Hi folks,
I’m trying to make an application which sends a packet traffic at line rate(100Gbps) making use of “Packet Pacing(tx_pp)” feature.
However, I met an error message while enabling RTE_ETH_TX_OFFLOAD_SEND_ON_TIMESTAMP ‘rte_eth_dev_configure()’.
Before running my application, I followed an instruction on this page. (ESPCommunity)
Did I miss something ? or
Please let me know if there is a way of checking out whether the feature is enabled ?
I would appreciate if anyone could share an experience/gotcha/comments/suggestion/references while doing the same thing with me.
Kind regards,
Kevin
My environment is
Linux OS :
"Linux MELB-TEST-D18.ad.analog.com 4.18.0-477.10.1.rt7.274.el8_8.x86_64 #1 SMP PREEMPT_RT Wed Apr 5 13:20:38 EDT 2023 x86_64 x86_64 x86_64 GNU/Linux
Mellanox Firmware version :
[root@MELB-TEST-D18 generator]# mlxfwmanager
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX6DX
Part Number: 0F6FXM_08P2T2_Ax
Description: Mellanox ConnectX-6 Dx Dual Port 100 GbE QSFP56 Network Adapter
PSID: DEL0000000027
PCI Device Name: /dev/mst/mt4125_pciconf0
Base GUID: 946dae0300e22eda
Base MAC: 946daee22eda
Versions: Current Available
FW 22.36.1010 N/A
PXE 3.6.0901 N/A
UEFI 14.29.0014 N/A
Status: No matching image found
Full error messages are :
"EAL: Detected CPU lcores: 24
EAL: Detected NUMA nodes: 1
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode ‘PA’
EAL: VFIO support initialized
EAL: Probe PCI driver: mlx5_pci (15b3:101d) device: 0000:16:00.0 (socket 0)
EAL: Probe PCI driver: mlx5_pci (15b3:101d) device: 0000:16:00.1 (socket 0)
TELEMETRY: No legacy callbacks, legacy socket not created
Device driver name in use: mlx5_pci…
Initializing port 0 with 8 RX queues and 8 TX queues…
Ethdev port_id=0 requested Tx offloads 0x200000 doesn’t match Tx offloads capabilities 0xd96af in rte_eth_dev_configure()
EAL: Error - exiting with code: 1
Cause: Cannot configure device: err=-22, port=0
