I purchased this card NVIDIA Mellanox MCX653106A-ECAT ConnectX®-6 InfiniBand/VPI Adapter Card 100GbE/HDR100/EDR, Dual-Port QSFP56, PCIe 4.0 x 16, Tall Bracket - FS.com
to run RDMA. I am using the MCPM200 cable to connect the server to an other system that has SFP on that end. -
I installed the drivers from Mellanox OFED (MLNX_OFED) Software: End-User | NVIDIA Developer
ofed_info -s output is MLNX_OFED_LINUX-23.10-1.1.9.0
test@dev-server:~$ ibdev2netdev
mlx5_0 port 1 ==> ibp66s0f0 (Down)
mlx5_1 port 1 ==> ibp66s0f1 (Down)
test@dev-server:~$ lspci | grep "Mellanox"
42:00.0 Infiniband controller: Mellanox Technologies MT28908 Family [ConnectX-6]
42:00.1 Infiniband controller: Mellanox Technologies MT28908 Family [ConnectX-6]
ibv_devinfo
hca_id: mlx5_0
transport: InfiniBand (0)
fw_ver: 20.39.2048
node_guid: 58a2:e103:00b9:3414
sys_image_guid: 58a2:e103:00b9:3414
vendor_id: 0x02c9
vendor_part_id: 4123
hw_ver: 0x0
board_id: MT_0000000224
phys_port_cnt: 1
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 4096 (5)
sm_lid: 0
port_lid: 65535
port_lmc: 0x00
link_layer: InfiniBand
hca_id: mlx5_1
fw_ver: 20.39.2048
node_guid: 58a2:e103:00b9:3415
vendor_id: 0x02c9
hw_ver: 0x0
phys_port_cnt: 1
port: 1
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 65535
port_lmc: 0x00
- Tried setting the port to ethernet but it did not work:
mlxconfig -d /dev/mst/mt4123_pciconf0 set LINK_TYPE_P1=2
-E- Failed to open the device
test@dev-server:~$ mlxconfig -d /dev/mst/mt4123_pciconf0 reset
Reset configuration for device /dev/mst/mt4123_pciconf0? (y/n) [n] : y
Applying... Failed!
- mst commands:
test@dev-server:~$ sudo mst status
MST modules:
MST PCI module is not loaded
MST PCI configuration module is not loaded
PCI Devices:
42:00.0
test@dev-server:~$ mlxfwmanager
-E- No devices found or specified, mst might be stopped, run 'mst start' to load MST modules
test@dev-server:~$ sudo mst start
Starting MST (Mellanox Software Tools) driver set
Loading MST PCI module - Success
Loading MST PCI configuration module - Success
Create devices
Unloading MST PCI module (unused) - Success
MST modules:
MST PCI configuration module loaded
MST devices:
/dev/mst/mt4123_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=0000:42:00.0 addr.reg=88 data.reg=92 cr_bar.gw_offset=-1
Chip revision is: 00
test@dev-server:~$ mlxconfig -d /dev/mst/mt4123_pciconf0 set LINK_TYPE_P1=2
