I want to connect more PCs to one Spark. But i get a problem during nvidia sync setup - because Unexpected Errorssh: handshake failed: knownhosts: key mismatch
This Spark is already connected to an other PC with nidia sync.
Hi, you should be able to connect to the same Spark with different machines.
If you manually connected via SSH then you may be hitting an issue where you have conflicting hostname/ip in your knownhosts file. You should look in your knownhosts files and remove any entries that match the hostname/ip you are trying to connect with Sync. After that you should be able to connect with Sync.
It is actually not possible to connect to a spark with the same user account from a diffrent machine. As you can see in the picture. Tested on serveral PCs.
I have had the same problem. Looked inside .config/NVIDIA as much as I coudl, but finally it only worked to completely remove everything aorund nvidia-sync.
