While running compute sanitizer to check my app I get error 500
========= COMPUTE-SANITIZER
========= Program hit CUDA_ERROR_NOT_FOUND (error 500) due to "named symbol not found" on CUDA API call to cuGetProcAddress.
========= Saved host backtrace up to driver entry point at error
========= Host Frame: [0x2d1e3a]
========= in /lib64/libcuda.so.1
========= Host Frame: [0xf9eb34]
========= in /lib64/libcutensor.so.1
========= Host Frame: [0xfa551a]
========= Host Frame: [0xfa5688]
========= Host Frame:__pthread_once_slow [0xfe57]
========= in /lib64/libpthread.so.0
========= Host Frame: [0xff4539]
========= Host Frame: [0xf9bfb7]
========= Host Frame: [0xfcd811]
========= Host Frame:cutensorInit [0xdc0c85]
========= Host Frame:/home/Yehonatans/work/nlircloud/src/ImageRec/common/tensorContraction.cu:35:CuTensorContraction::CuTensorContraction(float*, std::vector<int, std::allocator<int> >, float*, std::vector<int, std::allocator<int> >, float*, std::vector<int, std::allocator<int> >, std::vector<long, std::allocator<long> >) [0xf651d]
========= in /home/Yehonatans/work/nlircloud/src/cmake-build-debug/ImageRec/Apps/Main
My system is :
Rocky 8
Cuda 17 /17.1
Driver 515.65.01
What I am doing wrong and how can I solve the issue?
Regards
Yehonatan
