Completed Getting Started with Accelerated Computing in CUDA C/C++
I recently completed the Getting Started in Accelerated Computing with CUDA C/C++ course.
but the certificate does not appear on the My learning page. The grade is still stuck at 0%.
Hello @rush2fer
Hello, our records indicate that you have not yet passed the course, so you will not have a certificate at this time. Simply saving the notebooks does not do anything in regards to the grading process. For this particular course you need to successfully answer all of the questions in the final section.
Thanks, I hadn’t realized that there were three different notebooks and that I had to restart the environment for each one. I was able to catch up on the missing parts and get the certificate!
