Configuration for running NVPPS GPIO mode
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi
I need a clarification on the configuration for NVPPS.
I am getting 1 HZ PPS signal which I am able to feed to Tegra. Can you tell me what should my DTS configuration look like? Should we enable fsync group for this feature to work or should this be disabled and only change the frequency say from 30 to 10hz if we need 10fps?
I have ptp enabled. I have nvpps set from a function into gpio mode but still there is lack of clarity. I am trying to follow this Orin Time Sync | NVIDIA Docs but still some confusions. Can you please share a step by step on how to achieve this?
Thanks!!
Jishnu
For clarification on NVPPS configuration, please refer to nvpps_main.c and nvpps.txt to understand how NVPPS works. Additionally, you can check cam_fsync.c to see how TSC_EDGE_OUT signals are configured.
What about this part? Rest I can try figure out, this part I am not clear.
I believe you don’t need to enable another fsync group. You can refer to the ‘cam_fsync_program_group_generator_edges()’ function in ‘cam_fsync.c’ for guidance.
