Control the Jetson OrinNX remotely with GUI access
Hi, I’m trying to remote access into Jetson Orin NX. About the board’s side, i had installed a Dummy HDMI config via X11 to allow me to control it without monitor. However, when i use Teamviewer to connect to the board. The screen of my host’s teamviewer was freezed (sometimes it was cropped) and of course, i can’t interact with the screen at all.
My main purpose is just using Teamviewer connect to my board to see image captured from my board (when the board is not connected to any monitor). I’ve config the X11 config file to add a Dummy HDMI section, also settings ‘Sharing screen’ Active.
Btw, i’ve seen some related posts, but none of them give me the exact answer. Just the post right there (What is the best way to control the jetson Orin GUI remotely?) may be mostly the same situation like me. But it’s closed. So now, what is the best solution for my problem?
The issue seems to be specific to running the application. You may try the condition of having display. To check if it is specific to headless mode.
For headless mode, would suggest use VNC as suggested in
Jetson AGX Orin FAQ
Q: How to configure VNC w/o monitor connected for Jetson?
hi, i’ve done all the steps from that guide. But, of course, it doesnt work. So is there any other ways to fix that problems?
Tks,
We set up Orin NX module + Orin Nano carrier board, and follow the steps:
Jetson AGX Orin FAQ
We can remotely login through VNC. Would suggest try again. May try latest Jetpack 6.2.1 r36.4.4.
