Connecting to DGX Spark Connection Error
Getting “Connection Error” is something running on port 1 1000? Error:” Ping good. Can login just fine with ssh. Saw the other post referencing this but no information in that post other than uninstalling sync from the DGX but I don’t have it installed. I’m connecting from a windows system with Nvidia Sync installed. Cannot RDP to the system as well even with the Remote Desktop feature enabled.
  1. Can you access the dashboard locally on the Spark? http://localhost:11000/
  2. If you run ss -tlnp | grep 11000 you can see what ports are in use. Run this on the Spark and you should see
    LISTEN 0 4096 127.0.0.1:11000 0.0.0.0:* indicating the dashboard is listening.
  3. If you run that command on the host machine you shouldn’t see anything
