson Orin Nano headlessly (no monitor/keyboard) who want reliable remote GUI access without fragile workarounds.
Part 1:
Flashing OS onto Jetson Headlessly with an SSD
This section explains how to flash and boot an NVMe SSD on a Jetson Orin Nano without attaching a monitor or keyboard. The process uses NVIDIA SDK Manager , which enforces a strict host–target model. Confusing the two is the most common cause of failure, so we state them clearly.
Before proceeding, I would recommend to watch this setup guide from DronBot Workshop on YouTube, which covers the same ground visually: YouTube Link . Even I followed the same until acquiring the IP address of the Jetson after flashing.
Host and Target Overview
Host Machine (Required)
  • Purpose: Flashes the Jetson and installs NVIDIA SDK components
  • System: Ubuntu 20.04 or 22.04 (x86_64 PC or laptop)
  • Software: NVIDIA SDK Manager
  • Connectivity: USB-C (data cable) during flashing, Ethernet used later for SDK installation
Target Device (Jetson)
  • Device: NVIDIA Jetson Orin Nano Developer Kit
  • Storage: NVMe SSD (M.2 2230 or 2280, PCIe Gen3 only; minimum 256 GB recommended)
  • Flashing state: Recovery mode
  • Peripherals: No display or keyboard required (headless)
  • Networking: Ethernet required after flashing
The host only orchestrates the process. The target is the device being flashed and configured.
Step 1: Install NVMe SSD on the Target
Power off the Jetson Orin Nano. Install the NVMe SSD into one of the M.2 slots on the underside of the carrier board and secure it with the provided screw.
This SSD will become the boot device. No microSD card is involved.
Step 2: Put the Target into Recovery Mode
External Image
To allow the host to flash the target, recovery mode is mandatory.
  1. Locate the 14-pin button header on the Jetson carrier board.
  2. Short FC REC and GND (pins 2 and 3) using a jumper.
  3. Leave the jumper connected.
  4. Power on the Jetson.
If recovery mode is not active, the host will not detect the target.
Step 3: Prepare the Host Machine
On the host (Ubuntu PC):
  1. Install NVIDIA SDK Manager (.deb package).
  2. Disable sleep and screen blanking.
  3. Ensure internet connectivity.
Nothing in this step affects the Jetson directly.
Step 4: Flash the Target from the Host
External Image
All actions below happen on the host, but they operate on the target.
  1. Launch SDK Manager on the host and log in.
  2. Connect the Jetson (in recovery mode) to the host using USB-C.
  3. Power on the Jetson.
  4. SDK Manager should detect the device:
    • Select Jetson Orin Nano 8GB Developer Kit
  5. Accept the license agreement.
  6. Click Download and Flash.
  7. When prompted:
    • Choose Preconfig (recommended for headless use), or
    • Choose Runtime if you prefer first-boot setup.
  8. Select nvme as the target storage device.
  9. Start flashing and wait.
Do not disconnect power or USB. If this fails, you start over.
Step 5: First Boot and Network-Based SDK Installation
  1. After flashing completes:
    • Power off the Jetson
    • Remove the recovery jumper. I used female dupont connectors for easy handling.
  2. Power on the Jetson normally (no USB flashing cable required anymore).
  3. Connect the Jetson to your network using Ethernet. This is mandatory, the remaining SDK components are installed over the network.
  4. Determine the Jetson’s IP address without using a monitor or keyboard.
    Since this is a headless setup, do not rely on local login. Use one of the following host-side methods:
    Scan the local subnet (recommended)
    1. On the host, identify the active Ethernet interface and subnet:
    ip addr show eth0
    Example output:
    inet 10.42.0.1/24
    1. Scan the subnet for live devices: Install nmap if not already present: sudo apt install nmap
    nmap -sn 10.42.0.0/24
    Identify the Jetson by vendor or as a newly appeared IP (typically 10.42.0.xxx).
  5. Return to NVIDIA SDK Manager on the host.
  6. Provide:
    • Target IP address
    • Target username
    • Target password
  7. Resume and complete SDK component installation.
Once this step finishes, the Jetson is fully operational and no longer depends on the host.
Note: The same IP address is used for SSH, SCP, and VNC access going forward.
Part 2:
Setting Up VNC for Remote Desktop Access * GNOME Edition
External Image
Running GNOME headlessly on a Jetson-class device is non-trivial. GNOME expects a real display, valid EDID, and an active login session. GNOME cannot run headlessly without a valid display pipeline. This setup mirrors the real :0 display using x11vnc, which is the only method that remains stable across reboots and driver updates. This guide shows a working, production-grade setup using x11vnc, mirroring the real GNOME display over VNC, no hacks, no virtual desktops. This method was recommended by NVIDIA engineers themselves on their developer forums.
This Nvidia forum post was the inspiration for this method, but we are not doing it exactly the same way. Here they have used monitor for a setting change, we are doing it completely headless.
The approach is explicit:
  • Force GNOME to start with a valid EDID
  • Ensure a real :0 display exists
  • Attach x11vnc to that display at boot
Prerequisites
  • GNOME desktop installed and enabled
  • Root access
  • SSH access (since this is headless)
  • A known-good EDID from any working monitor
  • A VNC client on your host machine
This setup is commonly used on Jetson devices, but applies to any NVIDIA system running GNOME with the proprietary driver.
Step 1: Install and Initialize x11vnc
Install x11vnc and set a VNC password:
sudo apt update
sudo apt install x11vnc -y
x11vnc -storepasswd
x11vnc does not create a display. It attaches to an existing one. Everything that follows exists to guarantee that display.
Step 2: Force Graphical Boot Target
GNOME must start at boot, even without a monitor.
sudo systemctl set-default graphical.target
sudo reboot
If this step is skipped, x11vnc will start successfully, and attach to nothing.
Step 3: Extract EDID from a Working Monitor (Host Side)
On any Linux system with a monitor attached (your host machine):
xrandr --props
External Image
Locate the EDID: block, copy only the hex values, and paste them into a file without spaces or line breaks:
nano edid.hex
External Image
Convert it to binary:
xxd -r -p edid.hex EDID.bin
Verify the EDID:
edid-decode EDID.bin
External Image You should see a valid output describing the monitor capabilities.
Step 4: Install EDID on the Target (Jetson)
⚠️ Use an EDID from a monitor that supports the resolution you intend to use. Invalid EDIDs will cause GDM to fail silently.
Copy the EDID to the Jetson:
scp EDID.bin YOUR_USER@jetson:/tmp
Move it into firmware location:
sudo mkdir -p /lib/firmware/edid
sudo cp /tmp/EDID.bin /lib/firmware/edid/EDID.bin
Step 5: Replace Xorg Configuration (Critical)
Back up the existing config:
sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
sudo nano /etc/X11/xorg.conf
Replace the entire file with the following config:
If /etc/X11/xorg.conf does not exist, create it. Jetson images often rely on autogenerated defaults.
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Module"
    SubSection     "extmod"
        Option         "omit xfree86-dga"
    EndSubSection
    Load           "glx"
    Disable        "dri"
EndSection
Section "InputDevice"
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/mouse"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
Section "Device"
    Identifier     "Tegra0"
    Driver         "nvidia"
    Option         "AllowEmptyInitialConfiguration" "true"
    Option         "ConnectedMonitor" "DFP-0"
    Option         "CustomEDID" "DFP-0:/lib/firmware/edid/EDID.bin"
    Option         "UseDisplayDevice" "DFP-0"
    Option         "IgnoreEDIDChecksum" "DFP-0"
    Option         "ModeValidation" "AllowNonEdidModes"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "FakeVendor"
    ModelName      "Fake1920x1080"
    Option         "DPMS" "false"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Tegra0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
        Modes      "1920x1080"
    EndSubSection
EndSection
Restart GNOME:
sudo systemctl restart gdm3
Sanity check:
DISPLAY=:0 xrandr
If this fails, VNC will never work. Fix this first.
Step 6: Enable GNOME Auto-Login (Mandatory)
x11vnc requires an active user session. No login → no desktop.
Edit GDM configuration:
sudo nano /etc/gdm3/custom.conf
Enable auto-login:
[daemon]
AutomaticLoginEnable=true
AutomaticLogin=YOUR_USERNAME
Reboot:
sudo reboot
Verify again:
DISPLAY=:0 xrandr
Step 7: Create a systemd Service for x11vnc
Create the service file:
sudo nano /etc/systemd/system/x11vnc.service
Paste the following:
[Unit]
Description=Start x11vnc at startup
Requires=display-manager.service
After=display-manager.service
[Service]
Type=simple
User=YOUR_USERNAME
ExecStart=/usr/bin/x11vnc -auth guess -display WAIT:0 -loop -usepw -forever -rfbport 5900
Restart=on-failure
[Install]
WantedBy=graphical.target
Enable and start:
sudo systemctl daemon-reload
sudo systemctl enable x11vnc.service
sudo systemctl start x11vnc.service
Finally, Connect via VNC Viewer
Install a VNC viewer on your host machine (e.g., tigervnc-viewer, RealVNC, etc.) I recommend tigervnc-viewer for its simplicity and performance. Or RealVNC for its user-friendly interface.
Recommended: SSH Tunnel + Local VNC Viewer
From your host machine:
ssh -N -L 5900:localhost:5900 yourusername@JETSON_IP
vncviewer localhost:5900
You should now see the real GNOME desktop, hardware-accelerated, exactly as if a monitor were attached.
If you see a blank screen or errors, revisit the EDID and Xorg configuration steps. These are proven to be the most fragile parts of this setup. Many people reported rectifying in EDID and xorg.conf fixed their issues.
Part 3:
Setting Up VNC for Remote Desktop Access * XFCE Edition
External Image
This is completely optional. If you prefer GNOME, skip this section. I keep it here for completeness and serves as a backup plan if GNOME VNC setup fails by some updates in future.
If you want reliable headless VNC without GNOME’s complexity, XFCE is the pragmatic choice. XFCE is lightweight, predictable, and works cleanly with TigerVNC using a user-level systemd service. No EDID hacks, no display manager dependencies, no GPU quirks.
This guide sets up a persistent, headless XFCE desktop accessible over VNC, designed to survive reboots and run without any local login.
Why XFCE + TigerVNC
  • No dependency on a physical display
  • No Xorg/Wayland/GDM edge cases
  • Clean separation from system display managers
  • Works perfectly over SSH tunnels
  • Ideal for Jetson, servers, and lab machines
If you need stability over aesthetics, this is the correct stack.
Step 1: Install XFCE (Target Machine)
Install the XFCE desktop environment:
sudo apt update
sudo apt install -y xfce4 xfce4-goodies
Do not install a display manager. We are running XFCE entirely inside VNC.
Step 2: Install TigerVNC
sudo apt install -y tigervnc-standalone-server tigervnc-common
Set a VNC password:
vncpasswd
This creates ~/.vnc/passwd, which TigerVNC will use for authentication.
Step 3: Quick Sanity Test
Start a temporary VNC server:
tigervncserver :1
If this launches without errors, the core components are working. Stop it afterward:
tigervncserver -kill :1
XFCE runs on a separate X display (:1) and does not interfere with GNOME (:0). Both can coexist safely. Also that the port 5900 is for GNOME VNC, while 5901 is for XFCE VNC. Adjust accordingly based on which desktop you are using.
Step 4: Disable Legacy VNC Startup Scripts
Remove or empty any existing VNC startup files to avoid race conditions with systemd:
rm -f ~/.vnc/xstartup
TigerVNC will be launched and managed only via systemd from this point onward.
Step 5: Create a User-Level systemd Service
Create the user systemd directory if it doesn’t exist:
mkdir -p ~/.config/systemd/user
nano ~/.config/systemd/user/tigervnc.service
Paste the following service definition (adjust username if needed):
[Unit]
Description=TigerVNC server (Xfce headless)
After=network.target
[Service]
Type=simple
Environment=DISPLAY=:1
ExecStart=/usr/bin/Xtigervnc \
  :1 \
  -localhost \
  -SecurityTypes VncAuth \
  -rfbauth /home/yourusername/.vnc/passwd \
  -geometry 1920x1080
ExecStartPost=/bin/sh -c 'sleep 2; DISPLAY=:1 dbus-launch --exit-with-session xfce4-session & disown'
Restart=on-failure
RestartSec=3
[Install]
WantedBy=default.target
Why this works
  • Xtigervnc creates a real X server
  • XFCE runs inside that server
  • dbus-launch ensures session services work correctly
  • No dependency on login managers or GPUs
Step 6: Enable User Lingering (Critical)
By default, user services do not start unless the user logs in. Headless systems need lingering enabled.
sudo loginctl enable-linger yourusername
Verify:
loginctl show-user yourusername | grep Linger
Expected output:
Linger=yes
If this is not set, your VNC server will not start after reboot.
Step 7: Enable and Start the Service
Reload user services and enable TigerVNC:
systemctl --user daemon-reload
systemctl --user enable tigervnc
systemctl --user start tigervnc
Check status:
systemctl --user status tigervnc
Reboot to confirm persistence:
sudo reboot
Step 8: Access VNC Securely Over SSH
Same here, use an SSH tunnel to secure your VNC connection.
ssh -N -L 5901:localhost:5901 yourusername@JETSON_IP
vncviewer localhost:5901
This keeps VNC off the network and avoids exposing port 5901.
Final Notes
Troubleshooting
If you encounter issues, First do a google search to see if there are nvidia forum posts. Keep taking LLMs help as last resort. as often I see it can go crazy and overcomplicate things.
Ports & Displays
Display :0  → GNOME + x11vnc → TCP 5900
Display :1  → XFCE + TigerVNC → TCP 5901
Security Note
Do not expose VNC ports directly to the network. Always use SSH tunneling.
Thanks for your sharing to the community!
Thank you for this excellent post.
I followed “Part 2” and I am able to connect from Windows into Jetson using free version of RealVNC client.
However I cannot Copy from Windows and Paste into Jetson. It works the other way around, as well as on Jetson itself.
This is kind of deal breaker for me since I am developing on Jetson for the most part.
It is not a problem with RealVNC which has setting to enable Copy/Paste and it is turned on. I am also using the same instance of RealVNC to connect to Raspberry Pi and I can copy both ways.
I looked into “autocutsel“ but I was not able to make it work in this scenario.
Any ideas would be greatly appreciated.
UPDATE:
I discovered that Paste from Client to Remote works selectively for few applications. In my case it does work in Chromium and Mousepad. It does not work for Terminal, Text Editor, Libre Office Apps, …
Also tried TightVNC cilent, same behavior.
The hint about Mousepad’s behavior was worth its weight in gold — thank you!
After several hours of intense discussion with an AI, we jointly wrote a replacement for autocutsel. For testing purposes, it can be launched in a terminal window inside the VNC client, or run permanently via a systemd‑user service. In all cases, the environment variables DISPLAY and XAUTHORITY must be set correctly. For example:
DISPLAY=:0 XAUTHORITY=/run/user/1000/gdm/Xauthority python3 ~/clipboard-sync.py
The code in clipboard-sync.py is:
#!/usr/bin/env python3
import gi
gi.require_version('Gtk', '3.0')
from gi.repository import Gtk, Gdk
import subprocess
import time
def get_mac_clipboard():
    clipboard = Gtk.Clipboard.get(Gdk.SELECTION_CLIPBOARD)
    text = clipboard.wait_for_text()
    # Wenn nichts da ist → ignorieren
    if not text:
        return None
    # UTF‑8 Validierung
    try:
        text.encode("utf-8")
        return text
    except UnicodeError:
        return None
def set_x11_clipboard(text):
    p = subprocess.Popen(
        ["xclip", "-selection", "clipboard"],
        stdin=subprocess.PIPE
    p.communicate(input=text.encode("utf-8"))
last = None
while True:
    text = get_mac_clipboard()
    # Nur reagieren, wenn sich der Text geändert hat
    if text and text != last:
        last = text
    time.sleep(0.2)
In my case, the ~/.config/systemd/user/clipboard-sync.service looks like this:
[Unit]
Description=Clipboard Sync (Mac → Jetson)
After=graphical-session.target
[Service]
Environment=DISPLAY=:0
Environment=XAUTHORITY=/run/user/1000/gdm/Xauthority
ExecStart=/usr/bin/python3 /home/klaus/clipboard-sync.py
Restart=always
RestartSec=1
[Install]
The username must, of course, be adjusted.
The code imitates Mousepad’s behavior to some extent: it receives whatever was copied into the clipboard inside a VNC window and then transfers it into the clipboard of the X session, allowing any other program — such as a terminal — to paste it.
You may need to install one or another Python module. But you’ll notice that quickly once you test the code manually for the first time
Best regards from the snowy Bavarian Forrest,
Klaus
By the way, you don’t need an EDID file at all to create a virtual monitor. This can also be done directly by specifying modelines. I’ll simply show how this works in my setup. For this purpose, the file /etc/X11/xorg.conf.d/10-nvidia.conf is used
Section “Device”
   Identifier “NVIDIA”
   Driver “nvidia”
   Option “UseDisplayDevice” “DFP-0”
   Option “ConnectedMonitor” “DFP-0”
   Option “AllowEmptyInitialConfiguration” “true”
   Option “ModeValidation” “NoEdidModes, NoMaxPClkCheck, NoHorizSyncCheck, NoVertRefreshCheck”
EndSection
Section “Monitor”
   Identifier “Monitor0”
   Modeline “2560x1440” 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
   Modeline “1920x1080” 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
   Modeline “1600x900” 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync
   Modeline “1280x1024” 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
EndSection
Section “Screen”
   Identifier “Screen0”
   Device “NVIDIA”
   Monitor “Monitor0”
   DefaultDepth 24
   SubSection “Display”
   Depth 24
   Modes “2560x1440” “1920x1080” “1600x900” “1280x1024”
   EndSubSection
EndSection
In fact, a few additional resolution options are added at runtime. You could prevent that — but why would you. For my use case on a 16" MacBook, the 2560×1600 variant with a scale of 125% turned out to work best.
I’ll also show what my ~/.config/systemd/user/x11vnc.service looks like. Maybe this will be helpful for someone out there.
[Unit]
Description=VNC Server for X11 (User)
Wants=graphical-session.target
[Service]
Type=simple
ExecStart=/usr/bin/x11vnc -display :0 -auth /run/user/1000/gdm/Xauthority -forever -shared -rfbauth /home/klaus/.vnc/passwd -rfbport 5900
Restart=on-failure
[Install]
The WAIT:0 is no longer required here. The file /etc/X11/xorg.conf.d/10-nvidia.conf ensures that Xorg starts immediately with a valid display. GDM creates a real user session with its own Xauthority at /run/user/1000/gdm/Xauthority, and x11vnc only connects once GDM has fully initialized the session. This is ensured in particular by the lines:
Best regards and have fun,
Klaus
And then there was another issue that I found extremely annoying. In a VNC session, key repeat didn’t work at all for me. In other words, holding down a key was not recognized. This is especially irritating when you want to delete text using the Backspace key — something I do all the time. Once again, the previously mentioned AI and I developed a solution together: keyrepeat.py.
from Xlib import X, display
from Xlib.ext import xtest
import time
d = display.Display()
Timing-Parameter
REPEAT_DELAY = 0.20      # Sekunden bis Wiederholung startet
REPEAT_RATE  = 0.01      # Sekunden zwischen Wiederholungen
POLL_RATE    = 0.005     # Polling-Intervall (10 ms)
Modifier-Keycodes, die Wiederholung blockieren
MODIFIERS = {
    37,   # Left Ctrl
    105,  # Right Ctrl
    64,   # Left Alt (Option)
    108,  # Right Alt (AltGr)
    133,  # Left Super (Command)
    134,  # Right Super
pressed_since = {}
while True:
    keymap = d.query_keymap()
    now = time.time()
    current_pressed = set()
    # Alle möglichen Keycodes prüfen
    for keycode in range(8, 256):
        byte = keycode // 8
        bit = keycode % 8
        if keymap[byte] & (1 << bit):
            current_pressed.add(keycode)
    # PrĂĽfen, ob ein Modifier aktiv ist
    modifier_active = any(k in current_pressed for k in MODIFIERS)
    # Neue gedrĂĽckte Tasten registrieren
    for keycode in current_pressed:
        if keycode not in pressed_since:
            pressed_since[keycode] = now
    # Losgelassene Tasten entfernen
    for keycode in list(pressed_since.keys()):
        if keycode not in current_pressed:
            del pressed_since[keycode]
    # Wiederholungen erzeugen (nur wenn KEIN Modifier aktiv ist)
    if not modifier_active:
        for keycode, t0 in list(pressed_since.items()):
            if now - t0 > REPEAT_DELAY:
                xtest.fake_input(d, X.KeyPress, keycode)
                xtest.fake_input(d, X.KeyRelease, keycode)
                d.sync()
    time.sleep(POLL_RATE)
A ~/.config/systemd/user/keyrepeat.service is also a suitable option for this as well.
[Unit]
Description=Custom KeyRepeat Daemon
[Service]
ExecStart=/usr/bin/python3 /home/klaus/keyrepeat.py
Restart=always
RestartSec=1
[Install]
Best regards,
Klaus
Klaus, fantastic job!
Thank you so much sharing.
Best
Artur
