I installed NVIDIA Sync and AI Workbench on a Windows 11 Pro system without any problems. I was able to connect it to my DGX Spark and successfully opened a terminal exactly once. Since then, I am unable to open a terminal (the terminal window pops open and immediately closes). I am still able to use the AI Workbench both locally with docker on the Windows 11 Pro system and connected to the DGX Spark.
I have found the logs on the Windows 11 side of the conversation but don’t immediately see anything that tells me anything other than it opened and closed a connection successfully (if I’m reading the logs correctly).
While I have other SSH tools that can connect to the DGX Spark from the same Windows 11 Pro system, I would like to understand what changed to make the NVIDIA Sync terminal stop working.
I had the similar issue when running the Nvidia Sync APP on MacBookPro. I solved the problem by removing the DGX host MAC_ADDRESS entry from .ssh\known_hosts.
Not sure
Thanks. I tried your suggestion with the corresponding file under Windows 11. Unfortunately it didn’t work. I even removed the device (and cleared it out of the AppData…NVidia Corporation…ssh_config file so Sync would complain about the device still being there after I deleted it). The terminal window still opens and closes without displaying anything other than the window borders (and the Command Shell wrapper).
I noticed some logs in the path where the ssh_config file was under Sync, so I’ll go have a look there for any clues and report back if I find anything.
Adding a bit more to the mystery: On a different Windows 11 Pro system (an Intel NUC), I installed NVIDIA Sync without any problem, and it connects with the terminal flawlessly. I decided to connect both systems and observe the changes to the NVIDIA Sync-desktop log files. Both of them are identical in their responses to a terminal connection request. (They both look like they are reporting success, however I am making some assumptions based my interpretation of what’s written in the log responses.) I can say, however, that both are identical, even though one system is connecting via a terminal, and the other is not.
I am seeing the same behavior on Ubuntu as well. If I open a terminal manually and ssh in, it works fine. If I open the Sync tool and click the Terminal icon in it, the terminal pops up and closes immediately. No logs are written to nsync.log when it happens. The NVIDIA\ Sync-desktop.log shows that it opened successfully, with no errors reported. If I run the command listed on the spawnProcess log line, I get the same behavior. I temporarily changed gnome-terminal to not auto-dismiss the windows, and it looks like it is exiting with code 255 because of “Too many authentication failures”. Odd since manually calling ssh from a open terminal connects successfully… but maybe it is a similar reason for all of you.
Hi @jim180, are you still encountering this problem? You can also view the nvsync.log which should be found in the same place as the desktop log files you mentioned. You can also look at your /var/log/auth.log on your Spark device to see if any login issues are occurring.
If you found a fix please let me know so I can mark your issue as solved.
