We are trying to use send scheduling on a Connectx-6 LX. If we set no timestamps on the packet buffers and manually send each packet at approximately the right time everything works. However if we set timestamps in the buffers then the first 25 packets are sent and the packets are received at the expected times but all subsequent calls to
rte_eth_tx_burst
return 0. If its relevant we are sending a single packet in each burst with timestamps 125 us apart.
We’ve tried setting the timestamps to low values and the packets are transmitted correctly and as expected the
tx_pp_timestamp_past_errors
value is incremented. We also set high values and this worked too with
tx_pp_timestamp_future_errors
incrementing.
Any ideas where to start debugging this? I couldn’t see any API which would give an error code for
rte_eth_tx_burst
failing.
We’re using DPDK 21.08 with the 5.4.3.1 Mellanox driver on Ubuntu 20.04.
