Confirmation Needed for SSD Compatibility with Jetson Orin Nano
I purchased a Samsung 990 EVO Plus SSD 2TB, PCIe Gen 4×4, Gen 5×2 M.2 2280, with speeds up to 7,250 MB/s, to install as additional storage on the Jetson Orin Nano. I believe the Jetson Orin Nano supports this type of SSD; could you please confirm?
Thank you.
Mustafa
Based on the provided context, the Jetson Orin Nano series supports PCIe interfaces. According to the Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide, the Orin module brings four PCIe interfaces to the module pins for up to seven total lanes (1 x4 + 1 x1 + 1x2) for use on the carrier board. The PCIe x4 interface (PCIE0) operates up to Gen4 speed and supports both Root Port and Endpoint operation.
Since the Samsung 990 EVO Plus SSD 2TB is a PCIe Gen 4 and Gen 5 M.2 2280 SSD, it should be compatible with the Jetson Orin Nano. However, please note that the Jetson Orin Nano’s PCIe interface might not support Gen 5 speeds, as the context only mentions support for Gen 4 speeds.
To confirm compatibility and ensure optimal performance, I recommend checking the following:
  1. Verify that the Jetson Orin Nano’s carrier board has an M.2 slot that supports PCIe Gen 4 and Gen 5 SSDs.
  2. Check the Jetson Orin Nano’s documentation and the Samsung 990 EVO Plus SSD’s documentation to ensure that the SSD’s power consumption and thermal requirements are compatible with the Jetson Orin Nano.
  3. Consult the Jetson Orin Nano’s Supported Component List (SCL) to confirm that the Samsung 990 EVO Plus SSD is listed as a supported component.
In summary, based on the provided context, the Jetson Orin Nano series supports PCIe interfaces, and the Samsung 990 EVO Plus SSD 2TB should be compatible. However, it is essential to verify the compatibility and ensure optimal performance by checking the documentation and supported component list.
I’m using this one: Samsung 990 EVO Plus NVMe M.2 SSD 1 TB, PCIe 4.0 x4 / PCIe 5.0 x2, NVMe 2.0
And it works without any problems with the Jetson Nano Orin.
