SSH works, but not Nvidia Sync
I have two DGS Spark and both are able to access via Ethernet from main Windows computer using ssh spark-xxxx.local call. One am I also able to set up via Nvidia Sync, but for the other one I only get an error trying both IP and .local settings. How can this be the case, as far as I can tell both are setup in exactly the same way?
/magnus
What is the error you are getting?
When I had a similar issue, there was a log file in “/Users/username/Library/Application Support/NVIDIA/Sync/logs/” that helped me figure out what was going on. Maybe there is a similar file in Windows?
Just said error in UI and the log contained nothing useful.
However, following re-installing Nvidia Sync, with the exact same configurations, it worked.
So, if you run into weird sync problems, try to re-install…
/magnus
