I have read https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html#_Device_Properties
But still confused and can not get correct cam setting.
I have 4 cam sensor, name w x y z.
w x connect to SoC csi-port-c, y z connect to SoC csi-port-d
So here is the question
I have to do add 4 port eahch two have same port-index in tegra-capture-vi to create /dev/video?
tegra-capture-vi {
num-channels = <4>;
ports {
port@0 {
reg = <0>;
ar0234_vi_in0: endpoint {
vc-id = <0>;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&ar0234_csi_out0>;
port@1 {
reg = <1>;
ar0234_vi_in1: endpoint {
vc-id = <1>;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&ar0234_csi_out1>;
port@2 {
reg = <2>;
ar0234_vi_in2: endpoint {
vc-id = <0>;
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&ar0234_csi_out2>;
port@3 {
reg = <3>;
ar0234_vi_in3: endpoint {
vc-id = <1>;
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&ar0234_csi_out3>;
In nvcsi port-index is mean which csi_port for Soc?
If yes, channel0&1 port-index gonna be 2 for csi-port-c, channel2&3 port-index gonna be 3 for csi-port-d, right?
channel@0 {
port0{
ar0234_csi_in0: endpoint@0 {
port-index = <0>;
channel@1 {
port0{
ar0234_csi_in1: endpoint@2 {
port-index = <0>;
channel@2 {
port0{
ar0234_csi_in2: endpoint@4 {
port-index = <1>;
channel@3 {
port0{
ar0234_csi_in3: endpoint@6 {
port-index = <1>;
For sensor node, port-index is for seeting sensor data input to which vi port?
If yes, w x y z DTS goona be this, right?
mode_0{
tegra_sinterface = "serial_c"
port@0{
ar0234_ar0234_out0: endpoint{
vc-id=<0>;
port-index=<2>;
/* x */
mode_0{
port@0{
ar0234_ar0234_out1: endpoint{
vc-id=<1>;
port-index=<2>;
/* y */
mode_0{
tegra_sinterface = "serial_d"
port@0{
ar0234_ar0234_out2: endpoint{
vc-id=<0>;
port-index=<3>;
/* z */
mode_0{
port@0{
ar0234_ar0234_out3: endpoint{
vc-id=<1>;
port-index=<3>;
But when I use this DTSI only got /dev/video0 and /dev/video1
cam.txt (18.3 KB)
nvcsi.txt (2.1 KB)
tegra-capture-vi.txt (1.3 KB)
Here is the pad and sink info
Media controller API version 5.10.120
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.120
Device topology
- entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "zedx 12-0018":0 [ENABLED]
pad1: Source
-> "vi-output, zedx 12-0018":0 [ENABLED]
- entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
<- "zedx 12-0010":0 [ENABLED]
pad1: Source
-> "vi-output, zedx 12-0010":0 [ENABLED]
- entity 7: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
device node name /dev/v4l-subdev2
pad0: Sink
<- "zedx 13-0018":0 [ENABLED]
pad1: Source
-> "vi-output, zedx 13-0018":0 [ENABLED]
- entity 10: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
device node name /dev/v4l-subdev3
pad0: Sink
<- "zedx 13-0010":0 [ENABLED]
pad1: Source
-> "vi-output, zedx 13-0010":0 [ENABLED]
- entity 13: zedx 12-0018 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev4
pad0: Source
[fmt:SGRBG10_1X10/1920x1200 field:none colorspace:srgb]
-> "13e40000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 15: vi-output, zedx 12-0018 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "13e40000.host1x:nvcsi@15a00000-":1 [ENABLED]
- entity 33: zedx 12-0010 (1 pad, 1 link)
device node name /dev/v4l-subdev5
pad0: Source
- entity 35: vi-output, zedx 12-0010 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
- entity 45: zedx 13-0018 (1 pad, 1 link)
device node name /dev/v4l-subdev6
pad0: Source
- entity 47: vi-output, zedx 13-0018 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
- entity 57: zedx 13-0010 (1 pad, 1 link)
device node name /dev/v4l-subdev7
pad0: Source
- entity 59: vi-output, zedx 13-0010 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
Now I can see /dev/video0~3
But I notice I can’t use two csi serial port in same time.
For example single port work
$ v4l2-ctl --stream-mmap -d0 # csi port c
# Or
$ v4l2-ctl --stream-mmap -d2 # csi port d
But
# Also
The first stream will break (In here is vidoe0(csi_port_c))
I will got
[ 1009.991255] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: flags 2, err_data 0
[ 1010.042788] [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=1030815275936 sof_ts=1030815286080 gerror_code=2 gerror_data=a3 notify_bits=4000000000
[ 1010.042796] [RCE] "
[ 1012.690735] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1012.699927] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1012.711365] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1012.719117] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 1012.730518] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1012.738338] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 1012.749206] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1014.524421] bwmgr API not supported
[ 1017.042646] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1017.051885] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1017.062451] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1017.070197] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 1017.080886] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1017.088606] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 1017.099409] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1019.858591] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1019.867739] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1019.878307] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1019.886104] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 1019.897107] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1019.904884] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 1019.915960] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
hello caniculawolf,
you may see-also Topic 69753 for the mappings of the NVCSI and VI port-index.
please share your latest device tree for cross checking.
Hi Jerry,
I wish to double comfirm the understanding about port index in vi nvcsi and sensor to make sure I have correct DTS setting.
Is this right?
If vc-id not important, why we need that node?Or is that means each vi_channel can have lot of different vc-id stream?
nvcsi@15a00000 {
channel@0{
port{
port@0{
port-index=<0>; /* Means channel_0 is csi_a */
cam_sensor@18{
port{
port@0{
endpoint{
port-index = <2>; /* Means this sensor is connect to SoC csi_c */
vc-id = 0; /* No effect, not important */
tegra-capture-vi {
port{
port@0{
port-index=<3>; /* Means this vi channel is connect to nvcsi_port_index_3(csi_d) */
vc-id = 1; /* No effect, not important */
hello caniculawolf,
please note that, CSI0 D1 and CSI1 D0 P/N will always been swizzled for P/N on Orin NX.
please use device tree property, lane_polarity
to configure a polarity swap on any lane.
besides, you should setting both vc-id
and vc_id
if you would like to enable Jetson Virtual Channel with GMSL Camera Framework .
Hi Jerry,
Base on no any issue in example DTS, I suppose now I have correct understanding about port-index.
And accordind to doc vc-id property is special for GMSL framwork, it’s not about jetson’s virstual channel but also I have to set it correct.
If all of the above statements are correct, I will mark it as resolved.
okay, let’s close this discussion thread, please create another new topic if you need further supports.
system
Closed
December 31, 2024, 7:13am
11
