Isn’t Orin’s bandwidth is 204GB/s? Why is Nsight Profile showing 77.49GiB/s here?
Do you get this by profiling your application?
This might be profiled with a custom app rather than the spec value.
Hi,i get above info by following command:
nsys profile -s none -t cuda,osrt,nvtx --cuda-memory-usage=true --gpu-metrics-device=all -o gridsample -w true /usr/src/tensorrt/bin/trtexec --onnx=../xxx.onnx --fp16 --allowGPUFallback --iterations=1000 --useCudaGraph=enabled
And I use different onnx models, the “Memory Bandwidth” is always 77.49 GiB/s, which confuses me.
The info comes from the below TARGET_INFO_GPU table
https://docs.nvidia.com/nsight-systems/UserGuide/index.html#available-export-formats
CREATE TABLE TARGET_INFO_GPU (
totalMemory INTEGER, -- Total amount of memory on the device (B).
memoryBandwidth INTEGER, -- Amount of memory transferred (B).
clockRate INTEGER, -- Clock frequency (Hz).
We are checking this with our internal team.
Will update more with you.
