Hi ! i’m implementing a NVIDIA GRID vGPU virtualizating a Tesla M60 (in mode M60-2Q) to run a mathematical sofware utilizating the GPU to compute. I’ve noticed when i run nvidia-smi that "Compute M." is in "Prohibited". However, if i try to change it to Default or EXCLUSIVE PROCESS, i just cant! it saids that de change is made, but it is’t. Could it be the problem the configuration of the virtual machine in M60-2Q?
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi
Thu Sep 07 15:32:55 2017
| NVIDIA-SMI 370.12 Driver Version: 370.12 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 GRID M60-2Q WDDM | 0000:02:04.0 On | N/A |
| N/A N/A P0 N/A / N/A | 371MiB / 2048MiB | 1% Prohibited |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 184 C+G Insufficient Permissions N/A |
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi -c 1
Warning: Exclusive_Thread was deprecated! Setting Exclusive_Process instead.
Unable to set compute mode for GPU 0000:02:04.0: WDDM devices may only run in D
FAULT compute mode
Treating as warning and moving on.
All done.
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi -c 0
Set compute mode to DEFAULT for GPU 0000:02:04.0.
All done.
Thu Sep 07 15:40:46 2017
| N/A N/A P0 N/A / N/A | 371MiB / 2048MiB | 2% Prohibited |
