Configuring pins to SPI
I am attempting to connect a flowmeter (G1-1/2" 1.5" Water Flow Sensor Food-Grade Switch Hall Effect Flowmeter Fluid Meter Counter 5-150L/min) to a Jetson Nano via SPI using a LS7366R 32-BIT QUADRATURE COUNTER WITH SERIAL INTERFACE.
I have tried using sudo /opt/nvidia/jetson-io/jetson-io.py but the window instantly closes.
Thank you in advance for any help.
Hi averycbateman,
Are you using the devkit or custom board for Jetson Nano?
It seems you want to port a SPI device on Jetson Nano.
Have you verified the SPI loopback test before connecting to your SPI device?
Have you also gotten the porting guide and custom driver for your device from your vendor?
